  3. Arduino Uno Works, Nano not
8 Posts 4 Posters 3.2k Views 2 Watching
  • max929292M
    max929292M
    max929292
    I am building a motion sensor connecting to my ethernet gateway. When I make the sensor with Arduino Unos it works great. If I use same radio, sensor, cables and code with Arduino Nano's I get an "radio init fail".
    I triple checked cabling, the nanos etc. Also put a capacitor etc. but no success.
    Anybody has an idea why it works on UNOs but not on Nano's?
    • sundberg84S
      Sounds like a bad nano? Check power (3.3) with a multimeter to start with.
      Also try to upload some standard blinksketch and try the different pins the radio uses on the nano to see if something is broken
      • max929292M
        max929292M
        max929292
        I checked Voltage which is fine. Also Nano is working fine (Blink etc). I actually tested with three different nano and all give me same result whereas the UNO's immediately work. Do I need to make any adjustments in the code if I use Nanos?
        • sundberg84S
          No, it should be the same.
          • sowardS
            sowardS
            soward
            Check the power at the radio and make sure it's getting ~3.3v . Are the nanos 5v or 3.3v?
            max929292M 1 Reply Last reply
            • sundberg84S
              Nanos are 5v but have both 5v and 3.3v outputs.
              • sowardS soward
                max929292M
                max929292M
                max929292
                @soward Power and cabling has been checked. All is fine but I still get that error.
                • m26872M
                  m26872M
                  m26872
                  Does the Uno have a 3.3V-reg while Nano get 3.3V from it's Ftdi-chip (don't remember) Could Uno/Nano board selection in Arduino IDE effect the Ftdi behavior?
