  3. Arduino (MySensors W5100 Gateway) closing TCP connection (2us- NOT 2ms) after each sending of data
2 Posts 1 Posters 1.6k Views 1 Watching
  • maxtoxM
    maxtoxM
    maxtox
    wrote on last edited by maxtox
    Hello Everybody,
    just noticed with Wireshark, that TCP connection is closing after Arduino sends something!
    UDP does not do that with the same sketch!!!!
    It is closing after 2 MICROSECONDS not Milliseconds.. so it means, that TCP does not wait for anything and just closing...
    Did somebody noticed that too?
    i am working with a latest DEV branch.
    Thank you in Advance!
    Arduino Mega 2560 with iobroker.net (MQTT, node-red, etc..)
    • maxtoxM
      maxtoxM
      maxtox
      Hello Everybody,
      checked yesterday and noticed, that if i use JUST STANDARD "TCP W5100) Sketch, it happens (Connection is closing just (2 MICROseconds) after Arduino sends something and just after that it starting to establish a new connection over the next TCP port!
      Checked everything with WIRESHARK.
      WHEN I USE STANDARD ETHERNET sketch, from the Standard Arduino Library Example:
      https://github.com/arduino/Arduino/tree/master/libraries/Ethernet
      everything is just fine!
      Should i place it as an Issue?
