  3. radio init fail !!!
radio init fail !!!
3 Posts 3 Posters 1.5k Views 3 Watching
  • 8art-5imson8
    8art-5imson8
    8art-5imson
    hi
    I have 2 NRF24 radios with antenna and 12 without. i have set up a serial gateway on a arduino UNO and a Humidity sensor on another UNO (also tried on Pro Mini) Yesterday i had this basic setup working using the two antenna version RF modules. i then substituted the rf modules for antenna less ones. in the serial monitor, both came up with " radio init fail ,so i swapped them back. now the Humidity sensor says "id req" it sort of sends to
    gateway (i have no controller. just veiwing in ser monitor). i have capacitors on power lines. have reloaded sketches several times but still get the id req in the sensor side, i have even tried different sensor sketches they all sort of work, but give the id req thing. (also cleared eeprom)
    I dont know whether it is connected but ALL 12 ! of the antenna less ones say "radio init fail" in both sensor and gateway, they were all new and had worked previosly.
      Did you by any chance get the none-plus variant of the NRF24l01?
      "id req" --- Means id request. And as you have no controller no-one answers it.
      http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
      • Igor KatkovI
        Igor KatkovI
        Igor Katkov
        It must be something very dumb. Check that you have a solid galvanic connection to nrf modules on all lines.
