  3. DS18B20 and DHT22 in the same sensor and sketch
5 Posts 4 Posters 4.4k Views 4 Watching
  • miljumeM
    miljumeM
    miljume
    wrote on last edited by miljume
    I have created a sensor with both a DHT22 and a DS18B20 which will be located in my bathroom with the main unit with the DHT22 inside the bathroom and the DS18B20 (cable mounted) will be located in my sauna
    This seems to work fine but when I view the sensor in Domoticz it shows two devices with temp and humidity for both of them! I only want the DHT22 device to be temp & humidity and the other device to be temp only
    Is there a way to do this in the code?
    I have used the example sketches for Humidity and Temperature and put them together into one sketch so that I have one sensor with three child devices
    Anyone that could give me a hint?
    Regards,
    Mikael
    • S
      Slim
      Hi
      I have a node with DHT22 and a DS18B20, using this code.
       * Version 1.0 - Henrik EKblad
       * This sketch provides an example how to implement a humidity/temperature
       * sensor using DHT11/DHT-22
       * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
       * http://www.mysensors.org/build/temp
      #include <OneWire.h>
      #include <DHT.h>
      #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
      #define ONE_WIRE_BUS 4 // Pin where dallas sensor is connected
      #define CHILD_ID_HUM 1
      #define CHILD_ID_TEMP 2
      int numSensors=0;
      boolean metric = true;
      MyMessage msg(0,V_TEMP);
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
        gw.sendSketchInfo("Humidity", "1.0");
        sensors.begin();
        gw.begin();
        gw.sendSketchInfo("Temperature Sensor", "1.1");
           gw.present(i, S_TEMP);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
          Serial.println(temperature);
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        gw.process();
        gw.sleep(conversionTime);
          #if COMPARE_TEMP == 1
          #else
        gw.sleep(SLEEP_TIME); //sleep a bit
      This is what i get from the sensors.
      DS18B20 03-03-2016 17:49:21: 0;0;3;0;9;read: 7-7-0 s=0,c=1,t=0,pt=7,l=5,sg=0:2.3
      DHT22 03-03-2016 17:49:20: 0;0;3;0;9;read: 7-7-0 s=1,c=1,t=1,pt=7,l=5,sg=0:71.2
      DHT22 03-03-2016 17:49:20: 0;0;3;0;9;read: 7-7-0 s=2,c=1,t=0,pt=7,l=5,sg=0:5.8
      Try if this works better? I use PiDome as the controller.
      • miljumeM
        miljumeM
        miljume
        Thanks for a quick reply!
        I tested this code tonight but have the same problem, two devices popup in Domoticz but the second one (with DS18B20) also reports humidity which i guess is received from DHT22
        Not a very big problem if you know the setup but you could easily think that the humidity comes from the same measurement point as the DS18B20 which it dont
        • A
          A
          Affe
          Hi
          I got a problem when I would vertifiera sketch
          Does anyone have a working sketch dallas and DHT
          • dokhoD
            dokhoD
            dokho
            Hi !
            I've same problem to make a node with 2 DS18B20 and 2 DHT22.
            In domoticz the DS18B20 sensors are show with humidity value (of the 1st DHT22) and the 2nd DHT22 show the humidity value of the 1st one...
            The sketch i'm using is here: https://forum.mysensors.org/topic/5222/node-with-ds18b20-and-dht22
            (sorry for my bad english)
