  3. Changing Node Id of Serial Gateway
7 Posts 3 Posters 2.9k Views 3 Watching
  • LyubomyrL
    LyubomyrL
    Lyubomyr
    Hello.
    Can I change Node ID of the Serial gateway? I'm using Domoticz as a controller.
    I tried to change the code
    gw.begin(incomingMessage, 24, true, 0);
    // also tried gw.begin(incomingMessage, 24, true, 24);
    and changed each
    serial(PSTR("0;0;%d;0;%d; .........
    into
    serial(PSTR("24;0;%d;0;%d;.............
    // also tried cahnging into serial(PSTR("24;24;%d;0;%d;.............
    I made changes in the files SerialGateway and SerialGatewayUtil
    The node with sensor sees SerialGateway; Domoticz showes log "Serial gateway ready", but Domoticz does not see the sensor.
      No, you cannot. May I ask why?
      • LyubomyrL
        LyubomyrL
        Lyubomyr
        I suppose that this could increase security a little bit. Sorry to hear that this is impossible.
          How would it increase security?
          • LyubomyrL
            LyubomyrL
            Lyubomyr
            Well, if one wants to steal a signal, it would be more difficult to him to understand what is happening. It is some kind of Security through obscurity.
            On the other hand if something wants to pretend being a gateway, it would be more difficult to find out what node id does the node have.
            I understand that this not huge security upgrade but this can cause some difficulties for intruder.
              This thread might be of interest if you want to increase security: http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
              There is also a sniffer available to capture traffic (including node ids): https://www.mysensors.org/controller/sniffer
              • LyubomyrL
                LyubomyrL
                Lyubomyr
                I've seen the security link, but sniffer is very interesting indeed. Thank You!
