  3. Binary switch project
3 Posts 2 Posters 1.3k Views 2 Watching
  • mikeg291M
    mikeg291M
    mikeg291
    I cannot figure out how to correct the errors that I am getting. on this project. I need help
    #include <Bounce2.h>
    #include <Time.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    int alarmtime = 15;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    time_t  lastSwitchTime = 0;
    void receiveTime(unsigned long controllerTime);
    bool timeReceived = false;
      gw.begin();
      // Serial.begin(9600);
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
       gw.present(CHILD_ID, S_DOOR);
      // Make sure we get the system time, repeat request every 5 seconds until we have a valid time
      gw.requestTime(receiveTime);
      unsigned long lastRequest = millis();
      if ((millis() - lastRequest) >  5000) {
          gw.wait(100);
       lastSwitchTime = now();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         Serial.print("Switch was ");
         Serial.print(oldValue ? "ON" : "OFF");
         Serial.print(" for: ");
         Serial.print(now() - lastSwitchTime);
         Serial.println(" seconds");
         // Send in the new value
        if (value < == alarmtime );
         gw.send(msg.set(value==HIGH 1));
         else
         gw.send(msg.set(value=LOW 0));
         oldValue = value;
    // This is called when a new time value was received
    void receiveTime(unsigned long controllerTime) {
       // OK, set incoming time
       Serial.print(F("Time value received: "));
       Serial.println(controllerTime);
       setTime(controllerTime);
       timeReceived = true;
    Arduino: 1.6.7 (Windows 7), Board: "Arduino Nano, ATmega328"
    C:\Users\repair\Documents\Arduino\pump_cycle_time_2.5\pump_cycle_time_2.5.ino: In function 'void loop()':
    pump_cycle_time_2.5:66: error: expected primary-expression before '==' token
    pump_cycle_time_2.5:67: error: expected ')' before numeric constant
    pump_cycle_time_2.5:68: error: expected '}' before 'else'
      else
    pump_cycle_time_2.5:69: error: expected ')' before numeric constant
    C:\Users\repair\Documents\Arduino\pump_cycle_time_2.5\pump_cycle_time_2.5.ino: At global scope:
    pump_cycle_time_2.5:73: error: expected declaration before '}' token
      else
    exit status 1
    exit status 1
    • mikeg291M mikeg291
      #include <Time.h>
      #define CHILD_ID 3
      int alarmtime = 15;
      int oldValue=-1;
        gw.begin();
       // Setup the button
            gw.wait(100);
        debouncer.update();
           else
           oldValue = value;
        else
        else
      exit status 1
      exit status 1
      Some things that should help:
      1. Press ctrl/cmd+T in the Arduino IDE. That will auto-format the code which will make it much easier to spot mistakes.
      2. In the forum, code is marked with three backticks, not [code]. I know it's a bit non-intuitive but it is just the way the forum is. I took the liberty to changre your [code] to backticks to make the post to make it more readable.
      3. Comparing if a value is smaller is done by <= in c/c++. But it looks like you are trying to compare the value (which is always 0 or 1) to 15. That seems a bit strange. Adding a comment explaining what you are trying to do should help others (and perhaps yourself on day) to figure out what you ate trying to accomplish.
      4. The code to run inside an if clause should be surrounded by { and }
      5. The if clause and the two gw.send can probably be replaced by a single
        gw.send(msg.set(value==HIGH?1:0));
      • mikeg291M
        mikeg291M
        mikeg291
        Sorry for the lack of clarity . I have used your tips to and update the sketch to no avail . What I am trying to do is use the switch to activate the time and use the time the switch was activated ( lastSwitchTime ) to compare to the (alarmTime ) and send the new (value ). ? . Once I resolve the current issues : I haven't gotten to it yet but , Once the alarmTime alarm is met I would like to have locked in requiring a reset are possible button push to clear it .
        [code]
        #include <Time.h>
        #define CHILD_ID 3
        int alarmTime = 15;
        int oldValue = -1;
        gw.begin();
        // Setup the button
        pinMode(BUTTON_PIN, INPUT);
        digitalWrite(BUTTON_PIN, HIGH);
        gw.wait(100);
        debouncer.update();
        if (alarmTime <= lastSwitchTime );
        { gw.send(msg.set(value == HIGH 1));}
        else
        { gw.send(msg.set(value = LOW 0));
        oldValue = value;
        C:\Users\repair\AppData\Local\Temp\arduino_9fa690567122ca1856b95eff67fbf9b8\pump_cycle_time_2.5.ino: In function 'void loop()':
         else
        exit status 1
        enabled in File > Preferences.
        [/code]
