  3. serial monitor
serial monitor
stbcsg0pt0
3 Posts 3 Posters 980 Views 2 Watching
  • aaronik19A
    aaronik19A
    aaronik19
    Dear All,
    I am new to MySensors and I tried my first project. On the serial MOnitor on Arduino, the controller is sending the following code find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    What does this means?
    My code is very basic to try the program:
    #define ID 0
    #define OPEN 1
    #define CLOSE 0
    MyMessage msg(ID, V_TRIPPED);
      gw.begin();
      gw.present(ID, S_DOOR);
      gw.send(msg.set(OPEN));
      delay(5000);
    Thanks for your help
    • TheoLT
      TheoLT
      TheoL
      I believe it's just saying, that the node is looking for a good way. There are some posts on this topic that explain it. If you're really curious the API contains a lot of details.
      • sundberg84S
        Hi!
        Find parent means the node is trying to find its way to the gateway - and if this repeats it cant.
        Its either a range issue or a power issue. You can start by checking the gateway serial log and see if there is any info.
        Also, have you added a capacitor on the radios? This is very important since the radio is sensitive to power spikes.
        It this doesnt work start with changing the power source and check your wirings / ground connection on the node.
        Also you can try to move the node closer to the gateway - if this works and you have some distance between node and gateway you should consider a repeater.
