  3. ๐Ÿ’ฌ MyMultisensors
๐Ÿ’ฌ MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 92.2k Views 35 Watching
  • particleP
    particleP
    particle
    Thanks, and is it OK if I buy 16V for the passive too ?
    Like this one http://www.conrad.fr/ce/fr/product/457889/Condensateur-cramique-CMS-0603-Kemet-C0603C104K4RAC-01-F-16-V-10-X7R-1-pcs?ref=searchDetail for the 100nF for instance.
    • Nca78N
      Nca78N
      Yes it's OK to buy 16V. And it should be a rule to buy x7r, so you should be good with those.
      But for big values capacitors (used as power reserve), try to take as low voltage as possible on your circuit as leakage is proportionnal to rated voltage.
      • particleP
        particleP
        particle
        wrote on last edited by particle
        #63
        Thank you so much, so I will buy 16V for 1u capacitor or more, and 6.3V for others.
        And is there a rule for active ? (Watts, volts, amps...)
        Nca78N 1 Reply Last reply
        • particleP particle
          Nca78N
          Nca78N
          No, it's the opposite :D
          The higher the voltage rating, the more leakage/losses you will have. It's not important for small capacitors, but for reserve capacitors like 100ยตF it's better to take as low as possible, basically 2x the voltage used on your board.
          Honestly it's not a big issue if you use 16V instead of 6V, but with a board as optimized for battery life as this one, it would be sad not to optimize the capacitors also ;)
          • particleP
            particleP
            particle
            OK understood, it's clear now ! :-)
            And yes with the optimization work, I would like to pay tribute to him!
            • scalzS
              scalzS
              wrote on last edited by scalz
              #66
              Hey!
              Sorry for being so late, too much pending projects :)
              but here is how looks the custom box for my project. I need to polish a few things, especially sort of mounting plate, then i'll release my stl.
              Box is 62x29x 11.6mm
              No nails no screws.
              i don't like to search my screwdriver or needing screws, or a shorting circuit screw.. So when i can i prefer snaps!
              And in real
              See you soon!
              tonnerre33T 1 Reply Last reply
              • scalzS scalz
                Hey!
                No nails no screws.
                And in real
                See you soon!
                tonnerre33T
                tonnerre33T
                tonnerre33
                @scalz Very good work dude ! What about de V2 ? because i want to build this awesome node but i have read somewhere, you are working on the V2 ;)
                • scalzS
                  scalzS
                  #68
                  oki.
                  v2 won't be released soon (not this month sure) because i miss time, also it's not mysensors compatible yet. and not rfm69 too ;)
                  • scalzS scalz
                    oki.
                    tonnerre33T
                    tonnerre33T
                    tonnerre33
                    @scalz Oki. And for the nrf24 version ? :)
                    • KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      #70
                      Unfortunately this circuit and pcb contain a little mistake in reverse polarity protection module. Q1 must be connected as on the following diagram
                      reverse polarity
                      So just reverse connections of drain and source of Q1, and the next version of your board will contain correct reverse polarity protection :wink:
                      PS
                      Otherwise your circuit will be powered through mosfet body diode (with a drop to ~0.6V of course) when polarity is crossed. :anguished:
                      • scalzS
                        scalzS
                        #71
                        @Koresh thx for feedback :+1: Files are now updated and added a note
                        @tonnerre33 sorry for late reply. yes this will be nrf24 compatible, not rfm69. i'll try to show something soon, time does not help me!
                        • scalzS scalz
                          tonnerre33T
                          tonnerre33T
                          tonnerre33
                          @scalz nrf24 for the V1 or V2? Because if V2 isn't mysensors compatible, i prefer use V1 but in nrf24 version ;)
                          • YeitsoY
                            YeitsoY
                            Yeitso
                            So there is no option yet to order complete boards with components in place from manufacturarer? Or am i not getting openhardware correct. Order 10 PCBs will just get me the pcb right?
                            • YeitsoY Yeitso
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              @Yeitso you are right, 10pcbs order will just give you the pcb ;)
                              • tonnerre33T
                                tonnerre33T
                                tonnerre33
                                I'm finalizing the nrf24 version because it's a nice board, that would be too bad for nrf24 user
                                Did you finish the nrf24 version @scalz ?
                                • scalzS
                                  scalzS
                                  #76
                                  @tonnerre33 sorry for delay. yep, sure i finished it a while (rev 1.1 nrf), never ordered it, i use rfm for this node. but i'll upload this week oki
                                  • scalzS scalz
                                    tonnerre33T
                                    tonnerre33T
                                    tonnerre33
                                    @scalz Thx a lot ! I tried to replace the transmitter myself but the routing is too hard for me.
                                    I'll try to check the schema before order the board ;)
                                    • B
                                      B
                                      Bigbug
                                      This looks like an awesome unit! Is there a way to buy this with components assembled? Looks like a lot of work to solder all those smds..
                                      • P
                                        P
                                        pointbre
                                        I also wish I could buy assembled ones.
                                        tomtasticT 1 Reply Last reply
                                        • P pointbre
                                          tomtasticT
                                          tomtasticT
                                          tomtastic
                                          Likewise, to be able to buy assembled would be great
                                          With your input, this post could be even better ๐Ÿ’—
