  3. Inclusion mode not reliably starting
2 Posts 1 Posters 892 Views 1 Watching
  • signal15S
    signal15S
    signal15
    I built the ESP8266 wifi gateway and connected it to my Vera. Communication is working fine between them, but the gateway will only intermittently go into inclusion mode. When I click the Start button in Vera, I can see the data being sent to the gateway to start inclusion mode, both in the Vera logs, and in the serial console:
    Client 0: 0;0;3;0;5;1
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    Client 0: 255;255;3;0;4;58
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=2,sg=0,st=bc:58
    Sometimes it will go into inclusion mode. But, when it doesn't, I have to reboot the gateway and try again. Sometimes inclusion mode will continue to work for 3 or 4 more tries, or, it will not and I will have to reboot to get it working again.
    Any thoughts? I've tried 2 different radios. One of the normal tiny ones, and then the version of it with the SMA connector and antenna on it. Same results with both.
    • signal15S
      signal15S
      signal15
      Seems to be fixed. I cleared the EEPROM and reloaded the firmware.
