  3. Voltage Follower Help Needed
1 Posts 1 Posters 864 Views 1 Watching
  • S
    Samuel235
    Does anyone have any experience regarding voltage followers?
    I'm looking at implementing a voltage follower into my Electrochemical Sensor circuit for Carbon Monoxide and to remove any electronical noise that could influence the sensor (which its very sensitive too) they recommend i add in a voltage follower before the sensor output gets to the OP AMP to the MCU.
    Page 6 of the datasheet shows the voltage follower circuit proposed, but my current circuit is using a non-inverting setup where the proposed schematic (shown below) is using an inverting method. I know that the voltage follower is a non-inverting OP AMP itself, and i know how it works by utilizing the fact no current can flow through a OP AMP, however i just do not know/understand how to use this in my current setup.
    How would you go about implementing the voltage follower into my current circuit? Is it even possible to have a voltage follower on a non-inverting setup?
    Voltage Follower Circuit
    My circuit
    MySensors 2.1.1
