  3. Relay Node: radio init failure
11 Posts 3 Posters 3.9k Views 3 Watching
  • martrwM
    martrwM
    martrw
    I have two modules:
    1. Ethernet Gateway w/Clone Nano, W5100 and NRF24L01+
      Flashing this module with EthernetGateway.ino and opening serial debug I get this:
    Finished
    0;0;3;0;2;0;0;3;0;2;1.5.4
    Finished
    0;0;3;0;2;Get Version0;0;3;0;2;1.5.4
    Finished
    0;0;3;0;18;PINGFinished
    Which I think means everything is working and the PING is a response to Domoticz request for setup.
    1. Relay Module w/Clone Mini Pro, NRF24L01+ and 5/3.3 voltage regulator
      Flashing the module with RelayActuator.ino and stating Serial monitor I get:
    radio init fail
    So, after two days of checking power, wiring, re-flowing solder, changing radios and researching issues, I decide to flash the Relay Module with EthernetGateway.ino, since I can't think of anything else to do. Rearranging radio wiring for the EthernetGateway(since it is different) and using the EXACT SAME HARDWARE, I flash it with EthernetGateway.ino and get this:
    Which I think means the radio is working.
    I then reflash the EXACT SAME HARDWARE using the EthernetGateway radio wiring with the RelayActuator.ino and I get this:
    radio init fail
    Which I expected. All hardware was prototyped and verified to work with Domoticz before soldering onto PCB. Only change was to the Ethernet Gateway Nano which lasted about 3 seconds on the 12V power I had planned to run it with.
    Ideas?
    AWIA 1 Reply Last reply
    • martrwM martrw
      I have two modules:
      Finished
      Finished
      Finished
      radio init fail
      radio init fail
      Ideas?
      AWIA
      AWIA
      AWI
      @martrw can you post a photo / schematic?
      • martrwM
        martrwM
        martrw
        This post is deleted!
        • martrwM
          martrwM
          martrw
          Please instruct on method for uploading images. Please be specific as I can find no instructions.
          • martrwM
            martrwM
            martrw
            I am working this problem from the prototype board since the relay components are now soldered in and mounted in a case. The same issue exists with each set of components... i.e. soldered in and prototype have the same serial debut outputs.
            This is the prototype. I have replaced the leads according to the color coding at https://www.mysensors.org/build/connect_radio for trace-ability. I confirmed that the serial debug responses are the same after the rewire. The cap on the radio power is 10uF, this is all I have. I have also tried 68uF with the same results. Recommendations for the size of this component vary by 4 orders of magnitude across MySensors forum. In my uneducated opinion, cap should not matter for initialization.
            ![0_1463758331864_prototype.jpg](Uploading 100%)
            Closeup of the Mini wired for the RelayActuator.ino.
            Closeup of the radio connections:
            ![0_1463758502884_radio.jpg](Uploading 100%)
            Serial Debug output of this configuration:radio init fail
            Mini rewired for EthernetGateway.ino
            Enable soft_spi in myconfig.h and flash the Mini with EthernetGateway.ino, this is the Serial Debug output:
            Same hardware... same wires... same power supply... different software and wiring for software.
            • martrwM
              martrwM
              martrw
              wrote on last edited by martrw
              Radio wiring photo crapped out:
              ![0_1463759286823_radio.jpg](Uploading 100%)
              I get 405 Error Not Allowed each time I try to upload this image.
              Update:18:30hrs
              GettingStarted.ino from this site https://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo runs the radio just fine utilizing the arduino pin hookup TMRh20 RF24 Library. This is looking like a software issue or a pin out error.
              • martrwM
                martrwM
                martrw
                Is there anyone still in here or should I just turn out the lights when I leave?
                • martrwM martrw
                  Update:18:30hrs
                  AWIA
                  AWIA
                  AWI
                  @martrw still hard to tell from the pictures. If you wire the radio correct (and have a working radio) it should work.
                  I always upload pictures by taking a screenshot and just copy paste (ctrl v) it on the posting.
                  • NuubiN
                    NuubiN
                    Nuubi
                    You could try connecting all the ground pins of the Arduino together -- this helped me with one clone board.
                    • martrwM
                      martrwM
                      martrw
                      I have 10 radios. Two were prototyped to verify and then soldered into enclosures. Three days ago I could not sleep and decided to work on this issue for a bit. Going over the same steps I have gone over multiple times, suddenly, miraculously, the communications started to work. For 15 glorious minutes I clicked an icon on the computer and the relay operated. Then the clock struck midnight and they turned back into pumpkins! I am not making any of this up.
                      Of the remaining 8 radios and 4 or 5 arduinos I have used every software library I can find to try to figure this out. None are diagnostic. Each presumes that the radios, arduinos and stars align and they just work OoB. GettingStarted seems to be the most universally used for radio validation. Using this code and the wiring recommended for it, I can get none of the 8 radios to get past these lines of code:
                      unsigned long start_time = micros(); // Take the time, and send it. This will block until complete
                      if (!radio.write( &start_time, sizeof(unsigned long) )){
                      Serial.println(F("failed"));
                      This means to me that none of the radio's and/or none of the arduino's and/or none of the power configurations work.
                      Respectfully, if this is a wiring issue, then you can tie me up and paint me blue! I will be blue-fully happy to have finally been shown the truth.
                      • martrwM martrw
                        AWIA
                        AWIA
                        AWI
                        @martrw You sound pretty hopeless... and not even getting past the first step. Have you measured voltages etc. to make sure the radio gets its juice (and not more than 3.5V)? You can test your arduino with a "blink" sketch on all the relevant pins. If all correct I can't think of anything else that a very bad batch of radio's.
