  3. RealTimeClockDisplaySensor.ino
13 Posts 5 Posters 5.6k Views 2 Watching
  • HoffanH
    HoffanH
    Hoffan
    Have try this sketch. But i can't compile it.
    Have even try the online way
    • daulagariD
      daulagariD
      daulagari
      A bit too less information to help...
      Can you post the errors you get and where you did get the source from?
      • HoffanH
        HoffanH
        Hoffan
        You don't get any Errorcode when you use codebender
          I saw the 500-error when trying to run-and-clone mysensors libraries this morning. It was reported to the codebender team and I'm waiting for reply.
            Got a message from Mr Vasilis over at CodeBender. This should be fixed now.
            • HoffanH
              HoffanH
              Hoffan
              I still get compiling Error when i try this with codebender
                Works fine for me.
                Do you select "Clone sketch and libraries"?
                http://www.mysensors.org/build/display
                • O
                  O
                  osalval
                  Hi, not compiling for mi either:
                  Arduino: 1.5.8 (Windows 8), Board:"Arduino Nano, ATmega328"
                  Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                  Using library MySensors in folder: C:\Program Files (x86)\Arduino\libraries\MySensors (legacy)
                  Using library Time in folder: C:\Program Files (x86)\Arduino\libraries\Time (legacy)
                  Using library DS3232RTC in folder: C:\Program Files (x86)\Arduino\libraries\DS3232RTC (legacy)
                  Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
                  Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal (legacy)
                  C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=158 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I
                  C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -I
                  C:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs -I
                  C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -I
                  C:\Program Files (x86)\Arduino\libraries\MySensors -I
                  C:\Program Files (x86)\Arduino\libraries\Time -I
                  C:\Program Files (x86)\Arduino\libraries\DS3232RTC -I
                  C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -I
                  C:\Users\Oscar\AppData\Local\Temp\build6354959487290696935.tmp\MySensors_RealTimeClockDisplaySensor.cpp -o C:\Users\Oscar\AppData\Local\Temp\build6354959487290696935.tmp\MySensors_RealTimeClockDisplaySensor.cpp.o
                  In file included from C:\Program Files (x86)\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:35:0, from MySensors_RealTimeClockDisplaySensor.ino:21:
                  C:\Program Files (x86)\Arduino\libraries\LiquidCrystal/LCD.h:421:44: error: 'prog_uchar' does not name a type
                  void createChar(uint8_t location, const prog_uchar charmap[]);
                  C:\Program Files (x86)\Arduino\libraries\LiquidCrystal/LCD.h:421:63: error: ISO C++ forbids declaration of 'charmap' with no type [-fpermissive]
                  Error de compilación
                  O 1 Reply Last reply
                  • O osalval
                    O
                    O
                    osalval
                    @osalval
                    Hi, after reinstall IDE 1.0.6, it compile OK, but now liquid display don't show nothing.
                    Monitor shows:
                    sensor started, id 20
                    send: 20-20-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                    send: 20-20-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                    read: 0-0-20 s=255,c=3,t=6,pt=0,l=1:M
                    send: 20-20-0-0 s=255,c=3,t=11,pt=0,l=9,st=ok:RTC Clock
                    send: 20-20-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                    send: 20-20-0-0 s=255,c=3,t=1,pt=0,l=3,st=ok:1.0
                    requesting time
                    requesting time
                    requesting time
                    requesting time
                    requesting time
                    • O osalval
                      @osalval
                      Monitor shows:
                      requesting time
                      requesting time
                      requesting time
                      requesting time
                      requesting time
                      O
                      O
                      osalval
                      wrote on last edited by osalval
                      @osalval
                      Solved, it was the contrast adjustable resistor of IIC interface, its very critical, now its working fine.
                      No so fine it doesn't fetch the time from controller
                      • O osalval
                        @osalval
                        O
                        O
                        osalval
                        @osalval
                        By the way I find, THE ONLY one library: LiquidCrystal, that Works with Arduino V1.5.8:
                        https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
                        LiquidCrystal_V1.2.1.zip
                        https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads/LiquidCrystal_V1.2.1.zip
                        I still can not fetching time from controller. What i shoul do with openHAB and MQTTGateway?
                        • J
                          J
                          Jackpot
                          "I still can not fetching time from controller"
                          I replaced ;
                          if ((!timeReceived && now-lastRequest > 101000)
                          || (timeReceived && now-lastRequest > 60
                          1000*60)) {
                          with;
                          if ((!timeReceived && now-lastRequest > 10*1000)
                          || (timeReceived && now-lastRequest > 3600000ul)) {
                          It started fetching time from the controller after that. I'm just using the TimeAwareSensor.ino sketch and an ethernet gateway.
                          Maybe this will help...........
                          • J Jackpot
                            I replaced ;
                            1000*60)) {
                            with;
                            O
                            O
                            osalval
                            Thank you @Jackpot
                            Don´t Works for mi. As somebody told, I think is the MQTT Gateway that no respond to requestTime.
                            I`m not software men but I think the sketch is correct and MQTT Gateway should answer wirt the value in "receiveTime"
