  3. Node to Node
Node to Node
point to pointpingpongnodes
2 Posts 2 Posters 1.3k Views 3 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    I have some electronics in my car (yep, im that guy) and I am looking to put some control buttons in my sunglasses holder on the ceiling. I obviously do not want to try to get wiring through the ceiling of my fairly new car so I was thinking of using RF to do the controlling. I was wondering if something like this is possible on node->node interaction. I know the pingpong sketch does that, but I have also seen there is some talk of having to be near a gateway at some point.
    If i setup everything up once, do I need to get the nodes back to the gateway? will it cause any problems with those nodes being isolated to each other down the road?
    I know I could code this directly, but I like the idea of being able to use something that has already had alot of thought for retries and what not put in to it.
    Thanks!
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    F 1 Reply Last reply
    • CrankyCoderC CrankyCoder
      Thanks!
      F
      F
      flopp
      @Jason-Brunk
      I am not sure but maybe you can use incoming message to listen to the NRF network.
      Read more about how to use incoming message here
      https://forum.mysensors.org/topic/4195/how-to-find-out-if-message-was-successfully-delivered
