  3. Home Assistant
  4. Problem with IP camera Foscam FI8910W - IP Camera(Error loading image)
3 Posts 2 Posters 2.9k Views 2 Watching
  • Maurizio ColluM
    Maurizio ColluM
    Maurizio Collu
    Dear all, I bought a Foscam FI8910W IP camera, and I followed the instruction provided here to add it to my Home Assistant system:
    https://home-assistant.io/components/camera.foscam/
    I can see the "camera.ip_camera" entity now among currrent entities, and I added it to the home Screen.
    Anyway, I cannot see anything and instead I only have a window saying: "IP Camera(Error loading image)"
    I must specify that if with my browser I go to the same ip, I can see the camera OK, no problem, as I already set it up with the FOSCAM software.
    Does anyone else had the same problem / solved it?
    • Maurizio ColluM Maurizio Collu
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Maurizio-Collu
      Hi!
      I think you will probably find better help in the home assistant forum than here, as this topic is not mysensors related.
      community.home-assistant.io
      It's also a great and friendly community, so I'll bet you'll find some advice soon.
      • Maurizio ColluM
        Maurizio ColluM
        Maurizio Collu
        Thanks, I'll try.
        Maurizio
