  3. How to determine from which Node a message is comming from
3 Posts 2 Posters 1.4k Views 3 Watching
  • TheoLT
    TheoLT
    TheoL
    First of all, not sure whether this is the right topic for my question, so if not I apologize.
    I've been experimenting with node to node communication inspired by @GertSanders his presentation during the Dutch MySensors meetup. I haven't discovered this feature of MySensors before, but it's brilliant.
    I can communicate from one sensor to another without the interference of any controller. Love it! It opens new possibilities, and probably keep me awake for a couple of nights ;-)
    So I'd like to know, if there's a way to determine the sender of a message in the incomming message handler. I do see a setDestination() method but - at least in 1.5 - there's no getter and it seems like MySensors ignores that. For my use case it would be great if I can determine what the id is of the node of which the message is originating from.
    I also tried to create a message with the default constructor like this:
      MyMessage myMsg();
      myMsg.setDestination( aNodeId );
    but that results into the following compile error:
    error: request for member 'setDestination' in 'myMsg', which is of non-class type 'MyMessage()'
    I can get around that easily, so I think I misunderstood the API documentation for that.
    void sendMessage( uint8_t aNodeId, char *aMsg ) {
      MyMessage myMsg( 255, V_VAR1 );
      myMsg.set( aMsg );
      gw.send( myMsg, true );
    • TheoLT TheoL
        MyMessage myMsg();
        myMsg.set( aMsg );
      @TheoL this code:
        LOG(F("Received %s from %s\n"), msgTypeAsCharRepresentation((mysensor_data)message.type), nodeTypeAsCharRepresentation(message.sender));
        delay(250);
        sendPingOrPongResponse( message );
      from the PingPong example suggests that the sender is available.
      Is that a solution to your problem or did I not quite understand your question?
      TheoLT 1 Reply Last reply
        @TheoL this code:
          delay(250);
        TheoLT
        TheoLT
        TheoL
        @mfalkvidd Thanx for the quick reply and the example. It's exactly what I was I was looking for. I just overlooked the union definition in Message.h.
        I'm currently sending the message to the Node itself as a test. But event that that works.
