  3. Arduino Pro mini 3,3V + NRF24L01+: Can i change Pins?
3 Posts 2 Posters 1.3k Views 2 Watching
  • vgaV
    vgaV
    vga
    Hi together,
    just have a simple question:
    is it possible to change the Pins to connect the NRF24L01+ to my Arduino Pro Mini 3,3V, or is there maybe a special function on the configured Pins, so only these Pins are usable?
    Thanks and best regards!
      The pins are special, since they support hardware SPI. SPI is a bus to which several devices can be connected at the same time.
      The pins can be changed if software SPI is used instead of hardware SPI. See https://github.com/mysensors/MySensors/blob/3519558703d6c21c8046da38462c7167ba28a9ed/examples/GatewayW5100/GatewayW5100.ino#L57 for an example of how it can be done and https://www.mysensors.org/build/ethernet_gateway#wiring-things-up for a wiring diagram.
      Could you share the reason you want to change the pins?
      • vgaV
        vgaV
        vga
        ah, thanks mfalkvidd, thats what i´m looking for!
