  3. gw send, how to do in my combination of sensors
9 Posts 4 Posters 2.9k Views 4 Watching
  • DickD
    DickD
    Dick
    In my project in development, I miss the GW send for my motion detector. I tried several options but nothing works. Anyone an idea, how to?
    #include "Bounce2.h"
    #define USE_MOTION_SENSOR
    #define MOTION_SENSOR_PIN    3          //physical number of PIR
    #define LIGHT_SENSOR_ANALOG_PIN A0      //physical number of LDR
    #define CHILD_ID_LIGHT 6
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    Bounce motionsDebouncer = Bounce();
    #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
    #define noRelays 5                     //number of relais in use
    const int relayPin[] = {A1, A2, A3, A4, A5}; //  switch around pins to your desire number of relais
    const int buttonPin[] = {4, 5, 6, 7, 8   }; //  switch around pins to your desire number of buttons
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                    // physical pin number of button
      int relayPin;                     // physical pin number of relay
      byte oldValue;                    // last Values for key (debounce)
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msgRelay[noRelays];
    MyMessage msgLDR(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    int lastLightLevel;
    unsigned long SLEEP_TIME = 6000; // Sleep time between reads (in milliseconds)
      gw.begin(incomingMessage, RADIO_ID, true);
      delay(250);
      gw.sendSketchInfo("Multy-Relay&button-PIR&LDR", "0.2");
      delay(250);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      pinMode( MOTION_SENSOR_PIN, INPUT_PULLUP );
      motionsDebouncer.attach(MOTION_SENSOR_PIN);
      motionsDebouncer.interval(50);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++)
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msgRelay[i].sensor = i;                                   // initialize messages
        msgRelay[i].type = V_LIGHT;
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(5);
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        gw.send(msgRelay[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        gw.present(i, S_LIGHT);                               // present sensor to gateway
        delay(250);
      if ( motionsDebouncer.update()) {
        int value = motionsDebouncer.read();
        Serial.println( "PIR " + (String)value );
      gw.process();
      for (byte i = 0; i < noRelays; i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        if (value != Relays[i].oldValue && value == 0)
          gw.saveState( i, Relays[i].relayState );
        }                 // save sensor state in EEPROM (location == sensor number)
        Relays[i].oldValue = value;
       int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      //Serial.println(LDR);
     if ((lightLevel > 1.05 * lastLightLevel)||(lightLevel < 0.95 * lastLightLevel))    //5% difference will send
           gw.send(msgLDR.set(lightLevel));
          lastLightLevel = lightLevel;
          Serial.print("LDR");
          Serial.println(lightLevel);
    // process incoming message
      if (message.type == V_LIGHT)
        if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
     // delay( 50 ); // give the input pins some rest. Incomming messages are still being processed.
    gw.wait(50);
    sinczeS 1 Reply Last reply
    • DickD Dick
      #define RELAY_OFF 1
      public:
      int lastLightLevel;
        delay(250);
        delay(250);
          delay(250);
        gw.process();
      gw.wait(50);
      sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      @Dick I assume you are working on a version < 2.0.0. if I look at your sketch??
      • DickD
        DickD
        Dick
        wrote on last edited by Dick
        not yet, stil working with the 1.54. in the IDE serial it works all fine but the motion sensor is not visible in DOMOTICZ and probably because I do not send to GW but I am new in this area so support is welcome.
        • DickD Dick
          @Dick have you looked at the motion example? https://www.mysensors.org/build/motion
          DickD 1 Reply Last reply
            DickD
            DickD
            Dick
            @mfalkvidd
            Yes I did bud than I do not understand what I have now,
                Serial.println( "PIR " + (String)value );```
            only a GW send row needed or is that not right?
            What I saw on the https://www.mysensors.org/build/motion
            was clear but after implementation I got several errors during the compilation so I thought, perhaps only something with GW.send
            Or am I wrong?
            TheoLT 1 Reply Last reply
            • DickD Dick
              @mfalkvidd
              Or am I wrong?
              TheoLT
              TheoLT
              TheoL
              @Dick added some comments in the code. And made some changes. It compiles. But I can't test it for you..
              #define RELAY_OFF 1
              // <-- byTheo since you don't have any methods in your class, a simple C struct made be
              //                    more resource friendly
                public:
              #define MOTION_CHILD_ID 8 // <-- byTheo
              MyMessage motionMsg( MOTION_CHILD_ID, V_TRIPPED ); // <-- byTheo
              int lastLightLevel;
                //  delay(250); // <-- byTheo
                gw.wait( 250 ); // <-- byTheo
                motionsDebouncer.attach(MOTION_SENSOR_PIN); // <---- byTheo I believe PIR sensors don't need debouncing
                motionsDebouncer.interval(50); // <---- byTheo I believe PIR sensors don't need debouncing
                gw.present( MOTION_CHILD_ID, S_MOTION, "Motion needs presentation", true ); // byTheo
                  gw.send( motionMsg.set( value ), true ); // <-- byTheo : Also it might need inverted value
                //  { <--- byTheo
                gw.process();
                int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
                if ((lightLevel > 1.05 * lastLightLevel) || (lightLevel < 0.95 * lastLightLevel))  //5% difference will send
                // } // <---- byTheo
              //  gw.wait(50); // <-- byTheo don't use delays in message handler. Message handler needs the shortest execution time is possible
              • TheoLT TheoL
                #define RELAY_OFF 1
                  public:
                int lastLightLevel;
                  //  { <--- byTheo
                  gw.process();
                DickD
                DickD
                Dick
                @TheoL
                Hi Theo, the devil is playing with me, my PI stopped working and that is my Domoticz location. I read your commend, thank you for that, I am probably not able to test it this evening.
                sorry for that> I inform you about the results.
                • DickD Dick
                  @TheoL
                  TheoLT
                  TheoLT
                  TheoL
                  Hello @Dick,
                  Don't be sorry. Just let me know if this is what you wanted after you've tested it.
                  • TheoLT TheoL
                    Hello @Dick,
                    DickD
                    DickD
                    Dick
                    @TheoL My Domoticz works again, I have to give it a fix ip because the IP was change and for your info, Your solution worked very well. It is now visible in Domoticz. Thanks for the support now I have to wait for other parts, I wait for my last parts for this project, an IR receiver so I can use a remote controle. After that I can use this project as a universal project, a default design in basic.
                    Again thanks!
