  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.0k Views 53 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    wrote on last edited by tonnerre33
    #21
    analogRead(BATTERY_SENSE_PIN);
    must give you 1023 and not 330.
    For me it's a problem of value resistance or analogReference.
    Try to add this
    analogReference(INTERNAL);
    sensorValue = analogRead(BATTERY_SENSE_PIN);
      #ifdef MY_DEBUG
     Serial.print("Value A0 before force reference: ");
     Serial.print(sensorValue);
    delay(10000);
      #ifdef MY_DEBUG
     Serial.print("Value A0 after force reference: ");
    Just after this existing code :
       #ifdef MY_DEBUG
       Serial.println(sensorValue);
    And plz send me the logs of the node ;)
    bjacobtB 1 Reply Last reply
    • tonnerre33T tonnerre33
      Try to add this
        #ifdef MY_DEBUG
      delay(10000);
        #ifdef MY_DEBUG
         #ifdef MY_DEBUG
      bjacobtB
      bjacobtB
      bjacobt
      @tonnerre33 Its still the same
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=101)
      TSM:FPAR
      TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:PAR OK (ID=0, dist=1)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=101)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
      TSP:MSG:PONG RECV (hops=1)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
      TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
      Request registration...
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=101, parent=0, distance=1, registration=1
      330
      Value A0 before force reference: 327
      Value A0 after force reference: 329
      Battery Voltage: 1.11 V
      Battery percent: 32 %
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:32
       * This is an example that demonstrates how to report the battery level for a sensor
       * Instructions for measuring battery capacity on A0 are available here:
       * http://www.mysensors.org/build/battery
      #define MY_NODE_ID  101
      unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
      int oldBatteryPcnt = 0;
         analogReference(INTERNAL1V1);
      #else
      void presentation() {
         sendSketchInfo("Battery Meter", "1.0");
         // get the battery Voltage
         #ifdef MY_DEBUG
        #ifdef MY_DEBUG
      delay(10000);
        #ifdef MY_DEBUG
         #ifdef MY_DEBUG
         float batteryV  = sensorValue * 0.003363075;
         Serial.print(batteryV);
         Serial.println(" V");
         Serial.print(batteryPcnt);
         Serial.println(" %");
           // Power up radio after sleep
           oldBatteryPcnt = batteryPcnt;
         sleep(SLEEP_TIME);
      • tonnerre33T
        tonnerre33T
        tonnerre33
        #23
        Ok it's not a problem with the analogReference, you can delete this part of code.
        Did you control your resistance value and did you do this schema ?
        • bjacobtB
          bjacobtB
          bjacobt
          wrote on last edited by bjacobt
          #24
          I'm sorry what do you mean by "control your resistance value"
          this is my circuit,
          1M resistor to +V rail, 470K resistor to GND and middle point to A0.
          0_1478097209731_IMG_1543.JPG ,
          • tonnerre33T
            tonnerre33T
            tonnerre33
            Ok try to remove the jumper between V+ and AREF
              bjacobtB
              bjacobtB
              bjacobt
              @tonnerre33 That was it!
              I'm getting Battery Voltage: 3.10 V
              Battery percent: 92 %
              Thank you so much :)
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
              Node registration=1
              922
              Value A0 before force reference: 924
              Value A0 after force reference: 923
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:92
              • Meshx86M
                Meshx86M
                Meshx86
                can Li 18650 3.7 batteries be used as they are rechargeable ? knowing the max voltage at full might reach 4.1-4.2v ? maybe keeping the voltage regulator ?
                • Meshx86M Meshx86
                  @Meshx86 yes they can be used but as you've already identified the nrf (and maybe other components) will need to be protected from the high voltage when the battery is full.
                  The self-discharge rate of li-ion is higher than alkaline batteries which might affect how long the node can run before it needs charging.
                  • parachutesjP
                    parachutesjP
                    parachutesj
                    I just built the circuit which is explained in the thread with a Pro Mini 3.3 8 mHz
                    So far so good, I can read the voltage of the battery etc but my problem is, it consumes about 1.2 mA while in sleep, this is about factor 10 of the findings from the thread.
                    I just copied the code 1:1
                    Any glue what could be wrong or what get others with that setup? The Arduino is not modified at all.
                    SJ
                    N 1 Reply Last reply
                    • parachutesjP parachutesj
                      SJ
                      N
                      N
                      Nicklas Starkel
                      @parachutesj you have to modify the pro mini. Remove the power led according to instructions!
                      parachutesjP 1 Reply Last reply
                      • N Nicklas Starkel
                        parachutesjP
                        parachutesjP
                        parachutesj
                        @Nicklas-Starkel thank you. If one could read...
                        I read the description again and thought that it should be 120uA stock and when removing LED and regulator it will even go down further but thinking about it, how should at base 120 uA and removing LED save additional 1.5mA???? LOL, sorry was a long day.
                        My Fluke reads 0.044 mA in sleep now (without LED). Sweet!
                        • N
                          N
                          Nicklas Starkel
                          Another battery related question that I really do not understand.
                          Are there different versions on how to read battery consumption?
                          I see some sketches uses:
                          long readVcc() {
                            long result;
                            noInterrupts ();
                            // start the conversion
                            ADCSRA |= _BV (ADSC) | _BV (ADIE);
                            set_sleep_mode (SLEEP_MODE_ADC);    // sleep during sample
                            interrupts ();
                            sleep_mode ();
                            // reading should be done, but better make sure
                            // maybe the timer interrupt fired
                            while (bit_is_set(ADCSRA,ADSC));
                            result = ADCL;
                            result |= ADCH<<8;
                            result = 1126400L / result; // Back-calculate AVcc in mV```
                          However some (like the original one in this thread) uses:
                          Is it due to different libraries or maybe it is the same but just programming wise different?
                          • G
                            G
                            gloob
                            If you are using the first sketch you dont have to use a seperate pin to measure the input voltage. There are also no resistors.
                            You can run this on a bare ATmega with minimal hardware.
                            • G gloob
                              N
                              N
                              Nicklas Starkel
                              @gloob thanks!
                              One would think running with no resistors and not using a separate PIN would be better.
                              @hek or @mfalkvidd , any comments as to why the original sketch is preferred over the other 'way' in this article?
                              hekH 1 Reply Last reply
                              • N Nicklas Starkel
                                @gloob thanks!
                                @Nicklas-Starkel
                                https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
                                  @Nicklas-Starkel
                                  N
                                  N
                                  Nicklas Starkel
                                  @hek , I've read that post several times :)
                                  Since it was so outdated (2 years) I naturally assumed the 'battery powering article' was a newer way to do it (especially since mys2.0).
                                  Also, the post you linked to is attributed if you use no voltage regulator.
                                  And in the article this is also one of the things you are recommended to remove, hence making it even more confusing as to why the article describes another way than the post.
                                  • Meshx86M
                                    Meshx86M
                                    Meshx86
                                    wrote on last edited by Meshx86
                                    #37
                                    i just want to get this once and for all, so others coming by gets it directly instead of going through all the 2 threads posts, please correct me if i am wrong:
                                    1- using the voltage divider is needed if there is a voltage regulator / booster where where VBatt != Vcc.
                                    2- using the voltage regulator is not needed if the voltage regulator is removed / no booster is used (powering directly from 2 x AA batteries) where VBatt == Vcc.
                                    *I've noticed the 2nd method requires inputting battrie's DMM measured values vs arduino ones for correction, is this a down side if you need to change the battery later on ? or is it just programmed once ? and does the 1st method rquirs these corrections too ?
                                    Cheers
                                    • Meshx86M Meshx86
                                      Cheers
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @Meshx86
                                      actually, you need a voltage divider if the voltage to be measured is above the maximum allowed by the processor at the speed you are running it.
                                      If Vcc is 5V, then any voltage above 5V should be measured via a voltage divider.
                                      If Vcc is 3.3V same principle, but you could get away with measuring 5V directly (would not kill the processor), but your values may be off.
                                      Meshx86M 1 Reply Last reply
                                      • GertSandersG GertSanders
                                        @Meshx86
                                        Meshx86M
                                        Meshx86M
                                        Meshx86
                                        #39
                                        @GertSanders following the instructions of this post suggest using Alkaline batteries (apparently Li-ion aren't a good idea for sensor nodes ?! plus they are expensive), the optimal solution would be using 2 x AA batteries as some ans this post suggested.
                                        I believe there is no way 2 x AA batteries in series would measure anywhere near 3.3v, the max i measured with brand new batteries was 3.2v.
                                        my major concern is:
                                        would i still need to the do the voltage corrections when using the voltage divider ? if so, does that need to be reprogrammed every time you replace the battery ?
                                        sorry to bring this again @Yveaux @axillent
                                        • Meshx86M Meshx86
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @Meshx86
                                          No problem to ask. I use the intern measurement method, which uses the internal 1.1V reference of the atmega328, so even if the Vcc value changes from 3.2V -> 2.6V, the reference will always be 1.1V, and the internal method allows you to calculate the actual measured battery voltage based on a difference with the reference, even with a declining value on Vcc (if powered by the same batteries).
