  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    This post is deleted!
      This thread contains comments for the article "Building a WiFi Gateway using ESP8266" posted on MySensors.org.
      ramoncarranzaR
      ramoncarranzaR
      ramoncarranza
      @hek Hi, I am new to arduino but not to Vera, have been using Veralite for a few years, I wuould like to know how to add the Serial Gateway to Vera, I find it very confusing, it would be ideal if a video was created or step by step instructions for newbees like me, I will be more than happy to donate via paypal, Thanks so much
      reply
        @ramoncarranza
        What part is confusing? Did you follow the steps outlined here:
        https://www.mysensors.org/controller/vera
        ramoncarranzaR 1 Reply Last reply
          @ramoncarranza
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @hek I got it already, I was confused on the Vera Plugin vs the Arduino Plugin not realizing they were both the same, but now I get the following message on Vera
          "MySensors plugin : Choose the Serial Port"
          "MySensors Plugin[105] : Running Lua Startup"
          I have yet to assemble the Serial Gateway though, so I'm assuming the messages will go away once the Gateway is installed??????
            Yes, once you insert the usb gateway you just have to follow the instructions here:
            https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
            • ramoncarranzaR
              ramoncarranzaR
              ramoncarranza
              Thanks so much!!
              This thing's Amazing!!!!!!
              • sghazaghS
                sghazaghS
                sghazagh
                Hi all,
                I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
                Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpg
                And here is the error I get:
                TSM:INIT
                !TSM:RADIO:FAIL
                !TSM:FAILURE
                TSM:PDT
                thanks,
                • korttomaK
                  korttomaK
                  korttoma
                  If you are using the NRF24L01+ you should wire it according to the instructions here
                  And use the sketch from the same page.
                  So check your wiring of the radio module.
                  • Tomas
                  • sghazaghS
                    sghazaghS
                    sghazagh
                    I used the same link (pins and sketches!). Checked it 10 times!
                    I think my Radios are not functional....
                    korttomaK 1 Reply Last reply
                    • sghazaghS sghazagh
                      korttomaK
                      korttomaK
                      korttoma
                      @sghazagh maybe you can take a picture of the setup. Maybe someone else can see something that you don't.
                      • Tomas
                      • sghazaghS
                        sghazaghS
                        sghazagh
                        wrote on last edited by sghazagh
                        #31
                        Good idea,
                        Here is the side by side image from front and back of the PCB.
                        The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
                        However, I have rotated it by 180 degree and tried that as well. same result!
                        • sghazaghS
                          sghazaghS
                          sghazagh
                          Guys, just an update for my issue regarding Radio and my circuit.
                          The Radio was faulty, I received the new one, swapped it and all worked fine.
                          I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
                          The wiring all are correct.
                          • jakesJ
                            jakesJ
                            jakes
                            Hi Hek,
                            Thanks for this guide... I have added an additional 433 RF receiver to my ESP8266 gateway. How can I send the data received from 433 RF to the my Home Assistant controller?
                            • denisvdbD
                              denisvdbD
                              denisvdb
                              Hello, i have build a wifi gateway and use it in jeedom.
                              My gateway wifi as connection problem.
                              In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
                              If I restart the node the communication is re-established.
                              Is this a problem with nrf24l01?
                              • D
                                D
                                derrij
                                why esp8266 gateway shows only debug info?
                                when i comment //#define MY_DEBUG
                                where is no any serial output.
                                • D derrij
                                  @derrij because it is a wifi gateway?
                                  • A
                                    A
                                    AndreD
                                    If put in client mode
                                    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
                                    I get an error. How to win.
                                    Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
                                    "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
                                    In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                                 from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
                                    C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                                    C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
                                    C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                                     size_t left = source.available();
                                    C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                                     source.read(buffer.get(), will_send);
                                    Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
                                    Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
                                    Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
                                    Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
                                    exit status 1
                                    Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
                                    • Jonathan CaesJ
                                      Jonathan CaesJ
                                      Jonathan Caes
                                      Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
                                      • Jonathan CaesJ Jonathan Caes
                                        #39
                                        @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
                                        • J
                                          J
                                          joseyapor
                                          Hi how many Gateways Can i have on a network?
                                          With your input, this post could be even better πŸ’—
