  2. Announcements
  • alowhumA
    alowhumA
    alowhum
    I once noticed this too, on a pi zero system with domoticz beta.
    • O
      O
      otto001
      wrote on last edited by otto001
      #802
      @Nick-Willis:
      I do run the gateway in debug mode, but I could not see anything special.
      Yesterday the service was auto-restarted by my script:
      2018-02-27 13:31:03 high CPU-usage! --> restarting service```
      On the same time in the "normal" mysgw.log (debugging enabled) (should be syslog normally, but I changed the logfile location for better investigation):
      Feb 27 13:30:36 raspiez mysgw: TSF:MSG:READ,14-14-0,s=1,c=1,t=23,pt=7,l=5,sg=0:0.11
      Feb 27 13:30:36 raspiez mysgw: TSF:MSG:READ,14-14-0,s=3,c=1,t=0,pt=7,l=5,sg=0:21.9
      Feb 27 13:30:36 raspiez mysgw: TSF:MSG:READ,14-14-0,s=4,c=1,t=1,pt=7,l=5,sg=0:31.4
      Feb 27 13:30:38 raspiez mysgw: New connection from 192.168.1.11 <-- fhem re-connects
      Feb 27 13:30:38 raspiez mysgw: GWT:TSA:C=1,CONNECTED
      Feb 27 13:31:04 raspiez mysgw: Received SIGTERM <-- AUTO-Restart
      The only thing that is a little bit unusual is the re-connect of my controller (fhem) - but this happens every 30 minutes for stability reasons.
      This should not happen, but I can not find out what the problem is.
      Maybe you could also enable debugging by changing the following file (maybe we can find a pattern why this is happening):
      /etc/systemd/system/mysgw.service
      from
      ExecStart=/usr/local/bin/mysgw
      to
      ExecStart=/usr/local/bin/mysgw -d
      Please do not forget to issue a
      sudo systemctl daemon-reload
      followed by
      sudo systemctl restart mysgw.service
      to enable the change.
      My restarting-script might help until someone with better knowledge finds a solution...
      I also will have an eye on the logs for findig out how often this is happening...
      Cheers,
      Otto
      M 1 Reply Last reply
      • O otto001
        @Nick-Willis:
        from
        to
        followed by
        Cheers,
        Otto
        marceloaqno
        Code Contributor
        Please, could all of you who experienced this issue post the configuration options you used to build the gateway?
        This would help to investigate the problem.
        • O
          O
          otto001
          #804
          @marceloaqno : of course, thanks for the hint!
          I had the following configure:
          ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5004
          (The high CPU problem also occured before I connected PIN 15 to IRQ without the corresponding config option. I hoped to solve the Problem using IRQ, but this did not help. And I have a second GW with default port 5003 in my network. This is running an ancient version of Raspi GW Software and this is working fine -but slower). I am using current fhem as controller and I have it connecting every 30 minutes to the gateways due to stability issues in the past. There are only about 6 nodes (just motion, humidity & temp and lux) connected to this gateway.
          In addition to that I changed the default channel in MyConfig.h (because I have two different MySensor networks):
          #ifndef MY_RF24_CHANNEL
          #define MY_RF24_CHANNEL (82)
          I am pretty sure, that this is not important, but I also set up rsyslog to write gw logs to an own file instead of syslog....
          Maybe this helps.
          Cheers,
          Otto
          • O otto001
            Maybe this helps.
            Cheers,
            Otto
            marceloaqno
            Code Contributor
            @otto001 I think I found the problem. I wrote a fix for it:
            https://github.com/marceloaqno/MySensors/commit/ca8865d8e1fe1b08195943fae1640d5fddb81924
            • O
              O
              otto001
              #806
              @marceloaqno : Wow, you are fast! Thanks!
              Just applied the patch and recompiled. I will report in a couple of days while my monitoring-script is still running (and logging)...
              Cheers,
              Otto
              • M marceloaqno
                mvader
                @marceloaqno I am also recompiling and testing.
                thanks for the (hopeful) fix
                I will report back with my status in a few days
                • O
                  O
                  otto001
                  #808
                  @marceloaqno :
                  At first, THANKS for your help. CPU usage does not rise anymore.
                  But unfortunately no more node READs after the same situation:
                  Mar  4 07:00:09 raspiez mysgw: TSF:MSG:READ,14-14-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  Mar  4 07:00:09 raspiez mysgw: TSF:MSG:READ,12-12-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  Mar  4 07:00:09 raspiez mysgw: GWT:RFC:C=1,MSG=14;255;3;0;6;M
                  Mar  4 07:00:09 raspiez mysgw: !TSF:MSG:SEND,0-0-14-14,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                  Mar  4 07:00:09 raspiez mysgw: TSF:MSG:READ,11-11-0,s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
                  Mar  4 07:00:09 raspiez mysgw: GWT:RFC:C=1,MSG=12;255;3;0;6;M
                  Mar  4 07:00:09 raspiez mysgw: TSF:MSG:SEND,0-0-12-12,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                  Mar  4 07:00:13 raspiez mysgw: TSM:READY:NWD REQ
                  Mar  4 07:00:13 raspiez mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  Mar  4 07:00:13 raspiez mysgw: TSF:SRT:OK
                  Mar  4 07:00:13 raspiez mysgw: TSF:SAN:OK
                  Mar  4 07:00:37 raspiez mysgw: Ethernet client disconnected.
                  Mar  4 07:00:37 raspiez mysgw: New connection from 192.168.1.11
                  Mar  4 07:00:37 raspiez mysgw: GWT:TSA:C=0,CONNECTED
                  Mar  4 07:00:37 raspiez mysgw: GWT:TSA:C=1,DISCONNECTED
                  After this point (again after a reconnect from the controller) no more messages from any node PLUS the cpu usage stayed normal (what makes it even worse at this moment, as I would have to create a script which monitors the logfile and restarts the mysgw service in this situation). As soon as the service is restarted, everything is working fine again.
                  What happens after this point in the log:
                  Mar  4 07:00:37 raspiez mysgw: GWT:RFC:C=0,MSG=0;0;3;0;2;
                  Mar  4 07:15:13 raspiez mysgw: TSF:SAN:OK
                  Mar  4 07:20:13 raspiez mysgw: TSM:READY:NWD REQ
                  Mar  4 07:20:13 raspiez mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  Mar  4 07:30:13 raspiez mysgw: TSF:SRT:OK
                  Mar  4 07:30:13 raspiez mysgw: TSF:SAN:OK
                  Mar  4 07:30:37 raspiez mysgw: GWT:TSA:C=0,DISCONNECTED
                  Mar  4 07:30:37 raspiez mysgw: Ethernet client disconnected.
                  Mar  4 07:30:37 raspiez mysgw: New connection from 192.168.1.11
                  Mar  4 07:30:37 raspiez mysgw: GWT:TSA:C=0,CONNECTED
                  Mar  4 07:30:37 raspiez mysgw: GWT:RFC:C=0,MSG=0;0;3;0;2;
                  Mar  4 07:40:13 raspiez mysgw: TSM:READY:NWD REQ
                  Mar  4 07:40:13 raspiez mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  Mar  4 07:45:13 raspiez mysgw: TSF:SAN:OK
                  Mar  4 08:00:13 raspiez mysgw: TSM:READY:NWD REQ
                  Mar  4 08:00:13 raspiez mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  Mar  4 08:00:13 raspiez mysgw: TSF:SRT:OK
                  Mar  4 08:00:13 raspiez mysgw: TSF:SAN:OK
                  Mar  4 08:00:37 raspiez mysgw: GWT:TSA:C=0,DISCONNECTED
                  Mar  4 08:00:37 raspiez mysgw: Ethernet client disconnected.
                  Mar  4 08:00:37 raspiez mysgw: New connection from 192.168.1.11
                  Mar  4 08:00:37 raspiez mysgw: GWT:TSA:C=0,CONNECTED
                  and so on....
                  It seems that the increasing cpu usage is only a symptom for the real problem.
                  As I am using this in production I will dis-apply the patch and use the daemon as before (beacuse using the python script for cpu-usage-monitoring makes the situation somehow controllable for me).
                  Maybe you could have an additional eye on this please? Could I help you with further information? Maybe I could add some additional logging somewhere in the code?
                  Thanks again and cheers,
                  Otto
                  • O otto001
                    @marceloaqno :
                    and so on....
                    Otto
                    marceloaqno
                    Code Contributor
                    @otto001 I'm trying to reproduce this problem, but so far I've got nothing beyond the normal behavior of mysgw.
                    I tried with a RPi1 and RPi3 using the fhem controller with the latest raspbian.
                    • M marceloaqno
                      mvader
                      wrote on last edited by mvader
                      #810
                      @marceloaqno said in 💬 Building a Raspberry Pi Gateway:
                      My uptime is at 4 days now. so far still working with your patch. CPU is at 2% and sensor network still working correctly. will report if that changes.
                      • Nick WillisN
                        Nick WillisN
                        Nick Willis
                        I've been using your restarting method and its been working ok and has done one restart in 5 days.
                        However I now see something else where altho cpu use is fine, none of my nodes can communicate to the gateway. My controller can connect to the gateway no problem but there are no messages received. Restarting nodes does not help. Only a manual restart of the gateway gets things going again - at least for a while anyway.
                        Where is the log output from the gateway to be found? I know it can be run from the bash prompt to write the output to screen but how about logging the installed service output?
                        • Nick WillisN Nick Willis
                          #812
                          @nick-willis the log is sent to syslog by default. See https://www.mysensors.org/build/raspberry#troubleshooting for details.
                          • O
                            O
                            otto001
                            #813
                            @marceloaqno : This is strange. I am using a RPi 1 on this gateway with raspbian Jessie. Beside the GW-service there is only a small python programm which listens on an UPD-Port and plays an mp3 if it receives suitable data (for doorbell). Since March 4, 20:15 there were several restarts due to high cpu usage (after dis-applying your patch):
                            2018-03-04 23:01:03 cpu (99.7) very high! --> restarting service
                            2018-03-05 07:31:03 cpu (99.7) very high! --> restarting service
                            2018-03-05 11:01:03 cpu (98.7) very high! --> restarting service
                            2018-03-05 13:31:04 cpu (94.7) very high! --> restarting service
                            2018-03-06 11:31:03 cpu (99.7) very high! --> restarting service
                            2018-03-06 12:31:03 cpu (98.7) very high! --> restarting service
                            2018-03-07 06:01:03 cpu (94.8) very high! --> restarting service
                            2018-03-07 22:31:03 cpu (99.8) very high! --> restarting service
                            With this "auto-restarts" the sensors are working fine, I did not notice any problems.
                            However, I just upgraded to the recent Stretch (what takes a LONG time on RPi 1 and made me struggle a little bit with the new network names). I also rebuilt the GW of course and will report here what will happen....
                            @Nick-Willis : did you apply the patch of marceloaqno or not? Did you enable debugging? (see here )
                            Cheers,
                            Otto
                            • O otto001
                              Cheers,
                              Otto
                              marceloaqno
                              Code Contributor
                              #814
                              @otto001 In a new attempt to trigger this problem, I am using a script that will force the fhem controller to reconnect every 30s to the gateway (built with mysensors master branch, unpatched), and sends me a note in case of high CPU usage:
                              I'll leave it running for a few days to see what happens.
                              Here is the script, if anyone is interested:
                              #!/bin/sh
                              while true; do
                                (echo "set mysgw disconnect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
                                sleep 1
                                (echo "set mysgw connect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
                                sleep 1
                                cpu_percent=$(ps -C "mysgw" -o %cpu=)
                                cpu_percent=${cpu_percent%%.*}
                                if [ "$cpu_percent" -ge 90 ]
                                then
                                  echo "ALERT: HIGH CPU USAGE"
                                  # pushbullet script from https://gist.github.com/outadoc/189bd3ccbf5d6e0f39e4
                                  /home/pi/pushbullet.sh "RPi1: HIGH CPU USAGE"
                                  exit
                                fi
                                sleep 30
                              done
                              • O
                                O
                                otto001
                                @marceloaqno : Thank you!
                                Just a notice: I do NOT disconnect, I just connect every 30 minutes. Has been working for me since more than 2 years (ancient ms-gw version on RPi).
                                Yesterday I did a dist-upgrade to stretch on the "problematic" gw (as mentioned above) - without your patch but with my monitoring-script running. It is a little bit to early I presume, but no high cpu problems so far. I will report back here in a few days. Maybe this problem is really related to old libraries or something?! If this is running stable for a few days I will apply your patch and see what happens.
                                Thanks again!
                                Cheers,
                                Pula
                                  marceloaqno
                                  Code Contributor
                                  @otto001 After a few hours running the reconnect script, I noticed several error messages in my gateway log:
                                  accept(): Too many open files
                                  The problem was that the gateway wasn't releasing the socket descriptor after each disconnection of the controller. After reaching the limit (mine was 1036) the controller can't connect.
                                  I'm not entirely sure that this problem is related to what you're having. You can check how many file descriptors currently opened by the gateway with the command below
                                  sudo lsof -u root |grep mysgw |wc -l
                                  The fix:
                                  https://github.com/marceloaqno/MySensors/commit/a40d4441b7460225100398ff6f2581c2b0df36ea
                                    A Former User
                                    How do I update from master branch to development branch?
                                      Why do you want to do that? Development version is still work in progress
                                        A Former User
                                        wrote on last edited by [[global:former-user]]
                                        #819
                                        I'm using a raspberry pi gateway in home-assistant.
                                        Sometimes my gateway doesn't work anymore, and when I restart the service, it is running good
                                        I used ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
                                          Read the article again, there is the instruction on how to download the development version, but before you have to uninstall the mysgw service and rename the current mysensors folder to keep as backup.
