  3. Home Assistant
  4. pymysensors specific forum?
2 Posts 2 Posters 1.4k Views 3 Watching
  • afenoA
    afenoA
    afeno
    wrote on last edited by afeno
    There is any specific forum to talk about pymysensors?
    I have some doubts that I would like to clarify before proposing some changes on it.
    For example: Is it possible to send internal messages to the gateway? like sending an I_VERSION request. I only saw the option to send regular messages to sensors with set_child_vale.
    Thanks,
    Alfredo.
    • afenoA afeno
      Thanks,
      Alfredo.
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @afeno
      There's no specific forum for pymysensors that I know. Home Assistant uses pymysensors, so maybe that's the closest?
      Regarding sending an internal message: Create a Message instance and use the copy method to set the types and child, internal, I_VERSION, 255 etc. You can look at other places in the code for how that is done, eg:
      https://github.com/theolind/pymysensors/blob/master/mysensors/mysensors.py#L83-L85
      Then you want to encode the message and add it to the Gateway queue, for subsequent sending to gateway. There's the Gateway.fill_queue method for this. But you actually have to add a function with optional arguments/keyword arguments, where the return value of the function is the encoded message, to the queue. So you can add a reference to the encode method of the Message instance. See for example:
      https://github.com/theolind/pymysensors/blob/master/mysensors/mysensors.py#L325
