  3. My first motion build give error
6 Posts 4 Posters 1.9k Views 4 Watching
  • TON RIJNAARDT
    TON RIJNAARDT
    TON RIJNAARD
    I am a newby and this is my first build i get this error from the motion sensor.
    I use a arduino uno to try this project.
    Can some one help me what is wron
    Starting sensor (RRNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    !TSP:ASSIGNID:FAIL (ID=0)
    !TSM:FAILURE
    TSM:PDT
    TSM:FPAR
    TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    • TON RIJNAARDT TON RIJNAARD
      TSM:INIT
      TSM:RADIO:OK
      !TSM:FAILURE
      TSM:PDT
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      @TON-RIJNAARD great that you've gotten started :)
      Is this a combined node+gateway or do you have a separate gateway?
      Could you post your sketch?
      Node id 0 is reserved for the gateway. If this is a non-gateway node, use an id between 1 and 254.
      The basics of the MySensors network (nodes, gateways, etc) is described at https://www.mysensors.org/about/network
      TON RIJNAARDT 1 Reply Last reply
        TON RIJNAARDT
        TON RIJNAARDT
        TON RIJNAARD
        @mfalkvidd
        Hello, thanks for the very fast reply. The sketch is from the motion sensor.
        But i have not the gateway (i am waiting on the nano board).
        Must i chance the ID nr in the sketch?
        Greatz Ton
        BartEB CurlyWurlyC 2 Replies Last reply
          @mfalkvidd
          Greatz Ton
          BartEB
          BartEB
          BartE
          @TON-RIJNAARD to preset a node id use this define, where 1 can be a number between 1 and 254 (no duplicates allowed within your network)
          #define MY_NODE_ID 1
          But if there is no gateway you will keep getting errors, since radio messages will fail
            @mfalkvidd
            Greatz Ton
            CurlyWurlyC
            CurlyWurlyC
            CurlyWurly
            @TON-RIJNAARD
            To test things, you need
            1. Device 1 with rf24L01+ radio
            • Load "gatewayserial" sketch
            1. Device 2 with rf24l01+ radio
            • Load motion sketch, but add a line before
              so that it looks like this
            Switch on both devices and look at the serial messages from Device 1 (Gateway), When movement is detected, you will see new messages etc
            • TON RIJNAARDT
              TON RIJNAARDT
              TON RIJNAARD
              Thanks all for the information i wait that i have my nano and look what happens then.
