  3. Can't get the void receive() to work, on Repeater and Node's
6 Posts 2 Posters 3.1k Views 2 Watching
  • delinendD
    delinendD
    delinend
    Hi.
    I use the last 2.0.1-beta dev. version (from last night), and I can't get the function void receive(const MyMessage &message) to work.
    It works fine on a Gateway setup.
    Have tryed 2 types of setups.
    1. Node(ID6) to a Repeater(ID7). I see the debug data on the repeater, but can't get any data via the void receive().
    2. Node(ID6) to Node(ID7). Also here, I see the data on Node(ID7), but can't get any data via the void receive() funktion.
    Any ideas?
    Node(ID6) has a Static parent to Node-ID7, and Node(ID7) has a Static parent to Node-ID6
    The void receive(const MyMessage &message) funktion, now works fine, from version 2.0.1-beta, on at GatewaySerial setup.
    AWIA 1 Reply Last reply
    • delinendD delinend
      Hi.
      Any ideas?
      AWIA
      AWIA
      AWI
      @delinend Can you post the sketch.
      delinendD 1 Reply Last reply
      • AWIA AWI
        delinendD
        delinendD
        delinend
        @AWI
        Here the Node6, that sends temperatur, from a IR sensor to Parent-ID7
        #define MY_NODE_ID 6
        //#define MY_DEFAULT_ERR_LED_PIN 4
        #define MY_RF24_CHANNEL 123
        #define MY_PARENT_NODE_ID 7
        //#define MY_REGISTRATION_FEATURE
        #define MY_TRANSPORT_DONT_CARE_MODE
        //#define MY_REPEATER_FEATURE
        #include <Wire.h>
        #include <Adafruit_MLX90614.h>
        Adafruit_MLX90614 mlx = Adafruit_MLX90614();
        unsigned long SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
        MyMessage msg(0,V_TEMP);
        float temperature;
         mlx.begin();
        void presentation() {
          sendSketchInfo("Temperature Sensor", "1.1");
          present(0, S_TEMP);
        //  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
        //  Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
         temperature = mlx.readObjectTempC();
         Serial.println(temperature,1);
              send(msg.setSensor(0).set(temperature,1));
          sleep(SLEEP_TIME);
        Ande here Node7, from where I can see the temperatur data, via MY_DEBUG, but not via the void receive() function,
        //#define MY_SPECIAL_DEBUG
        //#define MY_DEBUG_VERBOSE_SIGNING
        //#define MY_DISABLED_SERIAL
        #define MY_NODE_ID 7
        #define MY_PARENT_NODE_ID 6
        // Enable serial gateway
        //#define MY_GATEWAY_SERIAL
        //#define MY_GATEWAY_W5100
        //  Serial.begin(19200);
        //  Serial.begin(MY_BAUD_RATE);
          Serial.println("Started . Please wait...");
         //sendSketchInfo("Temperature Sensor", "1.1");
        //Serial.println(tempp,1);
        delay(10);
        //wait(10);
          Serial.println("received something: ");
        //Serial.println(message.type);
          Serial.println(message.sender);
        //  Serial.println(message.sensor);
        //  Serial.println(message.getBool());
          @AWI
          #include <Wire.h>
          float temperature;
           mlx.begin();
            present(0, S_TEMP);
            sleep(SLEEP_TIME);
          delay(10);
          //wait(10);
          AWIA
          AWIA
          AWI
          shouldn't that be
          send(msg.setDestination(7).setSensor().set(temperature,1));
          in order to have messages delivered at the right destination == 7
          • AWIA AWI
            shouldn't that be
            delinendD
            delinendD
            delinend
            @AWI
            You hare a Hero :-) That works!
            Btw. Is the setting #define MY_TRANSPORT_DONT_CARE_MORE the right setting, when in a 2 Node's only setup ? I can't else get the Node6 beginning transmitting data.
              @AWI
              AWIA
              AWIA
              AWI
              @delinend The "royal way" is to have one node be a gateway. Else you need the "don't care"
