  3. ESP8266 need six analog input
5 Posts 2 Posters 3.0k Views 2 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    Has anyone experience with more than one analog input on the ESP8266?
    I have seen this example but I don't know if it will work well (the op-amp he is using is not specified).
    I have also googled that people uses MCP3004, MCP3008, MCP3021, MCP3421 for this, but I can't find anyone (beside the top example) that have a build tutorial for this expanded analog inputs.
    So have anyone else used six (or more) analog inputs on teh ESP8266 and can share the solution?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    • Martin TellblomM Martin Tellblom
      @Martin-Tellblom I have been looking at https://www.aliexpress.com/item/J34-Free-Shipping-16-Bit-I2C-ADS1115-Module-ADC-4-channel-with-Pro-Gain-Amplifier-for/32564528015.html
      but have not yet bought it. The address is configurable so you should be able to use up to 4 modules, giving you a total of 16 analog inputs. Also, it is able to measure voltages up to Vcc which is much easier than having to cope with the 1V limit of the esp analog input.
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        @mfalkvidd said:
        onfigurable so you should be able to use up to 4, giving you a total of 16 inputs. Also, it is able to measure voltages up to Vcc which is mych easier than having to cope with the 1V limit of the esp analog input.
        Looks promising, a few problems just :)
        The delivery time (found a few similar on ebay but they all seem to be shipped from the other side of the world with at least 30 days of deliverytime.
        It's a lot easier to be able to read 3.3V input I agree and this seems like the best idea yet but I don't now how to physicly connect the 6 wires to the 4 inputs and then I need a code that I can adapt.
        Or shall I use 2 of them (regarding to this Adafruit you can use 4 on the same I2C connection)
        Is this the same?
        http://www.ebay.co.uk/itm/16-Bit-I2C-4-CH-ADS1115-ADS1015-Module-ADC-Development-Board-for-Arduino-TE570-/282148404206?hash=item41b15afbee:g:zQkAAOSwZVlXveLA
        and
        http://www.ebay.co.uk/itm/16-Bit-I2C-Analogue-to-Digital-Convertor-Pro-Gain-Amp-ADS1115-4-Ch-Flux-Workshop-/122018838555?hash=item1c68e3b81b:g:hvkAAOSwepJXZE~N
          Is this the same?
          and
          @Martin-Tellblom both are called ads1115 so they should be the same.
          Yes, for 6 inputs you would use two modules.
          Martin TellblomM 1 Reply Last reply
            Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            @mfalkvidd
            Tnaks,
            I saw that Adafruit had a library and code or this that should be ESP8266 certified ...
            I'll try. Thanks for quick support
