  3. PIR sensor starts to trigger constantly after some time
11 Posts 4 Posters 5.8k Views 4 Watching
  • L
    L
    LastSamurai
    wrote on last edited by LastSamurai
    I recently updated my nodes to MySensors 2.0 and shortly after that my motion sensor started to behave strangely. It uses a mini PIR (linked in the mysensors store). It works for the first ~10-120 minutes and then starts to trigger constantly (without motion). I am using one of my minisensors boards (see here for pictures).
    The code I am using is based on the slim node pir from this forum, but converted to mysensors 2.
     * Based on the sketch of m26872 here https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
     * Documentation: http://forum.mysensors.org...
     * Version 1 06.09.2016 basesketch
     * Version 2 12.11.2016 update to mysensors 2
    // library settings
    #define MY_DEBUG    // Enables debug messages in the serial log
    //#define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
    #define MY_BAUD_RATE  9600 // Sets the serial baud rate for console and serial gateway
    //#define MY_SIGNING_SOFT // Enables software signing
    //#define MY_SIGNING_REQUEST_SIGNATURES // Always request signing from gateway//
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 // floating pin for randomness
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x5B,0x96,0x29,0xDD,0x0F,0x80,0x80,0xC5,0x1B}}} // gateway address
    //#define MY_NODE_ID 7
    #include <MyConfig.h>
    #include <Vcc.h>
    // program settings
    #define CHILD_ID 1
    #define CHILD_ID_BATTERY 2
    #define MOTION_INPUT_PIN 3
    #define BATTERY_REPORT_DAY 1   // Desired heartbeat(battery report) interval when inactive.
    #define BATTERY_REPORT_BY_IRT_CYCLE 30 // Make a battery report after this many trips. Maximum report interval will also be equal to this number of days.
    #define ONE_DAY_SLEEP_TIME 86400000
    #define VCC_MIN 1.8
    #define VCC_MAX 3.3
    int dayCounter = BATTERY_REPORT_DAY;
    int irtCounter = 0;
    bool interruptReturn = false; // "false" will make the first loop disregard high output from HV-505 (from start-up) and make a battery report instead.
    Vcc vcc(1.0);
    MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
    void before() {
      pinMode(MOTION_INPUT_PIN, INPUT);
      digitalWrite(MOTION_INPUT_PIN, LOW);    // Disable internal pull-ups
      sendSketchInfo("Motion sensor", "12112016 v2.0");
      present(CHILD_ID, S_MOTION);
      present(CHILD_ID_BATTERY, S_MULTIMETER);
      sleep(20000); // Wait until HC-505 warmed-up and output returned low.
      if (interruptReturn) {    // Woke up by rising pin
        send(msg.set("1"));  // Just send trip (set) commands to controller.
        wait(50);
        send(msg.set("0"));  // Send the off command right after
        irtCounter++;
        if (irtCounter >= BATTERY_REPORT_BY_IRT_CYCLE) {
            irtCounter=0;
            sendBatteryReport();
      else { // Woke up by timer  (or it's the first run)
        dayCounter++;
        if (dayCounter >= BATTERY_REPORT_DAY) {
              dayCounter = 0;
      sleep(3000);  // Make sure everything is stable before start to sleep with interrupts. (don't use "wait()" here). Tests shows false trip ~2s after battery report otherwise.
      // Sleep until interrupt comes in on motion sensor or sleep time passed.
      interruptReturn = sleep(MOTION_INPUT_PIN-2, RISING, ONE_DAY_SLEEP_TIME);
    void sendBatteryReport() {
      float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
      float v = vcc.Read_Volts();
      int batteryPcnt = static_cast<int>(p);
      send(voltage_msg.set(v,3));
    Signing is disabled for now as I had some problems with that.
    I am not sure if this has anything to do with the update but it worked before. Any idea how to fix this? Perhaps some kind of pulldown/up resistor or another capacitor?
    Thanks for your help!
    YveauxY 1 Reply Last reply
    • L LastSamurai
      // library settings
      #include <Vcc.h>
      // program settings
      #define CHILD_ID 1
      #define VCC_MIN 1.8
      #define VCC_MAX 3.3
      int irtCounter = 0;
      Vcc vcc(1.0);
      void before() {
          wait(50);
          irtCounter++;
              irtCounter=0;
          dayCounter++;
                dayCounter = 0;
      YveauxY
      YveauxY
      @LastSamurai you could try with the development branch as I fixed some wake from interrupt issues there; it might solve your issues.
      However, I have a comparable experience with cheap pir sensors. Sometimes they trigger when the arduino wakes, probably due to power variation (any other ideas are welcome).
      I can imagine that due to changes in amount/order/speed of messages sent in 2.0 this might trigger this strange behavior of the pir sensor.
      L 1 Reply Last reply
      • YveauxY Yveaux
        L
        L
        LastSamurai
        @Yveaux Thanks for the help, but it seems like the problem got only worse with the development branch. I guess its some kind of hardware problem then. Hopefully my pcb for the ikea motion sensor will arrive soon, then I will try them out.
        • abmantisA
          abmantisA
          abmantis
          Try with a fresh battery! Do you have any step-up converter for the PIR? I've also had the same problem recently, and I think (still need to test a bit more) that it was caused by the battery getting a bit discharged (after an OTA update).
          It usually triggers the PIR when the radio sends something. I think it is because the radio makes the voltage fluctuate when it sends.
          A simple workaround is to wait 3 seconds (the time my PIR takes to reset/settle after triggering) after sending data, and only then check if it has triggered. But I only wait if the previous state was zero (no motion), since I want it to fire instantaneously when motion is detected. So:
          • Get state;
          • Send state data;
          • If state was 1, sleep 3 secs;
          • Send new state if it changed from 0 to 1 (during 3 secs sleep);
          • Sleep with interrupt;
          • L
            L
            LastSamurai
            @abmantis Thanks for the answer. I think I got most of this. I modified some code from another pir post in this forum.
            Here is the code. Is that what you did too?
            // library settings
            #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 // floatingpin  for randomness
            #define MY_NODE_ID 12
            #include <Vcc.h>
            // program settings
            #define CHILD_ID 1
            #define VCC_MIN 1.8
            #define VCC_MAX 3.3
            int irtCounter = 0;
            Vcc vcc(1.0);
            void before() {
                wait(50);
                irtCounter++;
                    irtCounter=0;
                dayCounter++;
                      dayCounter = 0;
              wait(50);
            • abmantisA
              abmantisA
              abmantis
              My code is a little different, since I only send 0 when the PIR reports 0, instead of sending it right after 1.
              If you want I may post the code later.
              • abmantisA abmantis
                L
                L
                LastSamurai
                @abmantis Yes, I did that earlier too, but like this it was easier too use with my controller. Would be great if you could post your code too. Then I could test that too. Really want to get my pir up and working again ;)
                YveauxY abmantisA 2 Replies Last reply
                • L LastSamurai
                  YveauxY
                  YveauxY
                  @LastSamurai a quick test would be to introduce a blind time after triggering by issuing a sleep for a fixed amount of time (e.g 30 secs) without wake from Interrupt.
                  After this sleep you start another sleep which will wake when the sensor triggers.
                  I added this to my pir sensors and it works great!
                  m26872M 1 Reply Last reply
                  • YveauxY Yveaux
                    m26872M
                    m26872M
                    m26872
                    @Yveaux Isn't the "sleep(3000)" already this blind time? But, sure an increase would be good start.
                    • m26872M m26872
                      YveauxY
                      YveauxY
                      @m26872 yup, you're right :smirk: I didn't look at the sketch.
                      It should indeed wait longer than 3 seconds.
                      • L LastSamurai
                        abmantisA
                        abmantisA
                        abmantis
                        @LastSamurai Here is the code for my PIR and Light sensore node:
                        https://github.com/abmantis/MySensors-Sketches/blob/master/MotionLightSensor/MotionLightSensor.ino
                        It is a bit complex, sorry. Also, ignore the temperature parts since that is a WIP and is untested.
