  3. Serial gateway with NRF wireless + RS485 ??
2 Posts 2 Posters 1.3k Views 3 Watching
  • RedguyR
    RedguyR
    Redguy
    My "old" setup uses a wired sensor system with i2c and 1-Wire so most of my house is wired for sensors.
    My plan is to rebuild the sensor net using Mysensors nodes to read out the existing 1-Wire and i2c sensors and connect these nodes to my gateway/controller using the RS485 option since the wiring is already there.
    In addition to that, i would like to start adding new nodes and features using wireless nodes with the NRF radio on it.
    Can i create a gateway node that supports both of these options at the same time or do i have to setup separate gateways for that ?
    (i run domoticz)
      You'll have to use separate gateways.
