  3. send updates regularly in noides HOW ?
5 Posts 2 Posters 1.9k Views 2 Watching
  • pepsonP
    pepsonP
    pepson
    Hi
    I want add to sketch on my node to send updates status regularly to my gateway. But how i can do it ?
    I want add this to resolved problem when example on gateway power is down. Then node change status and then power come back on gateway and status node is not show correct in controller. It was repaire it when now i change status on node it was update on controller.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      Your question is very general, if You want specific answer ask a specific question. maybe attach your shetch ? if you want send updates regularly just send them regularly ...
      • pepsonP
        pepsonP
        pepson
           DESCRIPTION
           Sketch for 2x relay with buttons bistable. After back power all relays set OFF and send correct status OFF to controller.
        // Enabled repeater feature for this node
        #define MY_REPEATER_FEATURE
        #include <Bounce2.h>
        // Define Relays
        #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
        // Define Sensor ID's
        #define SSR_A_ID 1   // Id of the sensor child
        #define SSR_B_ID 2   // Id of the sensor child
        // Define buttons and relays
        const int buttonPinA = 3;
        const int buttonPinB = 4;
        const int relayPinA = 5;
        const int relayPinB = 6;
        // Define Variables
        int oldValueA = 0;
        int oldValueB = 0;
        bool stateA = false;
        bool stateB = false;
        int trigger = 0;
        Bounce debouncerA = Bounce();
        Bounce debouncerB = Bounce();
        MyMessage msgA(SSR_A_ID, V_STATUS);
        MyMessage msgB(SSR_B_ID, V_STATUS);
          pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
          pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
          // After setting up the buttons, setup debouncer
          debouncerA.attach(buttonPinA);
          debouncerA.interval(5);
          debouncerB.attach(buttonPinB);
          debouncerB.interval(5);
          digitalWrite(relayPinA, RELAY_OFF);
          digitalWrite(relayPinB, RELAY_OFF);
          pinMode(relayPinA, OUTPUT);
          pinMode(relayPinB, OUTPUT);
            /*--------------------- Added these lines for toggle switch-------------------------*/
          oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
          oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
         // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
         // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
        void presentation()  {
          sendSketchInfo("2xRelay with bistable", "1.0");
          present(SSR_A_ID, S_LIGHT);
          present(SSR_B_ID, S_LIGHT);
           Example on how to asynchronously check for new messages from gw
        if (trigger == 0){
          trigger = 1;
          debouncerA.update();
          // Get the update value
          int valueA = debouncerA.read();
          if (valueA != oldValueA) {
           // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
            send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
            stateA = stateA ? false : true;               // invert the state
             digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
          oldValueA = valueA;
          debouncerB.update();
          int valueB = debouncerB.read();
          if (valueB != oldValueB) {
            //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
            send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
            stateB = stateB ? false : true;                // invert the state
             digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
          oldValueB = valueB;
            switch (message.sensor) {
              case 1:
                stateA = message.getBool();
                digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                break;
              case 2:
                stateB = message.getBool();
                digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                break;
              // Write some debug info
            Serial.println(message.sensor);
            Serial.print("from node:");
            Serial.println(message.sender);
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          wrote on last edited by rozpruwacz
          so in line 101 and 113 you have if's that decides if the report will be sent to the gateway. basically you need an 'else if' branch that will decide if it is time to send additional report. something like that:
          if () {
          else if (sendAdditionalReport == true) {
          so You need to somehow calculate the sendAdditionalReport value in every pass of the loop accordingly. i don't really know so good arduino library but i believe there must be some kind of timer available that will help you with this calculation.
          • pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            I dont understand and i am begginer. Can you explaine me more and give me ready solution please ?
            This is my actual sketch which i use:
               DESCRIPTION
               Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
            // Define Relays
            // Define Variables
            int oldValueA = 0;
            int oldValueB = 0;
            int trigger = 0;
              sendSketchInfo("2xRelay with monostable", "1.0");
            if (trigger == 0){
              trigger = 1;
              if (valueA != oldValueA && valueA == 0) {
              oldValueA = valueA;
              if (valueB != oldValueB && valueB == 0) {
              oldValueB = valueB;
                  case 1:
                    break;
                  case 2:
                    break;
