  3. problem about gas sensor
5 Posts 3 Posters 1.9k Views 4 Watching
  • R
    R
    Reza
    hi guys
    i have 2 problem with gas sensor
    first about my sketch
    #define MY_RF24_CHANNEL 0
    #define MY_NODE_ID 4
    #define MY_REPEATER_FEATURE
    #include <avr/wdt.h>
    unsigned long time_m;
    unsigned long a , b , c;
    #define     CHILD_ID_MQ                   0
    /************************Hardware Related Macros************************************/
    #define     MQ_SENSOR_ANALOG_PIN         (0)  //define which analog input channel you are going to use
    #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
    #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
    //which is derived from the chart in datasheet
    /***********************Software Related Macros************************************/
    #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
    #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
    //cablibration phase
    #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
    //normal operation
    /**********************Application Related Macros**********************************/
    #define         GAS_LPG                      (0)
    #define         GAS_CO                       (1)
    #define         GAS_SMOKE                    (2)
    /*****************************Globals***********************************************/
    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    float Ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;           // variable to store the value coming from the sensor
    float valMQ = 0.0;
    float lastMQ = 0.0;
    float           LPGCurve[3]  =  {2.3, 0.21, -0.47}; //two points are taken from the curve.
    //with these two points, a line is formed which is "approximately equivalent"
    //to the original curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
    float           COCurve[3]  =  {2.3, 0.72, -0.34};  //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
    float           SmokeCurve[3] = {2.3, 0.53, -0.44}; //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
    MyMessage msg(CHILD_ID_MQ, V_LEVEL);
      Ro = MQCalibration(MQ_SENSOR_ANALOG_PIN);         //Calibrating the sensor. Please make sure the sensor is in clean air
      wdt_enable(WDTO_4S);
    void presentation() {
      sendSketchInfo("R_M Gas", "1.0");
      present(CHILD_ID_MQ, S_AIR_QUALITY);
      time_m = millis();
      a = time_m / 1000;
      b = a % 40;
      c = a % 20;
      if (b == 0) {
        uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_CO);
        Serial.println(val);
        Serial.print("LPG:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_LPG) );
        Serial.print( "ppm" );
        Serial.print("    ");
        Serial.print("CO:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_CO) );
        Serial.print("    ");
        Serial.print("SMOKE:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_SMOKE) );
        Serial.print("\n");
        if (valMQ != lastMQ) {
          send(msg.set((int16_t)ceil(valMQ)));
          lastMQ = ceil(valMQ);
     if (c == 0) {
        send(msg.set((int16_t)ceil(lastMQ)));
    wait(1000);
      wdt_reset();
      // wait(SLEEP_TIME); //sleep for: sleepTime
    /****************** MQResistanceCalculation ****************************************
      Input:   raw_adc - raw value read from adc, which represents the voltage
      Output:  the calculated sensor resistance
      Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
             across the load resistor and its resistance, the resistance of the sensor
             could be derived.
    float MQResistanceCalculation(int raw_adc)
      return ( ((float)RL_VALUE * (1023 - raw_adc) / raw_adc));
    /***************************** MQCalibration ****************************************
      Input:   mq_pin - analog channel
      Output:  Ro of the sensor
      Remarks: This function assumes that the sensor is in clean air. It use
             MQResistanceCalculation to calculates the sensor resistance in clean air
             and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
             10, which differs slightly between different sensors.
    float MQCalibration(int mq_pin)
      int i;
      float val = 0;
      for (i = 0; i < CALIBARAION_SAMPLE_TIMES; i++) {      //take multiple samples
        val += MQResistanceCalculation(analogRead(mq_pin));
        delay(CALIBRATION_SAMPLE_INTERVAL);
      val = val / CALIBARAION_SAMPLE_TIMES;                 //calculate the average value
      val = val / RO_CLEAN_AIR_FACTOR;                      //divided by RO_CLEAN_AIR_FACTOR yields the Ro
      //according to the chart in the datasheet
      return val;
    /*****************************  MQRead *********************************************
      Output:  Rs of the sensor
      Remarks: This function use MQResistanceCalculation to caculate the sensor resistenc (Rs).
             The Rs changes as the sensor is in the different consentration of the target
             gas. The sample times and the time interval between samples could be configured
             by changing the definition of the macros.
    float MQRead(int mq_pin)
      int i;
      float rs = 0;
      for (i = 0; i < READ_SAMPLE_TIMES; i++) {
        rs += MQResistanceCalculation(analogRead(mq_pin));
        delay(READ_SAMPLE_INTERVAL);
      rs = rs / READ_SAMPLE_TIMES;
      return rs;
    /*****************************  MQGetGasPercentage **********************************
      Input:   rs_ro_ratio - Rs divided by Ro
             gas_id      - target gas type
      Output:  ppm of the target gas
      Remarks: This function passes different curves to the MQGetPercentage function which
             calculates the ppm (parts per million) of the target gas.
    int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
      if ( gas_id == GAS_LPG ) {
        return MQGetPercentage(rs_ro_ratio, LPGCurve);
      } else if ( gas_id == GAS_CO ) {
        return MQGetPercentage(rs_ro_ratio, COCurve);
      } else if ( gas_id == GAS_SMOKE ) {
        return MQGetPercentage(rs_ro_ratio, SmokeCurve);
      return 0;
    /*****************************  MQGetPercentage **********************************
             pcurve      - pointer to the curve of the target gas
      Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
             of the line could be derived if y(rs_ro_ratio) is provided. As it is a
             logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
             value.
    int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
      return (pow(10, ( ((log(rs_ro_ratio) - pcurve[1]) / pcurve[2]) + pcurve[0])));
    in this sketch just report 0 value :
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
    4 TSM:INIT
    11 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=122
    14 TSF:SID:OK,ID=122
    16 TSM:FPAR
    53 TSF:MSG:SEND,122-122-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    316 TSF:MSG:READ,0-0-122,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    321 TSF:MSG:FPAR OK,ID=0,D=1
    2060 TSM:FPAR:OK
    2061 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2067 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2077 TSF:MSG:READ,0-0-122,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2082 TSF:MSG:PONG RECV,HP=1
    2084 TSM:UPL:OK
    2086 TSM:READY
    2089 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2097 TSF:MSG:READ,0-0-122,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2107 TSF:MSG:SEND,122-122-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
    2116 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2502 TSF:MSG:READ,0-0-122,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2509 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=11,pt=0,l=7,sg=0,ft=0,st=OK:R_M Gas
    2519 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    2528 TSF:MSG:SEND,122-122-0-0,s=0,c=0,t=22,pt=0,l=0,sg=0,ft=0,st=OK:
    2534 MCO:REG:REQ
    2537 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2544 TSF:MSG:READ,0-0-122,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2549 MCO:PIM:NODE REG=1
    2551 MCO:BGN:STP
    27561 MCO:BGN:INIT OK,ID=122,PAR=0,DIS=1,REG=1
    27567 TSF:MSG:READ,4-4-122,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    27572 !TSF:MSG:FPAR INACTIVE
    LPG:0ppm    CO:0ppm    SMOKE:0ppm
    41583 TSF:MSG:SEND,122-122-0-0,s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    60591 TSF:MSG:SEND,122-122-0-0,s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    71483 TSF:MSG:READ,8-8-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    71488 TSF:MSG:BC
    71489 TSF:MSG:FPAR REQ,ID=8
    71492 TSF:PNG:SEND,TO=0
    71496 TSF:MSG:SEND,122-122-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    71506 TSF:MSG:READ,0-0-122,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    71512 TSF:MSG:PONG RECV,HP=1
    71515 TSF:CKU:OK
    71516 TSF:MSG:GWL OK
    72384 TSF:MSG:SEND,122-122-8-8,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:1
    81399 TSF:MSG:SEND,122-122-0-0,s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    also when i use other sketch (in site) i have problem . after times i test this but dont show really values... i test with a new sensor and there is different value also i test with 3 sensor but there are different values for all !
    also i change sensors and i have different result. i can not know where is problem !
    blaceyB 1 Reply Last reply
    • R Reza
      hi guys
      //normal operation
      #define         GAS_LPG                      (0)
      #define         GAS_CO                       (1)
      //VARIABLES
      float valMQ = 0.0;
      float lastMQ = 0.0;
        time_m = millis();
        a = time_m / 1000;
        b = a % 40;
        c = a % 20;
        if (b == 0) {
          Serial.print("    ");
          Serial.print("    ");
          Serial.print("\n");
       if (c == 0) {
      wait(1000);
        wdt_reset();
               could be derived.
        int i;
        float val = 0;
        return val;
        int i;
        float rs = 0;
        return rs;
        return 0;
               value.
      4 TSM:INIT
      11 TSM:INIT:TSP OK
      16 TSM:FPAR
      2060 TSM:FPAR:OK
      2061 TSM:ID
      2062 TSM:ID:OK
      2064 TSM:UPL
      2084 TSM:UPL:OK
      2086 TSM:READY
      2534 MCO:REG:REQ
      2551 MCO:BGN:STP
      71488 TSF:MSG:BC
      71515 TSF:CKU:OK
      blaceyB
      blaceyB
      blacey
      @Reza said:
      /Hardware Related Macros************/
      If I were to hazard a guess, it looks like you did not set MQ_SENSOR_ANALOG_PIN to the pin # to which the MQ_SENSOR is attached. Pin 0 is not valid.
      R 1 Reply Last reply
      • blaceyB blacey
        R
        R
        Reza
        wrote on last edited by Reza
        @blacey
        Hello, thank you for the answer.
         Aout MQ2 is connected to the Arduino A0.
        The sketch that is in site "https://github.com/mysensors/MySensors/blob/master/examples/AirQualitySensor/AirQualitySensor.ino" has a problem. For long time if last value == new value, so radio dont ant reports to the gateway for a long time and I see that node is red and offline in domoticz. So I used a Millis () function has been added to report every few minutes. My first test with a plastic bag full of gas, i put gas sensor in a plastic bag and close the bag. So I see a number of ppm (greate) for example 1900 ppm. After some days I tested this again and again .... but this time a bag full of gas shows only 27 ppm (same conditions) so I'm making more gas sensors and put in plastic bag, but (in the photo ) each sensor shows the different number of ppm (the number is far ...).
        is the MQ2 a reliability sensor? this problem is related to MQ2 sensor? or sketch or other reason!
        Z 1 Reply Last reply
        • R Reza
          @blacey
          Z
          Z
          zampedro
          @Reza hi Reza,
          LPGCurve[3]={2.3, 0.21, -0.47}; COCurve[3] and SmokeCurve[3] are taken from MQ-2 datasheet where 2.3=Lg200 but the sketch uses "log" in
          In my system log stands for ln=natural logarithm so i have to change log with log10 in the sketch and in the MQ2 library.
          Try a Serial.print(log(10)) to check.
          Regards
          • Z zampedro
            @Reza hi Reza,
            Regards
            R
            R
            Reza
            @zampedro
            thank you for answer . but i dont understand you. you say to me i must change sketch ? what change ? witch line? thank you
