  3. Switch from hex to normal RGB
6 Posts 3 Posters 2.3k Views 3 Watching
    moskovskiy82
    Currently have the following code (at the bottom - removed everything irrelevant) - followed by the examples on this great board which receives hex. Not very strong at programming and need to switch to receiving values like /36/0/1/0/40 249,255,218
    Just do not know how to change the setColor(String hexstring) function
    OLD CODE:
    long RGB_values[3] = {0,0,0};
    String hexstring;
    int RValue;
    int GValue;
    int BValue;
    int CurrentLevel;
    void before()
    pinMode(RED_PIN, OUTPUT);
    pinMode(GREEN_PIN, OUTPUT);
    pinMode(BLUE_PIN, OUTPUT);
    TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20);
    if (message.type==V_RGB)
    	hexstring = message.getString();
    	Serial.print("RGB command: ");
    	Serial.println(hexstring);
    	setColor(hexstring);
      else if (message.type==V_PERCENTAGE)
    int dimLevel = message.getInt(); //0-100%
    Serial.print("Dim command: ");
    Serial.println(dimLevel);
    setDimLevel(dimLevel);
    saveState(SAVE_DIMMER_LEVEL, dimLevel);
    else if (message.type==V_STATUS)
    	if(message.getBool() == RELAY_ON)
    	setColor("FFF1E0");
    	saveState(SAVE_LIGHT_STATE, RELAY_ON);
    	if(message.getBool() == RELAY_OFF)
    	analogWrite(RED_PIN, 0);
    	analogWrite(GREEN_PIN, 0);
    	analogWrite(BLUE_PIN, 0);
    	saveState(SAVE_LIGHT_STATE, RELAY_OFF);
    void setDimLevel(int level)
    level = level > 100 ? 100 : level;
    level = level < 0 ? 0: level;
    int delta = ( level - CurrentLevel) < 0 ? -1 : 1;
    RValue = (int)(level / 100. * RValue);
    BValue = (int)(level / 100. * BValue);
    GValue = (int)(level / 100. * GValue);
    analogWrite(RED_PIN, RValue);
    analogWrite(GREEN_PIN, GValue);
    analogWrite(BLUE_PIN, BValue);
    CurrentLevel = level;
    void setColor(String hexstring)
    long number = (long) strtol( &hexstring[0], NULL, 16);
    Serial.print("Color long: ");
    Serial.println(number);
    RValue = number >> 16;
    GValue = number >> 8 & 0xFF;
    BValue = number & 0xFF;
    Serial.print("Color: ");
    Serial.print("Red: ");
    Serial.println(RValue);
    Serial.print("Green: ");
    Serial.println(GValue);
    Serial.print("Blue: ");
    Serial.println(BValue);
    Boots33B 1 Reply Last reply
    • M moskovskiy82
      OLD CODE:
      String hexstring;
      int RValue;
      int GValue;
      int BValue;
      int CurrentLevel;
      void before()
      	setColor("FFF1E0");
      Boots33B
      Boots33B
      Boots33
      @moskovskiy82 Not totally sure what you need but if you have a look at my setcolor function in this post it uses RGB values to change the colours. Is that what you meant?
        moskovskiy82
        Not exactly...
        Here we are awaiting a hex value
        And than process those to rgb values. But if via MQTT we will receive RGB values like 243,145,156 and not hex - how to change the code accordingly?
          mortommy
          you can try this:
                char convBuffer[8];
                hexstring = strtol(message.getString(convBuffer),0,16);
                r=(int)(hexstring>>16);
                g=(int)(hexstring>>8)& 0xFF;
                b=(int)(hexstring)& 0xFF;
          Hope it helps.
          • M moskovskiy82
            Not exactly...
            Boots33B
            Boots33B
            Boots33
            @moskovskiy82 I have not used MQTT so am not sure how it sends the data. Does it still send it as V_RGB ? if it does then you will need to parse the data to split it into the three separate values . Do a google search for: Arduino parse comma delimited string and you will see what is needed.
              moskovskiy82
              Sorry tp bump an old one but still haven't found a solution.
              MQTT passes it as
              mys-in/36/0/1/0/40 255,85,73
              So the message payload can be passed directly to arduino as PWM values
