  3. ESP + RFM69 Gateway Reset issue
4 Posts 2 Posters 2.8k Views 2 Watching
  • OpticFroggyO
    OpticFroggyO
    OpticFroggy
    Hi all,
    Firstly I'm so impressed with the community and the development on MySensors, it's great how the whole DIY IoT thing has boomed over the past couple of years.
    I'm trying to get the ESP Gateway example working with a RFM69 radio and having some issues it connects to my Wifi network fine, then fails shortly afterwards, at the same point every time. I've included a dump of the Serial from one full iteration and also a quick photo (though it's not that clear with all the wires) of my setup. Suffice to say it's basically just a normal ESP12 setup connected to the RFM69 as the documentation says.
    My ESP RFM69 Setup
    I'm using the latest versions of everything also.
    If anyone has any ideas they would be really appreciated.
    Starting gateway (RRNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    scandone
    state: 0 -> 2 (b0)
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    state: 2 -> 0 (2)
    reconnect
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    connected with xxxxxxxxxxxxxxx, channel 1
    dhcp client start...
    ip:192.168.0.18,mask:255.255.255.0,gw:192.168.0.1
    Soft WDT reset
    ctx: cont
    sp: 3fff00f0 end: 3fff03e0 offset: 01b0
    >>>stack>>>
    3fff02a0:  00000004 00000000 3fff0480 4020221c
    3fff02b0:  00000027 3fff06f4 3fff0480 40202861
    3fff02c0:  3fff0498 00000001 3fff0480 402029a5
    3fff02d0:  00000000 00000016 3fff0480 40202be0
    3fff02e0:  0000002f 3fff06f4 3fff0480 000000ff
    3fff02f0:  00000000 00000016 3fff0480 40203d39
    3fff0300:  00020401 40040203 33060305 0008d907
    3fff0310:  42190009 07264025 dc291028 2d2f882e
    3fff0320:  90376430 8f3c4238 306f123d 3fff00ff
    3fff0330:  00000064 00000004 3fff0480 40202994```
    • OpticFroggyO OpticFroggy
      Hi all,
      My ESP RFM69 Setup
      scandone
      state: 0 -> 2 (b0)
      0;255;3;0;9;TSM:PDT
      state: 2 -> 0 (2)
      reconnect
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 3
      cnt
      Soft WDT reset
      ctx: cont
      >>>stack>>>
      @OpticFroggy areyou using an unmodified(except configuration settings) example sketch? If not, could you post your sketch? Remember to censor your wifi password before posting.
      • OpticFroggyO
        OpticFroggyO
        OpticFroggy
        Hey,
        Yea it's the ESP8266 Gateway sketch, unmodified except for the various defines I'd need afaik.
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 9600
        //#define MY_RADIO_NRF24
        #define MY_RADIO_RFM69
        #define MY_RFM69_FREQUENCY   RF69_433MHZ
        #define MY_IS_RFM69HW
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "xxxxx"
        #define MY_ESP8266_PASSWORD "xxxxx"
        // Enable UDP communication
        //#define MY_USE_UDP
        #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        // Led pins used if blinking feature is enabled above
        #if defined(MY_USE_UDP)
          #include <WiFiUdp.h>
        #include <ESP8266WiFi.h>
        void presentation() {
          Hey,
           * LED purposes:
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
           * GND        GND
          @OpticFroggy sorry for the late reply. I haven't used rfm radios before, but tonight I finally got it working, with a lot of help from @scalz and the rest of the MySensors team.
          This is my wiring:
          These are my settings in the sketch:
          #define MY_RF69_IRQ_PIN D1
          #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
          #define MY_RF69_SPI_CS D2 // NSS
          D8 cannot be used because it interferes with uploading sketches.
          With this, I got an nodemcu rfm69H-433 ethernet gateway working, and a wemos d1 mini rfm69H-433 sensor node. I used MySensors 2.1.1.
