  3. Motion Sensor Stop Working after couple of day
4 Posts 2 Posters 1.2k Views 2 Watching
  • Dominic BonneauD
    Dominic BonneauD
    Dominic Bonneau
    Hi, I have made this motion sensor :
    https://www.mysensors.org/build/motion
    With HC-SR501 PIR Motion Sensor Module and a MQTT gateway
    and after a couple of day it stop working or become less accurate so i need to unplug it and plug it back so it start working fine again
    I unplug every connection and reconnect everything... i fix it up tight in my box so nothing move or unplug it self ..
    Do you have an idea what cause this ?
    • Dominic BonneauD Dominic Bonneau
      @Dominic-Bonneau - I always start by swapping to another power supply if its a 5v version.
      • Dominic BonneauD
        Dominic BonneauD
        Dominic Bonneau
        Hum ... it's Arduino pro mini 8v and i power it with USB and an apple power block.
        What should I do instead ?
          @Dominic-Bonneau - You mean a Pro Mini 5v? As i said I would change the usb charger to another and see what happens. Also I would make sure i have capacitors on the radio and the wiring/soldering is good.
          Sounds to me like power issue (long shot without more info) and somethings crash the radio.
          Please report with logs and sketches if possible.
