  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
  • O
    O
    Omemanti
    Hey, looks great!
    is it possible tot get some Eagle files?
    Thnx!
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      was it possible to buy this board assembled from you?
      KoreshK 1 Reply Last reply
        KoreshK
        KoreshK
        Koresh
        @Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
        This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
        Miroslav KadaněM 1 Reply Last reply
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          @Koresh said in 💬 Button size radionode with sensors swarm extension:
          rfm69cw
          yes rfm69cw is fine, as I understand it will still be compatible with rfm69(H)W gateway?. Also are you using 868 MHz band or any other?
          I don't remember where I read the prices, could you give them again? And can you buy the atmega/rfm -board separate from the sensorboard or do I have to buy them as a set?
            Will it be available preassembled? :)
              KoreshK
              KoreshK
              Koresh
              @gohan Yes. Of course :smile:
              • KoreshK
                KoreshK
                Koresh
                Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-controller-rfm69cw-hcw-433-mhz-radio-156694991.htm
                  Best of luck for your shop :+1:
                  • bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    wrote on last edited by bjornhallberg
                    #29
                    Great! One question though, is everything already soldered and if so is there an option to for 868MHz?
                    gohanG 1 Reply Last reply
                      @bjornhallberg if you want you can just order pcb and build your own node
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        @gohan Yeah I could but I'm just too lazy :-) There are a lot of components to source from AliExpress before anyone can build these boards. It would take months even if there aren't any errors in the BOM or lost packages from China.
                          @bjornhallberg since @Koresh is still in the early production stage, I think he can manage to make a few with a different radio, given of course he has the 866 mhz modules available 😁
                            bjornhallbergB
                            bjornhallbergB
                            bjornhallberg
                            #33
                            @gohan Thankfully I do have some CW 868 radios (~5 left) available that I bought ahead of time. I think everyone can solder the radio to the board by hand and so I personally would prefer that @Koresh would consider selling the parts separately.
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              If possible I would also like the option to chose 868 Mhz or be able to buy board without radio.
                                KoreshK
                                KoreshK
                                Koresh
                                @Cliff-Karlsson
                                @bjornhallberg
                                I have some assembled boards without the radio. You can buy them here https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-controller-ready-for-rfm69cw-hcw-radio-156711327.htm . I just reminding this board has a rfm69HCW footprint but you can solder rfm69CW modules with the pcb adapter which I made. Of course I will supply the adapter with the main board.
                                • KoreshK Koresh
                                  @Cliff-Karlsson
                                  @bjornhallberg
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @Koresh Thanks! Great solution with the adapter board as well, you really do think of everything. Do you have the other boards without radio as well? Specifically the Switch Controller?
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    @bjornhallberg
                                    I have some insertable switch boards without radio. I planned to solder nrf24 into them but can sell them without radio too (it supports only cw modules). Will put up for sale soon.
                                    • KoreshK Koresh
                                      @bjornhallberg
                                      bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      @Koresh Sounds great! Oh and btw, any idea how customs will handle the packages, any chance of taxes and customs fees? You're outside of the EU customs union right?
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        wrote on last edited by Koresh
                                        #39
                                        @bjornhallberg I do not know exactly, but I don't think there should be any fees. Try to find out tomorrow.
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Koresh I got one of boards and would like to add Si1132-A10-GMR. What else I need to add? C8?
                                          Why are you not using this sensor on your board?
