  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
  • Nca78N Nca78
    @alexsh1 said in 💬 Button size radionode with sensors swarm extension:
    However, actively measuring current - 4.5mA
    This would kill 2032 very quickly
    Matter of hours I guess, it's half more than the max continuous discharge current of a CR2032.
    alexsh1A
    alexsh1A
    alexsh1
    #81
    @Nca78 said in 💬 Button size radionode with sensors swarm extension:
    It is 4.mA for 120ms for less just for measurements
    However, I agree that this is not very battery friendly
    Nca78N 1 Reply Last reply
    • alexsh1A alexsh1
      Nca78N
      Nca78N
      Ah ok I completely misunderstood :D But yes seems high for a CR2032 sensor...
      • TerrenceT
        TerrenceT
        Terrence
        This post is deleted!
        • A
          A
          Abdu Sahin
          @Koresh,
          I tried to buy some of these on the link you provided, but couldn't do it. Do you still have this component in your stock ? I like to buy 865mhz HW/W versions.
          • Y
            Y
            yury
            @Abdu-Sahin said in 💬 Button size radionode with sensors swarm extension:
            865mhz HW/
            Hi
            They will be ready end of this week. do you need both HCW and CW versions?
            A 1 Reply Last reply
            • Y yury
              865mhz HW/
              Hi
              A
              A
              Abdu Sahin
              @yury
              I like to try both 865 HW/W versions. I need sensors with long battery life and good RF distance coverage for my project. I've noticed some people suggested using only 'W' version for battery powered nodes, but from my initial experience I didn't have good distance with 'W' version.
              Y 1 Reply Last reply
              • A Abdu Sahin
                @yury
                Y
                Y
                yury
                )) either good battery life or good coverage though... or good coverage and 2-3 AA batteries. CW is 20 mA when sending signal and HCW is about 100 mA. CR2032 battery will be drained by HCW pretty fast.
                HW/W versions have bigger footprints (Module Size:19.7X16mm) and not compatible with the "Button size".
                HCW/CW (Module Size:16X16mm) are equivalents for HW/W.
                • Y yury
                  A
                  A
                  Abdu Sahin
                  @yury
                  I think I can start with CW version as start. Battery life is important for me.
                  • A Abdu Sahin
                    @yury
                    Y
                    Y
                    yury
                    sent you a message in the chat...
                    • Y yury
                      A
                      A
                      Abdu Sahin
                      wrote on last edited by Abdu Sahin
                      #90
                      @yury
                      You can email me if you like.
                      My email is uk.asahin at gmail com
                      TerrenceT 1 Reply Last reply
                      • A Abdu Sahin
                        @yury
                        TerrenceT
                        TerrenceT
                        Terrence
                        @Abdu-Sahin I was interested in reading your conversation about battery life etc. I hope you will continue the conversation on the forum instead of in private.
                        Thanks.
                        • Miroslav KadanÄ›M
                          Miroslav KadaněM
                          Miroslav KadanÄ›
                          It is possible to buy only PCB ? Upload PCB to OSH Park, or send PCB in eagle. I do not have Altium Designer... Thx
                          KoreshK 1 Reply Last reply
                          • Miroslav KadanÄ›M Miroslav KadanÄ›
                            KoreshK
                            KoreshK
                            Koresh
                            @Miroslav-KadanÄ› I've just uploaded latest gerbers (rfm reset pin was connected to controller, connection of si1132 was fixed, reverse battery polarity protection was added). You can place PCB order at any factory. :wink:
                            • C
                              C
                              chbla
                              Maybe a stupid question but how do you connect the FTDI adapter? I only know the ISP pins
                              C 1 Reply Last reply
                              • getlargeG
                                getlargeG
                                getlarge
                                @yury @koresh
                                Few months ago, I've ordered some of your nodes, which work perfectly by the way, but I needed something that could speed up testing of any sensors.
                                So following our conversation on Github with Yury, I've created a PCB based on your Button size node, with a field for an extension board. The aim is to have a versatile board, and extensions that could handle virtually any sensors, like NodeManager project, but for hardware ;)
                                And it's also a first time experiment in the land of PCBs
                                Apart 2 errors ( maybe more in the future !), it seems to be well routed, as tests been proving, but i still not tried the FOTA function.
                                Errors was a badly routed button and it seems that, after the RFM chip is soldered, communication with USBasp gets bad! Is it because SCK and MISO route ( from pin headers to atmega328 ) goes through the RFM chip before atmega ?
                                You were mentioning some mods in dualoptiboot in order to flash M25P40, https://forum.mysensors.org/topic/3160/ota-flash-types-for-mysensors/43.
                                Would it be possible to share these ?
                                And just out of curiosity, how did you manage to solder SI7021 and TSL2561 ?
                                By now, it seems like a mystery for me...
                                • getlargeG getlarge
                                  @yury @koresh
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  wrote on last edited by Koresh
                                  #96
                                  @getlarge said in 💬 Button size radionode with sensors swarm extension:
                                  Did you solder R4 (from your schematic https://github.com/getlarge/Cosmonode/blob/master/Cosmonode_sch.pdf)? I can't find it on the boards photo.
                                  PS
                                  Will share compiled bootloader and sources soon.
                                  • getlargeG
                                    getlargeG
                                    getlarge
                                    @Koresh said in 💬 Button size radionode with sensors swarm extension:
                                    Sorry, picture's quality is not too good!
                                    R4 ( 10Kohm) is soldered. I read about that pullup resistor that is needed to sync with atmega SCK. Any other hint on what could cause that ?
                                    Maybe, that was a mistake when i changed the fuse? but I didn't have problem before with these settings.
                                    So I'll have to be patient to use M25P40!
                                    • C chbla
                                      C
                                      C
                                      chbla
                                      @chbla said in 💬 Button size radionode with sensors swarm extension:
                                      Can anyone quickly tell me how to do it correctly? I thought it didn't work but I'm unsure.
                                      • C chbla
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @chbla This board has standard FTDI header (see attached screenshot).
                                        But it also has all of ISP pins (mosi, miso, sck, rst)
                                        • H
                                          H
                                          hiddenuser
                                          wrote on last edited by hiddenuser
                                          #100
                                          @Koresh Might be a dumb question I am planning to work on this board, where do I find the complete part list.
