💬 Button size radionode with sensors swarm extension
Does any one have links to dirty pcb or OSH Park? Thanks a lot
^^^warning: it's an infiltration bot.
This post is deleted! -
@NeverDie Not sure if you are referring to me?
[[topic:post-is-deleted]]
@Miroslav-KadanÄ› Thanks!!
I do not have an electronics background. I wend through the pdf files and order the parts and looks like I got the wrong resistor and capacitor or wrong part. Looks like I have to wait for an expert to comment let me know which resistor/capacitor goes where what part size. I would love to hear from someone ;)
@Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
@koresh it is possible to buy this adapter (RFM69HCW -> RFM69CW) or download pcb files ?
Thx -
Thx@miroslav-kadaně said in 💬 Button size radionode with sensors swarm extension:
@koresh it is possible to buy this adapter or download pcb files ?
ThxGo to this link and press the download button: https://www.openhardware.io/view/299/Button-size-radionode-with-sensors-swarm-extension
@neverdie thx, but i need adapter from RFM69HCW to RFM69CW
Re: 💬 Button size radionode with sensors swarm extension
2 cr2032 winter upgrade - works nice
Keep working at -20 Celsius in a fridge. voltage dropped from 6 Volts to 5V and keeps pretty stable while sending temperature reading every 2 minutes for 2 days now.
There are so many reasons to use two CR2032 batteries in series with power converter instead of one lager battery like 2450
-CR2032 are much more widespread batteries
-Wider temperature range
-Stable voltage during all battery lifetime (using voltage converter)
-Stable radio power during battery lifetime
-Batteries give less current during transmitting so they are not "shocked" by high current.So I plan to create version with two CR2032 batteries holder (like on the Yury's photo) and the ultra high efficiency DC-DC converter based on the tps62745 (400 nA quiescent current, 90% efficiency)
:wink: -
The main problem is finding a button holder that can hold two CR2032's in series. So far I've only found two. One is made by Linx, but it's definitely not ideal:
The other works fine, but it has a larger footprint, so I'm not presently using it. It may work well on your board, though, because your board is square, so you can use the diagonal:
On the other hand, maybe you could bend down the tabs and use it as a through-hole?
I did one where I simply cut-off the tabs and then soldered it to the board. That works, but it leaves me with an uneasy feeling as to how long it might last in that configuration. Maybe it's worth re-visiting. -
:wink:@koresh Hello,
can you please update pcbdoc and schdoc files ?
And add a pcb adapter from RFM69HCW to RFM69CW ?
Thx Mirek -
@koresh Hello,
Thx Mirek@miroslav-kadanÄ›
Hello Mirek. All source files are actual, I used exactly the same files to produce latest stable version. I never share source files until I test the board. So I will share updated files (like on the latest screenshot or better) after the board will be checked and tested :wink:
PS
I've added rfm converter board. -
What's the typical time you get with the default node, coin cell and the sketch on github?
https://gist.github.com/solars/6116b78ea7ee581ecfafddb8da4a9610It drained within only 1 day for me
@gohan said in 💬 Button size radionode with sensors swarm extension:
is it sleeping 5 seconds only?
You are right, that was my mistake after testing it. However, the consumption still seems high.
For example I'm right now testing a BME280 which I want to use in the future, with the following sketch:
https://gist.github.com/solars/a5302f1cb60d90f89d7e37d5e23f8c4dIt's connected to SDA/SCL and GND/V - somehow the voltage it receives with a fresh battery is already quite low, and it also doesn't last very long.
