  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
  • KoreshK Koresh
    @pepson Yes. radio footprints are the same. You can use HW or CW via adapter.
    pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    #161
    @koresh
    Ok please share list components... i wait for it.
    And diffrent with v1 and v2 is only that v2 have two batteries ?
    KoreshK 1 Reply Last reply
    • pepsonP pepson
      @koresh
      KoreshK
      KoreshK
      Koresh
      @pepson Yes. So it have longer lifetime, radio range and working temperature range.
      pepsonP 1 Reply Last reply
      • KoreshK Koresh
        pepsonP
        pepsonP
        pepson
        @koresh
        Ok thanks. only wait for list component
        • pepsonP
          pepsonP
          pepson
          Hi
          Can you share your project file and file gerber with this specification
          https://support.jlcpcb.com/article/44-how-to-export-kicad-pcb-to-gerber-files
          Or can you put description to also file gerber ?
          • pepsonP
            pepsonP
            pepson
            Description to model elemnts. Ex. U4
            • pepsonP
              pepsonP
              pepson
              #166
              Please share also layer describe...
              Failed load project to production.
              • pepsonP pepson
                KoreshK
                KoreshK
                Koresh
                wrote on last edited by Koresh
                #167
                @pepson said in 💬 Button size radionode with sensors swarm extension:
                You mixed gerbers of the main board and adapter board.
                It is standard. If you really need it you can find layers description here
                https://goo.gl/Jv33Lb (Generated Gerber Files)
                No I can't. Have no time today, sorry.
                • KoreshK Koresh
                  pepsonP
                  pepsonP
                  pepson
                  @koresh said in 💬 Button size radionode with sensors swarm extension:
                  Can you explaine me more ? What can i do ?
                  • pepsonP pepson
                    KoreshK
                    KoreshK
                    Koresh
                    @pepson
                    pcb2.* - main boards gerbers
                    rfm69c_to_rfm69hc.* - adapter gerbers
                    You need only main board gerbers
                    • G
                      G
                      Gerator
                      Hi @koresh I'm having problems with battery monitor. Trying to find out what's wrong, I have realiced that A6 analog reads from regulator output. So It allways reports 3,3V, isn't it?
                      Also, I read that unregulated could go up to 6,5V. Wouldn't this destroy radio module? I think I'm missing something.
                      Thanks.
                      • D
                        D
                        diogoc
                        Hi. Do you have unassembled pcbs to sell?
                        • G Gerator
                          Thanks.
                          KoreshK
                          KoreshK
                          Koresh
                          @gerator Oh.. so sorry. It is new forum reporting system. Didn't saw your message.
                          A6 reads unregulated voltage (3.5-6.5V) through divider (1/3). So it can't destroyed nothing.
                          • D diogoc
                            KoreshK
                            KoreshK
                            Koresh
                            @diogoc I will try to find them. But all of components are 0402... :eyes:
                            • bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @Koresh I still have a bunch of v1 boards that I never got to work because of power consumption (I presume). I thought I'd make one more attempt.
                              I tried bridging the jumper and I'm using a 2032 battery. Consumption varies between 2 and 4mA on different boards. On some boards it fluctuates a lot. The instructions above are not immediately clear. Do I have to remove the LDO AND capacitors as well?
                              • Y
                                Y
                                yury
                                @bjornhallberg
                                while measuring current draw , was there FDTI adapter connected also?
                                • Y yury
                                  @bjornhallberg
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  wrote on last edited by bjornhallberg
                                  #176
                                  @yury No I ran them on just a 2032 battery at the time, just had it in an external battery holder. I also removed the LDO on one of the boards and bridged the two top pads, with no apparent effect.
                                  Unless there is something wrong with my DMM.
                                  alexsh1A 1 Reply Last reply
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @bjornhallberg I have the same v1 board you have with a sleeping power consumption being 5uA. I also have Si1132 sensor soldered and had some issues with power consumption initially as the standard Si1132 lib did not implement sleep function for this sensor.
                                    1. what sensors do you have? Do they properly put to sleep? BH1760?
                                    2. can you share the sketch?
                                    3. removing the LDO will not help you to bring down consumption from 3mA. 3mA most likely mean your radio is not sleeping. Such consumption will kill CR2032 very quickly - no chance running the board on such consumption
                                    4. did you try a different multimeter?
                                    5. there could be a problem with one of the tantalum capacitor. @yury could you remind which one has to be removed please?
                                    I suggest you start with 5)
                                    • alexsh1A alexsh1
                                      bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      #178
                                      @alexsh1 Thanks for the suggestions! Reassuring to know that you succeeded.
                                      1. I haven't added any sensors so it's just the default ones.
                                      2. https://github.com/EasySensors/ButtonSizeNode ... may need some cleaning up @Koresh or do we use v2 code for v1 sensor as well?
                                      3. I thought as much ... damn. I'm using the CW version radio with the adapter plate. I also thought about the radio but unlike the NRF radio this one should work with no counterfeit units?
                                      4. No my other DMM was out of batteries. Found my old crappy DMM and it says the same, ~2mA.
                                      5. I did remove both caps and it's still at ~2mA.
                                      You're probably right about something not sleeping. Or else I've done a horrible soldering job on the four radios I've attached so far. All four sensors behave pretty much the same.
                                      Also, at least on Domoticz they changed things around now so you have to use V_LEVEL instead of V_LIGHT_LEVEL or what? https://www.domoticz.com/forum/viewtopic.php?t=18577 With V_LIGHT_LEVEL I get some incomprehensible percent value reported.
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @bjornhallberg
                                        1. No - please double check the board. There are options for a few sensors. Which ones do you have. Sensors on board.
                                        2. Code really depends on sensors on board you have.
                                        3. This is not about counterfeit radio. Just radio NOT SLEEPING. That's it.
                                        4. OK.
                                        5. OK
                                        First thing first. Let's deal with your sleeping problem.
                                        Identify which sensors you have on board or post a good quality photo of the board.
                                        Try to use minimum sketch (see commends below - choose the correct Mhz band):
                                        and measure the current
                                        #define MY_RADIO_RFM69
                                        // Please use one!!!!!!
                                        //#define MY_RFM69_FREQUENCY   RF69_433MHZ
                                        //#define MY_RFM69_FREQUENCY   RF69_868MHZ
                                        //#define MY_RFM69_FREQUENCY   RF69_915MHZ
                                        #define MY_NODE_ID AUTO
                                        #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
                                        #define MY_PARENT_NODE_ID 0
                                        #include <Wire.h>
                                        #include <BH1750.h> //Make sure you are using this one https://github.com/claws/BH1750
                                        BH1750 lightMeter;
                                        #include "SparkFun_Si7021_Breakout_Library.h"
                                        Weather sensor;
                                        #define SPIFLASH_BLOCKERASE_32K   0xD8
                                        #define SPIFLASH_CHIPERASE        0x60
                                        lightMeter.begin(BH1750::ONE_TIME_LOW_RES_MODE);
                                          noInterrupts();
                                          _flash.initialize();
                                          _flash.sleep();
                                          interrupts();
                                        lux = lightMeter.readLightLevel();
                                        Serial.print("Lux="); Serial.println(lux);
                                        sleep(10000);
                                        • bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          @alexsh1 I may have made a bit of a mistake with some glitchy chinese test probes. De-glitched cables and connected to a proper lab power supply gave very different readings (with the default git-sketch) ...
                                          Still a bit confused over the differing readings. I get that the board I stripped from regulator and capacitors would perform better though. So do I have to do the same for all the other boards as well? Of course, I could save the worst performing boards for later and run them on 2xAA or something in places where space isn't an issue.
                                          KoreshK alexsh1A 2 Replies Last reply
