  3. Need some help with a Multi-Sensor Node
2 Posts 2 Posters 1.6k Views 3 Watching
  • D
    D
    drock1985
    wrote on last edited by drock1985
    I'm working on making a multi-sensornode (PIR, Light, Temp and V_LIGHT (for night-light)), as well as a repeater node. So far though, I am having problems with the system reporting all the variables every second, instead of on change/every 10 seconds like I have in my sketch. I'm not sure where I am going wrong,. I need the device to only report changes, specifically on motion when it is detected, as well as to receive the V_STATUS message. Would someone please look over this and point me in the right direction? I've been looking at this off and on for a while now and I can't find anything that is majorly wrong.
     * Version 1.0 - Derrick Rockwell (@Drock1985)
    // Enable debug prints
    #define MY_NODE_ID 21
    #include <OneWire.h>
    #include <BH1750.h>
    #include <Wire.h>
    unsigned long SLEEP_TIME = 120000;    // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 3        // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define COMPARE_TEMP 1                // Send temperature only if changed? 1 = Yes 0 = No
    #define ONE_WIRE_BUS 4                // Pin where dallase sensor is connected
    #define LED_ARRAY_1 5                   // Pin that controls the LED Light array (does not need to be a PWM pin)
    #define LED_ARRAY_2 6
    #define MAX_ATTACHED_DS18B20 2
    // #define MY_REPEATER_FEATURE           //Enables Repeater feature for non-battery powered nodes.
    OneWire oneWire(ONE_WIRE_BUS);        // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    DallasTemperature sensors(&oneWire);  // Pass the oneWire reference to Dallas Temperature.
    int lastTemperature = 0;
    int numSensors=0;
    boolean metric = true;
    #define CHILD_ID_MOTION 1   // ID of the sensor child
    #define CHILD_ID_TEMP 2     // ID of Temperature Sensor
    #define CHILD_ID_LUX 3      // ID of Lux Sensor
    #define CHILD_ID_LIGHT 4    // ID of LED light array
    #define LIGHT_ON 1
    #define LIGHT_OFF 0
    BH1750 lightSensor;
    // Initialize  messages
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage msgLux(CHILD_ID_LUX, V_LEVEL); //Sets up custom units (this case LUX for Light)
    MyMessage msgPrefix(CHILD_ID_LUX, V_UNIT_PREFIX); // Sends controller the LUX value instead of %
    MyMessage msgLight(CHILD_ID_LIGHT, V_STATUS);
    uint16_t lastlux = 0;
    int compareMotion = LOW;
    bool stateLight = 0; // Place holders for the loop function to register nodes in Home-Assistant
    bool initialValueSentLight = 0;
      pinMode(LED_ARRAY_1, OUTPUT);                // sets the LED Array as an output
      pinMode(LED_ARRAY_2, OUTPUT);                // sets the LED Array as an output
      lightSensor.begin();
      sensors.begin();
      send(msgPrefix.set("lux"));
    void presentation()  {
      sendSketchInfo("LuxMotionTempSensor", "1.0");
      present(CHILD_ID_MOTION, S_MOTION);
      wait(150);
      wait(150);
      present(CHILD_ID_LUX, S_LIGHT_LEVEL);
      wait(150);
      present(CHILD_ID_LIGHT, S_LIGHT);
      if (!initialValueSentLight) {
        send(msgLight.set(stateLight?LIGHT_ON:LIGHT_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID_LIGHT, V_STATUS);
        wait(2000, C_SET, V_STATUS);
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      if (lux != lastlux) {
        Serial.println(lux);
        Serial.println("Sending lux value");
          send(msgLux.set(lux));
          lastlux = lux;
        int temperature = (((sensors.getTempCByIndex(0)) * 10.)) / 10.;
        if (lastTemperature != temperature && temperature != -127.00 && temperature != 85.00)
        Serial.println(temperature);
        Serial.println("Sending temperature");{
          send(msgTemp.set(temperature));
          lastTemperature = temperature;
       // Read digital motion value
    //  if (compareMotion != tripped)  {
      Serial.println("Sending motion status");
      Serial.println(tripped);
      send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
    //  compareMotion = tripped;
    // sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
      if (message.isAck()) {
      if (message.type == V_STATUS && message.sensor == CHILD_ID_LIGHT) {
          Serial.println("Receiving initial value from controller");
          initialValueSentLight = true;
        // Change relay state
        stateLight = (bool)message.getInt();
        digitalWrite(LED_ARRAY_1, stateLight?LIGHT_ON:LIGHT_OFF);
        digitalWrite(LED_ARRAY_2, stateLight?LIGHT_ON:LIGHT_OFF);
    Thanks,
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      #include <BH1750.h>
      #include <Wire.h>
      int numSensors=0;
      #define LIGHT_ON 1
      #define LIGHT_OFF 0
      BH1750 lightSensor;
        sensors.begin();
        wait(150);
        wait(150);
        wait(150);
            lastlux = lux;
      Thanks,
      @drock1985 the comparison for the tripped check is commented out, so it will send values every time. Uncomment it :)
      If that doesn't help, please post the debug output of the node.
