  3. Magnetswitch + LUX sensor = false positives
5 Posts 2 Posters 1.5k Views 2 Watching
  • meanmrgreenM
    meanmrgreenM
    meanmrgreen
    wrote on last edited by meanmrgreen
    Im trying to combine some sketches in hope to create something that should monitor my mailbox and read the light outside while powering the thing by battery!
    Right now i have basicly cut and pasted the 3 sketches for the switch/battery power and light sensor and have em hooked up on a uno with breadboard. Using USB connection to power it.
    Started with switch and sleep interupt and it worked fine. Removed the debounce since it couldnt be used while sleeping aprently (nuub here)
    Added battery sketch and it seem to be working..
    THEN i put in the damn lux meter and all hell broke lose.
    Everytime i trigger the switch now it starts sending status like crazy to the gw, im talking light speed.
    And while its sending and the switch is seperated it allso gets alot of false positives (or negatives the way you look at it)
    The Battery voltage can be ignored since it isnt even powered by battery or have anything from that hook up on the breadboard.
    And the other thing i noticed is that if i leave the switch closed and let it do its sleep time thing. It reports every 5 minutes! how can that be when i have put the sleep time to 1800000ms, that should if i counted correctly equal to a reading every 30 minutes?
    It seems to be reading the lux and the switch right in domoticz but as said the switch goes on and off.
    Below is a snipped from serial monitor when it goes haywire.
    3061 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
    693
    Battery Voltage: 2.33 V
    Battery percent: 69 %
    3070 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=0,pMSG:SEND,5-5-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:71
    403
    2988 MCO:SLP:MS=1800000,SMS=0,I1=1,M1=1,I2=255,M2=255
    2993 MCO:SLP:TPD
    2995 MCO:SLP:WUP=1
    2998 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    692
    3007 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:69
    404
    3017 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=23,pt=3,l=2,sg=0,ft=0,st=OK:404
    3023 MCO:SLP:MS=1800000,SMS=0,I1=1,M1=1,I2=255,M2=255
    3028 MCO:SLP:TPD
    3031 MCO:SLP:WUP=1
    3034 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    701
    Battery Voltage: 2.36 V
    Battery percent: 70 %
    3043 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:70
    404
    3051 MCO:SLP:MS=1800000,SMS=0,I1=1,M1=1,I2=255,M2=255
    3056 MCO:SLP:TPD
    3058 MCO:SLP:WUP=1
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
     * Arduino BH1750FVI Light sensor
     * communicate using I2C Protocol
     * this library enable 2 slave device addresses
     * Main address  0x23
     * secondary address 0x5C
     * connect the sensor as follows :
     *   VCC  >>> 5V
     *   Gnd  >>> Gnd
     *   ADDR >>> NC or GND
     *   SCL  >>> A5
     *   SDA  >>> A4
     * http://www.mysensors.org/build/light
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_LIGHT 2
    #define CHILD_ID_BUTTON 1
    #define BUTTON_PIN 3  // Arduino Digital I/O pin for button/reed switch
    unsigned long SLEEP_TIME = 1800000; // Sleep time between reports (in milliseconds)
    int oldBatteryPcnt = 0;
    BH1750 lightSensor;
    MyMessage msg(CHILD_ID_BUTTON, V_TRIPPED);
    MyMessage msglux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    uint16_t lastlux;
      lightSensor.begin();
    	analogReference(INTERNAL1V1);
    #else
    	analogReference(INTERNAL);
    void presentation() {
      sendSketchInfo("Switch_Light", "1.0");
      present(CHILD_ID_BUTTON, S_DOOR);
      // Read digital motion value
      boolean tripped = digitalRead(BUTTON_PIN) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    // get the battery Voltage
    #ifdef MY_DEBUG
    	Serial.println(sensorValue);
    #ifdef MY_DEBUG
    	float batteryV  = sensorValue * 0.003363075;
    	Serial.print(batteryV);
    	Serial.println(" V");
    	Serial.print(batteryPcnt);
    	Serial.println(" %");
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          send(msglux.set(lux));
          lastlux = lux;
      // Sleep until interrupt comes in on motion sensor
      sleep(digitalPinToInterrupt(BUTTON_PIN), HIGH, SLEEP_TIME);
    • meanmrgreenM
      meanmrgreenM
      meanmrgreen
      Well it seems to be the debounce thing that is Messing with me.
      How can u remove false positives when battery powered?
      • meanmrgreenM meanmrgreen
        @meanmrgreen easiest way is to do a wait for 10-30ms before going back to sleep. That will let the bouncing settle.
        meanmrgreenM 1 Reply Last reply
          meanmrgreenM
          meanmrgreenM
          meanmrgreen
          @mfalkvidd
          Thanks alot for all the help with My newbie arduino questions. Ill try the wait statement later
          • meanmrgreenM
            meanmrgreenM
            meanmrgreen
            I think i solved it by replacing the tripped code with this modificed code from
            https://codebender.cc/example/MySensor/BinarySwitchSleepSensor#BinarySwitchSleepSensor.ino
            uint8_t value;
            static uint8_t sentValue=2;
            sleep(5);
            value = digitalRead(BUTTON_PIN);
              if (value != sentValue) {
             // Value has changed from last transmission, send the updated value
             send(msg.set(value==HIGH ? 1 : 0));
             sentValue = value;
