  3. Home Assistant
  4. Receiving only UTC time from Home Assistant controller
5 Posts 2 Posters 2.8k Views 2 Watching
  • proddyP
    proddyP
    proddy
    I'm not sure if this is a MySensors or Home Assistant issue, but using the example at https://www.mysensors.org/build/display to read the time from my HA controller, it always pulls the UTC time where in the MySensors library documentation here it states that void receiveTime(unsigned long ts); returns ts "Adjusted for timezone by controller."
    I have the time_zone parameter correctly configured in my Home Assistant's configuration.yaml file.
    As a workaround I have the sensor node convert the time using this piece of code:
    #include <Timezone.h>
    #include <TimeLib.h>
    TimeChangeRule CEST = { "CEST", Last, Sun, Mar, 12, 120 }; // Central European Summer Time, 2 hrs offset
    TimeChangeRule CET = { "CET ", Last, Sun, Nov, 5, 60 };   // Central European Standard Time, 1 hr offset
    Timezone CE(CEST, CET);
    TimeChangeRule * tcr;
    time_t t = CE.toLocal(controllerTime, &tcr);
    RTC.set(t);
    But it would good to know if its a bug or I'm just doing something incorrect?
    • proddyP proddy
      RTC.set(t);
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Paul-Derbyshire
      Hi!
      This is a bug or at least a deviation from the mysensors API. We should fix it. Should be just a matter of using the correct time function, I think.
      proddyP 1 Reply Last reply
        @Paul-Derbyshire
        Hi!
        proddyP
        proddyP
        proddy
        @martinhjelmare is this something I can help contribute too?
        • proddyP proddy
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Paul-Derbyshire
          Yes! Make a PR to pymysensors repository at github. I think calendar.timegm(time.localtime()) should return the correct time.
            @Paul-Derbyshire
            proddyP
            proddyP
            proddy
            @martinhjelmare I made a PR. https://github.com/theolind/pymysensors/pull/80
