  3. [SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway
22 Posts 4 Posters 5.6k Views 3 Watching
  • narfN Offline
    narfN Offline
    narf
    Hello!
    While i'm waiting for my hardware (ordered a couple Sensebender Micro) i tried to set up Controller and Gateway.
    I followed the instructions from here here and configured with
    ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.178.160 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
    But the Gateway doesn't connect to the controller:
    pi@raspgateway:~/MySensors $ sudo mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    Then nothing more follows...
    On openhabian (Raspberry) i installed the MQTT Binding (via OH2 paperUI) and Mosquitto (via openhabian config tool).
    What am i missing? :/
    Thanks in advance!
    Narf!
    Y 1 Reply Last reply
    • narfN Offline
      narfN Offline
      narf
      anybody? :(
      • narfN narf
        Hello!
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        Thanks in advance!
        Narf!
        Y Offline
        Y Offline
        @narf said in OH2 - Mosquito - Raspi Mysensors Gateway:
        That doesn't seem to be right...
        It seems it switches to listening (server) mode, while you are trying to configure an mqtt client connection. Myabe @marceloaqno has a clue?
          Did you try to recompile the gateway?
          • narfN Offline
            narfN Offline
            narf
            no - but i can try!
            i'll just have to run
            make
            and
            sudo make install
            again, right?
            • narfN Offline
              narfN Offline
              narf
              recompiling did the trick:
              pi@raspgateway:~/MySensors $ sudo ./bin/mysgw -d
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              mysgw: Attempting MQTT connection...
              mysgw: connected to 192.168.178.160
              mysgw: MQTT connected
              mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
                You probably compiled it before setting some parameters and with last build they were used. I'm glad you solved it.
                • narfN Offline
                  narfN Offline
                  narf
                  i'm a simple man, i do what the tutorials says =)
                  Thank you very much!
                  • narfN Offline
                    narfN Offline
                    narf
                    alright! today (finally!) i got my sensebender micro. they should send something right away, right?
                    so i plugged one in and got this on the gateway:
                    pi@raspgateway:~/MySensors $ sudo ./bin/mysgw -d        mysgw: Starting gateway...
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    mysgw: connected to 192.168.178.183
                    mysgw: TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0
                    mysgw: !TSF:MSG:LEN,7!=32
                    mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                    mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
                    mysgw: !TSF:MSG:LEN,0!=7
                    does this mean anything? i don't get it at all...
                    • hekH Offline
                      hekH Offline
                      Something is not quite right... See parsed log.
                      Message length seems to be a bit off and command type=7 ?? Doesn't make any sense.
                      • narfN Offline
                        narfN Offline
                        narf
                        what's next? i tried to upload the sensebender micro sketch (couldn't find it in the lib) but had several errors. couldn't find a beginner-beginner tutorial on how to upload a first sketch.
                        Generally this output points to an error with gateway or with sensor?
                        • hekH Offline
                          hekH Offline
                          You must add the micro to your board manager first. Instructions here:
                          https://github.com/mysensors/ArduinoBoards
                          The Sensebender Micro sketch is available here:
                          https://github.com/mysensors/SensebenderMicro/tree/master/Arduino/SensebenderMicro
                          Did you decoupling capacitor on gateway? Do you have more radios to test with in the case one is broken?
                          • narfN Offline
                            narfN Offline
                            narf
                            wrote on last edited by narf
                            i found the board but i don't get how to load the sketch ON the board :/
                            first thought was to c&p the code from https://github.com/mysensors/SensebenderMicro/tree/master/Arduino/SensebenderMicro
                            fatal error: SI7021.h: No such file or directory
                            second thought was to look for an example sketch. no luck.
                            i have other radios. but i'd really love to upload the (right) sketch first... just... how?
                            @hek said in [SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway:
                            did i what exactly?
                            all i can say that i wired the gateway with one of the specified NRF24L01+ Radios.
                            Same radio on sensebender.
                              you need to install library for SI7021
                              narfN 1 Reply Last reply
                                narfN Offline
                                narfN Offline
                                narf
                                @gohan said in [SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway:
                                took libraries from here: https://github.com/mysensors/MySensorsArduinoExamples
                                will investigate further.
                                i think i got the sensor up and running and it can't find a gateway?
                                debug
                                  In Arduino ide open library manager and search for that library or manually download it and choose to install new library as zip file.
                                  For debug you posted it looks the node it is missing the node ID
                                  • narfN Offline
                                    narfN Offline
                                    narf
                                    ok, thought this would be auto assigned: "Define a static node address, remove if you want auto address assignment"
                                    new debug: everything ok with this sensor?
                                    debug
                                    Next Stop Gateway? Should i just try another radio?
                                      Auto assign works if everything else is working and you have a controller that is able to assign node id.
                                      Now it seems there is no communication with gateway: do you also have a log for the gateway? Did you put capacitors on the vcc/gnd on both gateway and node? Keep in mind that RPI is not very suited to power the nrf24 radio.
                                      • narfN Offline
                                        narfN Offline
                                        narf
                                        the gateway "log" is some posts above.
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        should i provide another log?
                                        i didn't use any capacitors, neither gateway, nor node.
                                        here isn't anything regarding capacitors.
                                        and [here](lhttps://www.mysensors.org/build/raspberry under section "NRF24L01+ Radio" it only says "If you are using the nrf24 PA/LNA version you need to use a 5V->3.3V regulator.", but i'm using these so i thought it's ok without using regulators.
                                        or is a regulator something different than a capacitor?
                                          Voltage regulator is OK but you need a capacitor 4.7uF or bigger on vcc/gnd of radio module. Those modules are probably the same as I bought 4 months ago and they are cheap clones and don't have good range but they work with the proper capacitor.
