  3. Relay with finder and asc 712
5 Posts 2 Posters 2.6k Views 2 Watching
  • S
    sindrome73
    Hello and good morning.
    I discovered by accident Mysensors and I immediately buff (Ancra are at an early stage). And I wanted to make home automation for home, but while maintaining current systems.
    At the time at home, in Italy, I have this situation. A relay that receives a pulse and turns on and off the light ..... Carry scheme:
    I would like to create something like that, in order to keep the system in case of failure Mysensors, but integrating home automation.
    to the scheme:
    As we see, idea is to use a ASC712 to see if there current flow and update the controller (DOMOTICZ)
    How do I communicate the change of state in Domoticz ??
    Can anyone help me ??
    • S sindrome73
      to the scheme:
      @sindrome73 - welcome!
      Try the getting started https://www.mysensors.org/about.
      Exactly how the ASC712 works, I dont know but to answer your question "How do I communicate the change of state in Domoticz ??"
      You need just a regular switch 1/0 for MySensors and use the binary sketch (https://www.mysensors.org/build/binary) or some other sketch sending On/off (Relay, Motion...). MySensors will send this to your gateway which your controller (Domoticz) listen to and updates the value.
      • S
        sindrome73
        Hello thanks for the tip, but I've already tried qusto and creates unexpected result.
        I left these sketches: https://www.mysensors.org/build/relay
        If I understand, the logic is this: You press the button sull'arduino, the new state is sent with this line, the controller which updates their status.
         send (msg.set (were? false: true), true); // Send new state and request ack back
        Next comes this part sketch
        void receive (const MyMessage & message) {
          // We only expect one type of message from the controller. But we better check anyway.
          if (message.isAck ()) {
             Serial.println ( "This is an ack from gateway");
             // Change state relay
             message.getBool state = ();
             digitalWrite (RELAY_PIN, are you? RELAY_ON: RELAY_OFF);
             // Store been in eeprom
             saveState (CHILD_ID, state);
             // Write some debugging info
             Serial.print ( "Incoming change for sensor:");
             Serial.print (message.sensor);
             Serial.print ( "New status");
             Serial.println (message.getBool ());
        And the output changes state.
        But if I do, we press an external switch, and change the status, and update the controller with this: send (msg.set (were? False: true), true);
        It falls into a loop ???
        • S sindrome73
          @sindrome73 - sorry i dont understand. What kind of error message do you get? Debug?
          Do you want to be able to send a command FROM domoticz to the node? I didnt answer that above but the other way around.
          • S
            sindrome73
            I beg your pardon, but my English is very bad.
            In the evening load my sketch, so it is more clear ......
            Thanks for your patience for now ......
