  3. New MS node creates lots of random sensors, as well as actual sensors [Domoticz]
8 Posts 3 Posters 2.2k Views 3 Watching
  • V
    V
    velkrosmaak
    A load of components I ordered have arrived, and I'm busying myself building new MySensors nodes for my Domoticz setup.
    I'm using DHT11, PIR, and LDR on one board, using the 3in1 sketch from here: https://forum.mysensors.org/topic/404/3-in-1-humidity-temp-and-motion with the MySensors Light Sensor example sketch from the library.
    This is my version:
    //this is as per the forum 3 in 1, but with ldr
    //node id set msnuslly to 10
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    //ldr stuff
    #define CHILD_ID_LIGHT 3
    #define LIGHT_SENSOR_ANALOG_PIN A1
    //ldr stuff
    int lastLightLevel;
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
      gw.begin(NULL,10,false);
      gw.sendSketchInfo("Humidity/Motion", "1.0");
      gw.present(CHILD_ID_MOT, S_MOTION);
      //ldr stuff
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      //ldr stuff
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.print("Light Level: ");
      Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
        // end light measurement
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    The sensors appear in Domoticz, and work fine. The next day, a load of additional, random sensors appear:
    0_1489518405146_upload-c805f67c-06e6-4447-afbe-7487134783c2
    Has anybody experienced this before? Does my code look OK? Thanks so much for any help!
    • H
      H
      HarryDutch
      Domoticz > Settings > uncheck "Accept new Hardware Devices". Don't forget to click Apply Settings.
      gohanG 1 Reply Last reply
      • H HarryDutch
        @HarryDutch
        I had mine checked all the time but I never had this problem
        • V
          V
          velkrosmaak
          wrote on last edited by velkrosmaak
          These do look like spurious sensors created by my most recent node, for some reason. Rather than nodes from my neighbours being picked up, or similar.
          Incidentally, the actual sensors on this node have stopped updating in Domoticz since the random sensors have appeared.
          This is what my USB Serial MySensors gateway sees. Using library 1.5.1.
          0_1489540411689_upload-1fbefdde-6316-4d5a-9fc3-2c2d89bb975c
            Just wondering why you haven't updated the mysensors library
            • V
              V
              velkrosmaak
              Because it would require updating my Gateway which is in a somewhat inaccessible place right now. That's running 1.5.1 which is when I started playing with MySensors.
              There's no way I can update it over the air, or somesuch, is there?
              • V velkrosmaak
                @velkrosmaak unless it's an esp8266, I don't think you can
                • V
                  V
                  velkrosmaak
                  This particular one is running on an Arduino Duemilanove, but the sensor and gateway are both using the same library version (1.5.1) so that should be all good, no?
