  3. Multi sensor node - Rc433MHz, 2xRelay, DHT11
1 Posts 1 Posters 1.4k Views 1 Watching
  • marekdM
    marekdM
    marekd
    Hi!
    This is my last fast project.
    With this I can control 3x Rc433 MHz wall plugs, 2 relays and to measure room temperature and humidity with a single node.
    This is very simple to make for almost everyone, with some small, like me, soldering skills!
    This is how it looks like:
    The box was drilled to use motion sensor as well - but i change my mind ;)
    Below you can find sketch:
     * Version 1.0 - Henrik Ekblad
     * Version 2.0 - Marek Dajnowicz (Rc433, DHT11 upgrade)
     * How to control Rc433 MHz wall plugs and usage of DHT11
    //#define MY_NODE_ID 16
    #define CHILD_ID_HUM 1 // DHT11
    #define CHILD_ID_TEMP 2 // DHT11
    #define HUMIDITY_SENSOR_DIGITAL_PIN 3 // where DHT is coneccted
    #define RELAY_1 4
    #define RELAY_2 5
    #define CHILD_ID_L1 6 // for Rc433 PLUG 1
    #define CHILD_ID_L2 7 // for Rc433 PLUG 2
    #define CHILD_ID_L3 8 // for Rc433 PLUG 3
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #include <DHT.h>
    #include <NewRemoteTransmitter.h>
    DHT dht;
    float Temp;
    float Hum;
    boolean metric = true;
    MyMessage msgL1(CHILD_ID_L1, V_STATUS);
    MyMessage msgL2(CHILD_ID_L2, V_STATUS);
    MyMessage msgL3(CHILD_ID_L3, V_STATUS);
    MyMessage msgR1(RELAY_1, V_STATUS);
    MyMessage msgR2(RELAY_2, V_STATUS);
    // Create a transmitter on address xxxxxxxx, using digital pin 6 to transmit,
    // with a period duration of 260ms (default), repeating the transmitted
    // code 2^3=8 times.
    NewRemoteTransmitter transmitter(60548078, 6, 260, 3); // address got by ShowReceivedCode.ino from Arduino IDE
    const unsigned long tUpdate = 60000; // update interval 60sec
    unsigned long t0;
      t0 = millis();
      ServerUpdate();
    void ServerUpdate() {
      dht.readSensor(true);
      Hum = dht.getHumidity();
      delay(20);
      Temp = dht.getTemperature();
      delay(20);
      send(msgTemp.set(Temp, 1));
      delay(20);
      send(msgHum.set(Hum, 1));
      delay(20);
      t0 = millis();
    void presentation() {
      sendSketchInfo("Multi Node", "2.0.0");
      present(CHILD_ID_HUM, S_HUM, "HUM");
      present(CHILD_ID_TEMP, S_TEMP, "TEMP");
      present(CHILD_ID_L1, S_LIGHT, "PLUG_1");
      present(CHILD_ID_L2, S_LIGHT, "PLUG_2");
      present(CHILD_ID_L3, S_LIGHT, "PLUG_3");
      present(RELAY_1, S_BINARY, "Relay 1");
      present(RELAY_2, S_BINARY, "Relay 2");
    void before()
        pinMode(pin, OUTPUT);
        digitalWrite(pin, RELAY_OFF);
      if ((millis() - t0) > tUpdate) ServerUpdate();
        int incomingLightState =  message.getBool();
        int incomingOutlet = message.sensor;
        Serial.print("Outlet #: ");
        Serial.println(message.sensor);
        Serial.print("Command: ");
    // Rc433 Plugs
        if ((incomingOutlet == 6) && (incomingLightState == 1))
          transmitter.sendUnit(15, true);
        if ((incomingOutlet == 6) && (incomingLightState == 0))
          transmitter.sendUnit(15, false);
        if ((incomingOutlet == 7) && (incomingLightState == 1))
          transmitter.sendUnit(14, true);
        if ((incomingOutlet == 7) && (incomingLightState == 0 ))
          transmitter.sendUnit(14, false);
        if ((incomingOutlet == 8) && (incomingLightState == 1))
          transmitter.sendUnit(13, true);
        if ((incomingOutlet == 8) && (incomingLightState == 0))
          transmitter.sendUnit(13, false);
    // RELAYS
    if (incomingOutlet == 4) {
          if (incomingLightState == 1) {
            // Turn on  Relay 1
            digitalWrite(incomingOutlet, RELAY_ON);}
          if (incomingLightState == 0)  {
            // Turn off Relay 1
            Serial.println("Turn off Relay 1");
            digitalWrite(incomingOutlet, RELAY_OFF);}}
        if (incomingOutlet == 5) {
            // Turn on  Relay 2
            // Turn off Relay 2
            Serial.println("Turn off Relay 2");
