  3. DHT11 Arduino pro mini no temp readings
13 Posts 5 Posters 5.3k Views 4 Watching
    Mr_sensor
    I'm trying to get my first sensor working. A DHT11 temp/ humidity sensor. I followed the instructions from the build part on Mysensors. Uploaded the sketch and had a look at the serial monitor.
    There it appeared that no temperatures are coming up. So I had a look at the connections and all seems fine to me. What could be the problem? Power?
    Also, having a look at the serial log, does it communicate with the gateway? I think so, but which lines are referring to that?
    The parts with: TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1 ?
    Any advise on how to get the DHT11 to work? Thanks.
    Using the DHTlibrary as mentioned in the instructions.
    Arduino 1.8.2
    Mysensors 2.1.1
    Arduino pro mini ordered from aliexpress I am not sure which version I have both 3.3 volt and 5volt version (how to determine?).
    link text
    link text
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:INIT:STATID=1
    16 TSF:SID:OK,ID=1
    18 TSM:FPAR
    18 TSM:FPAR:STATP=0
    20 TSM:ID
    22 TSM:ID:OK
    24 TSM:UPL
    32 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    47 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    53 TSF:MSG:PONG RECV,HP=1
    55 TSM:UPL:OK
    57 TSM:READY:ID=1,PAR=0,DIS=1
    71 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    79 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    90 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    100 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2117 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
    2129 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2144 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2154 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    2160 MCO:REG:REQ
    2166 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2226 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2232 MCO:PIM:NODE REG=1
    2234 MCO:BGN:STP
    2236 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2242 MCO:SLP:TPD
    2244 MCO:SLP:WUP=-1
    2246 MCO:BGN:INIT OK,TSP=1
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    2269 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2279 MCO:SLP:TPD
    2281 MCO:SLP:WUP=-1
    2304 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2314 MCO:SLP:TPD
    2316 MCO:SLP:WUP=-1
    2336 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2347 MCO:SLP:TPD
    2349 MCO:SLP:WUP=-1```
    Any help would be appreciated. Thanks. W.
      Well, something is wrong with either the wiring or sensor. If you have a multimeter, you should probably do a continuity test on the connections.
      M 1 Reply Last reply
        Mr_sensor
        @hek Thanks for the reply. I just did a test with my multimeter and measuring at the dht11 it shows 3.46 so that should be ok right?
        I used the DHT11 some time ago with an esp8266 and than it was working fine. Could the pin 3 data be the problem?
        • tonnerre33T
          tonnerre33T
          tonnerre33
          wrote on last edited by tonnerre33
          Hi, which sensor do you use ?
          A DHT put on a pcb or without pcb ?
          If you haven't a DHT with pcb, you need to put a 5k resistor between pin 1 and 2 of the DHT ;)
          More information here : https://www.mysensors.org/dl/57c3ec0c4d04abe84cd93e0f/design/DHT11.pdf
          • tonnerre33T tonnerre33
            Mr_sensor
            @tonnerre33 No I have one with pcb.
            • M Mr_sensor
              Mr_sensor
              @Mr_sensor Stil get the message
              Also tried it with an dh22 I had (included a pull-up resistor between vcc and data) but get the same result. What can I do to get this working?
              If I use the arduino pro mini for an other sensor they are working fine (tested with a magnet-reed switch).
                have you set all the waiting/delay times and the initialization before reading the temperature (as seen in the examples)?
                  Mr_sensor
                  This is the sketch I'm using.
                   * Version 1.0: Henrik EKblad
                  #define MY_NODE_ID 2
                  #define MY_PARENT_NODE_ID 0
                  // Enable debug prints
                  //#define MY_RS485
                  #include <DHT.h>
                  #define DHT_DATA_PIN 3
                  #define SENSOR_TEMP_OFFSET 0
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                  DHT dht;
                    sendSketchInfo("TemperatureAndHumidity", "1.1");
                    present(CHILD_ID_HUM, S_HUM);
                    dht.readSensor(true);
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                      Serial.println(temperature);
                    } else {
                      nNoUpdatesTemp++;
                    if (isnan(humidity)) {
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      Serial.print("H: ");
                      Serial.println(humidity);
                    } else {
                      nNoUpdatesHum++;
                    sleep(UPDATE_INTERVAL);
                    Mr_sensor
                    since I did not get these Dht11 or Dht22 working, I decided to try an other sensor type to see if that would work better.
                    So I connected a HTU21D sensor and included the library from sparkfun. Using there demo sketch I can see the sensor is working fine:
                    HTU21D Example!
                    Time:192 Temperature:20.8C Humidity:998.0%
                    Time:1318 Temperature:20.8C Humidity:47.3%
                    Time:2445 Temperature:20.7C Humidity:47.4%
                    Time:3571 Temperature:20.7C Humidity:47.4%
                    Time:4698 Temperature:20.7C Humidity:47.5%
                    Time:5824 Temperature:20.7C Humidity:47.5%
                    Time:6948 Temperature:20.7C Humidity:47.6%
                    Time:8075 Temperature:20.7C Humidity:47.6%
                    Time:9201 Temperature:20.7C Humidity:47.6%
                    But when I include the "adapted" Mysensors sketch I found here in the forum it seems the temperatures are not read or something else is wrong?
                    This is what is in the log file in a ongoing loop:
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    12 TSM:INIT:TSP OK
                    14 TSM:INIT:STATID=2
                    16 TSF:SID:OK,ID=2
                    18 TSM:FPAR
                    18 TSM:FPAR:STATP=0
                    20 TSM:ID
                    22 TSM:ID:OK
                    22 TSM:UPL
                    28 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    47 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    55 TSM:UPL:OK
                    57 TSM:READY:ID=2,PAR=0,DIS=1
                    63 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    75 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    86 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                    96 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2107 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Humidity
                    2119 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                    2129 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2140 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2146 MCO:REG:REQ
                    2164 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2220 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2226 MCO:PIM:NODE REG=1
                    2228 MCO:BGN:INIT OK,TSP=1
                    2 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
                    6 TSM:INIT
                    6 TSF:WUR:MS=0
                    14 TSM:INIT:TSP OK
                    16 TSM:INIT:STATID=2
                    18 TSF:SID:OK,ID=2
                    20 TSM:FPAR
                    20 TSM:FPAR:STATP=0
                    22 TSM:ID
                    24 TSM:ID:OK
                    26 TSM:UPL
                    30 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    57 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    63 TSF:MSG:PONG RECV,HP=1
                    67 TSM:UPL:OK
                    67 TSM:READY:ID=2,PAR=0,DIS=1
                    73 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    92 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    102 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                    112 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2121 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Humidity
                    2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                    2144 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2154 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2160 MCO:REG:REQ
                    2234 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2240 MCO:PIM:NODE REG=1
                    2242 MCO:BGN:INIT OK,TSP=1
                    This is the sketch I use now I had to adopt it since it seemed to be for an older version of Mysensors. I'm no programmer so it might be messed up somehow :)
                     HTU21D Humidity Sensor
                     Hardware Connections (Breakoutboard to Arduino):
                     -VCC = 3.3V
                     -GND = GND
                     -SDA = A4 (use inline 330 ohm resistor if your board is 5V)
                     -SCL = A5 (use inline 330 ohm resistor if your board is 5V)
                    //#define MY_RS485
                    #include "SparkFunHTU21D.h"
                    #include <Wire.h>
                    //static const uint8_t FORCE_UPDATE_N_READS = 10;
                    float lastTemp;
                    float lastHum;
                    boolean metric = true;
                      sendSketchInfo("Humidity", "2.0");
                      //metric = getControllerConfig().isMetric;
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                    //Create an instance of the object
                    HTU21D myHumidity;
                      float temperature = myHumidity.readTemperature();
                      //if (!metric) {
                      //    temperature = (temperature * 1.8) + 32.0;
                      float humidity = myHumidity.readHumidity();
                      sleep(SLEEP_TIME); //sleep a bit
                    Can anyone advise me on the code and the error log so I understand what's going on and what needs to be done to get it working? Thanks a lot.
                    W.
                    • M Mr_sensor
                      HTU21D Example!
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      16 TSF:SID:OK,ID=2
                      18 TSM:FPAR
                      18 TSM:FPAR:STATP=0
                      20 TSM:ID
                      22 TSM:ID:OK
                      22 TSM:UPL
                      55 TSM:UPL:OK
                      2146 MCO:REG:REQ
                      6 TSM:INIT
                      6 TSF:WUR:MS=0
                      14 TSM:INIT:TSP OK
                      18 TSF:SID:OK,ID=2
                      20 TSM:FPAR
                      20 TSM:FPAR:STATP=0
                      22 TSM:ID
                      24 TSM:ID:OK
                      26 TSM:UPL
                      67 TSM:UPL:OK
                      2160 MCO:REG:REQ
                       -VCC = 3.3V
                       -GND = GND
                      //#define MY_RS485
                      #include <Wire.h>
                      float lastTemp;
                      float lastHum;
                      HTU21D myHumidity;
                        //if (!metric) {
                      W.
                      @Mr_sensor I think you need to add
                          myHumidity.begin();
                      Without that, the sensor/sensor library is not initialized.
                      (I looked at sparkfun's example sketch)
                        Mr_sensor
                        wrote on last edited by Mr_sensor
                        :) Great! That helped a lot. I Kicked that out when reading the Converting a sketch from 1.5 to 2.x article.
                        4911 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.4
                        4954 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:50.2
                        4962 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        4968 MCO:SLP:TPD
                        Now I only have to find out what to use for mqtt to read this sensor values. Thats still not very clear to me:
                        Guess it would be something like:
                        mygateway1-out/2/2/0/0/ or 2/2/0/0/1 ?
                        Would it be possible to have something like this:
                        mygateway-out/2/2/Temperature ?
                          Mr_sensor
                          Ok found out what topic is send to mqtt turned out to be:
                          mygateway1-out/2/1/1/0/1 or mygateway1-out/2/0/1/0/1
                          How to get an % and "C" to this topic value?
                            Just use any mqtt client and subscribe to topic # , you will be able to see all messages and pick the one you are looking for
