  3. Vera
  4. Sensebender serial gateway: serial port not recognized in Vera
5 Posts 3 Posters 2.6k Views 3 Watching
  • F
    F
    FrB
    I just started with mysensors and wanted to use a nice serial gateway for my Vera. Everything on the Sensebender seems to work fine, based on the serial output when connected to my PC under the Arduino serial terminal.
    When I connect the Sensebender to my Vera (UI7), it is recognized by the Vera (when looking in the Vera over SSH), but since there is no driver for the native USB/serial-port of the Sensenbender (it is not a standard FTDI USB/serial device), there is no driver loaded and no possible serial connection for the Mysensors app on the Vera.
    Doe anybody have a solution for this?
      wrote on last edited by hek
      See @blaceys answer here: https://forum.mysensors.org/topic/6531/vera-and-moteino-usb-as-gateway/4
      • TmasterT
        TmasterT
        Tmaster
        If it's not a original FTDI chip vera will not recognise it. I already tried that on v1 of my sensors.
        i had to buy a genuine ftdi(difficult to know that on ebay).
        i'm a arduino fan .Even sometimes don't undestanding how to use it :P
          @Tmaster, I think @FrB is using a Sensebender Gateway.
          • F
            F
            FrB
            Thanks for your answers. Yes, I am using the Sensebender which does have its own native usb port of the Atmel ATSAMD21. I will contact Vera to get it working....
            Meanwhile I added a W5100 chip to get it working over ethernet. This seems to be working for now as an alternative to a direct USB/Serial connection.
