  3. Vera Helper with Arduino
13 Posts 6 Posters 9.6k Views 1 Watching
  • B Offline
    B Offline
    BulldogLowell
    wrote on last edited by BulldogLowell
    I've been interested in augmenting my network with Ethernet and WiFi devices for some time. So, just messing around with an Uno and an Ethernet Shield, I built a device that can (without the RF integration)
    • Control any Vera device through HTTP Commands
    • Can be controlled by VERA luup or any wget style command
    • be a sensor on my network
    • be an independant/agnostic layer with equal footing with My Sensors
    • be dependable
    I'm not all the way there yet, but i built a sensor that can talk to my Vera, controlling vera devices and can be controlled by vera.
    This is the web page it creates:
    this sketch allow you to turn on/off a relay via a webpage or Vera, and control a vera device.
    take a look:
    https://www.youtube.com/watch?v=d1kxQCuZEJI
    #include <Wire.h>
    #include <EEPROM.h>
    #include <Ethernet.h>
    #include <EthernetUdp.h>
    #include <utility/w5100.h>
    #include <Time.h>
    #include <Timezone.h>
    #include "DHT.h"
    //#define DEBUG_ON
    #define LED_PIN 8
    #define DHT_SENSOR_PIN 7
    #ifdef DEBUG_ON
    #define DEBUG_PRINT(x)   Serial.print(x)
    #define SERIAL_START(x)  Serial.begin(x)
    #else
    boolean lightOn;
    DHT dht;
    LiquidCrystal_I2C lcd(0x27, 16, 2);
    uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // I'm-fetching-time-indicator for LCD display
    EthernetUDP Udp;
    EthernetServer server(80);
    uint8_t mac[] = { 0xDE, 0xDE, 0xDE, 0xDE, 0xDE, 0xDE };
    unsigned int localPort = 8888;
    IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
    const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
    byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
    byte socketStat[MAX_SOCK_NUM];
    char myString[100];
    byte locator = 0;
    EthernetClient client;
    const byte myserver[] = { 192,168,1,59 };
    const char *dayOfWeek[] = {"Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
    const char *monthString[] = {"NULL", "January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
    TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2, -240};  //Eastern Daylight Time = UTC - 4 hours
    TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, -300};   //Eastern Standard Time = UTC - 5 hours
    Timezone usET(usEDT, usEST);
    TimeChangeRule *tcr;
    boolean forceClockUpdate = true;
      SERIAL_START(9600);
      lightOn = EEPROM.read(0);
      pinMode(LED_PIN, OUTPUT);
      dht.setup(DHT_SENSOR_PIN);
      digitalWrite(LED_PIN, lightOn);
      DEBUG_PRINTLN(F("configuring ethernet"));
      if (Ethernet.begin(mac) == 0) // start Ethernet and UDP
        DEBUG_PRINTLN(F("Failed to configure Ethernet using DHCP"));
        while(true){}
      server.begin();
      Udp.begin(localPort);
      lcd.init();
      lcd.clear();
      lightOn? lcd.backlight() : lcd.noBacklight();
      lcd.createChar(0, clock);
      updateLCD();
      getNTPtime();
      webControl();
    void updateLCD()
      static int lastSecond;
      time_t rightNow = now();
      if (second(rightNow) != lastSecond)
        lcd.setCursor(0,0);
        lcd.print(F("Time:"));
        DEBUG_PRINT(F("Time:"));
        lcd.print(hourFormat12(rightNow) < 10 ? F(" ") : F(""));
        DEBUG_PRINT(hourFormat12(rightNow) < 10 ? F(" ") : F(""));
        lcd.print(hourFormat12(rightNow));
        DEBUG_PRINT(hourFormat12(rightNow));
        lcd.print(minute(rightNow) < 10 ? F(":0") : F(":"));
        DEBUG_PRINT(minute(rightNow) < 10 ? F(":0") : F(":"));
        lcd.print(minute(rightNow));
        DEBUG_PRINT(minute(rightNow));
        lcd.print(second(rightNow) < 10 ? F(":0") : F(":"));
        DEBUG_PRINT(second(rightNow) < 10 ? F(":0") : F(":"));
        lcd.print(second(rightNow));
        DEBUG_PRINT(second(rightNow));
        lcd.print(isAM() ? "am" : "pm");
        DEBUG_PRINT(isAM() ? " am " : " pm ");
        lcd.setCursor(0,1);
        lcd.print(dayOfWeek[weekday(rightNow)]);
        DEBUG_PRINTLN(dayOfWeek[weekday(rightNow)]);
        lcd.print(F("      "));
        lcd.setCursor(11,1);
        lcd.print(month(rightNow) < 10 ? F(" ") : F(""));
        lcd.print(month(rightNow));
        lcd.print(day(rightNow) < 10 ? F("/0") : F("/"));
        lcd.print(day(rightNow));
      lastSecond = second(rightNow);
    //unsigned long
    void sendNTPpacket(IPAddress& address) // Send an NTP request to the time server at the given address
      memset(packetBuffer, 0, NTP_PACKET_SIZE);
      packetBuffer[0] = 0b11100011;   // LI, Version, Mode
      packetBuffer[1] = 0;            // Stratum, or type of clock
      packetBuffer[2] = 6;            // Polling Interval
      packetBuffer[3] = 0xEC;         // Peer Clock Precision
      packetBuffer[12]  = 49;
      packetBuffer[13]  = 0x4E;
      packetBuffer[14]  = 49;
      packetBuffer[15]  = 52;
      Udp.beginPacket(address, 123); //NTP requests are to port 123
      Udp.write(packetBuffer,NTP_PACKET_SIZE);
      Udp.endPacket();
    void receiveTime(unsigned long newTime)
      DEBUG_PRINT(F("Time value received: "));
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
      if ((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour))
        DEBUG_PRINTLN(F("Clock updated...."));
        DEBUG_PRINT(F("Sensor's time currently set to:"));
        DEBUG_PRINT(hourFormat12() < 10? F(" 0") : F(" "));
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute() < 10? F(":0") : F(":"));
        DEBUG_PRINT(minute());
        DEBUG_PRINTLN(isAM()? F("am") : F("pm"));
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        DEBUG_PRINTLN(dayOfWeek[weekday()]);
      lcd.setCursor(15,0);
      lcd.print(F(" "));
    void getNTPtime()
      static unsigned long lastUpdateTime;
      const unsigned long interval = 60000UL;
      if ((millis() - lastUpdateTime >= interval) || forceClockUpdate)
        lcd.write(0);
        sendNTPpacket(timeServer); // send an NTP packet to a time server
        delay(1000);
        if (Udp.parsePacket())
          Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
          unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
          unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
          unsigned long secsSince1900 = highWord << 16 | lowWord;
          DEBUG_PRINT(F("Seconds since Jan 1 1900 = "));
          DEBUG_PRINTLN(secsSince1900);
          DEBUG_PRINT(F("Unix time = "));
          time_t utcEpoch = secsSince1900 - 2208988800UL;//seventyYears = 2208988800UL
          DEBUG_PRINTLN(utcEpoch);
          receiveTime(usET.toLocal(utcEpoch, &tcr) + 2);  //about 2 seconds to call for time
        if (!forceClockUpdate)
          lastUpdateTime += interval;
        forceClockUpdate = false;
    void webControl()
      EthernetClient client = server.available();
      if (client)
        while (client.connected())
          if (client.available())
            char c = client.read();
            if (locator < 100)
              myString[locator] = c;
              locator++;
              myString[locator] = '\0';
            if (c == '\n') //if HTTP request has ended
              DEBUG_PRINTLN(F("MyString ="));
              DEBUG_PRINTLN(myString);
              client.println(F("HTTP/1.1 200 OK")); //new page
              client.println(F("Content-Type: text/html"));
              client.println();
              client.println(F("<HTML>"));
              client.println(F("<HEAD>"));
              client.println(F("<meta name='apple-mobile-web-app-capable' content='yes' />"));
              client.println(F("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />"));
              client.println(F("<link rel='stylesheet' type='text/css' href='http://homeautocss.net84.net/a.css' />"));
              client.println(F("<TITLE>Jim's Home Automation</TITLE>"));
              client.println(F("</HEAD>"));
              client.println(F("<BODY>"));
              client.println(F("<H1>NTP Clock/Light</H1>"));
              client.println(F("<hr />"));
              client.println(F("<br />"));
              client.println(F("<a href=\"/?ledOn\"\">Light On</a>"));
              client.println(F("<a href=\"/?ledOff\"\">Light Off</a><br />"));
              client.println(F("<a href=\"/?phoneyOn\"\">PhoneyTV On</a>"));
              client.println(F("<a href=\"/?phoneyOff\"\">PhoneyTV Off</a><br />"));
              client.println(F("<a href=\"/?syncClock\"\">Force Synchronize Clock</a>"));
              client.println(F("<H2>Current Conditions</H2>"));
              client.println(F("<H3>"));
              client.println(dayOfWeek[weekday()]);
              client.println(F(","));
              client.println(monthString[month()]);
              client.println(F(" "));
              client.println(day());
              client.println(year());
              client.println(F("<font color=\"blue\">Temperature</font>"));
              client.println(F("<font color=\"red\">"));
              client.println((int)floor(dht.toFahrenheit(dht.getTemperature()) + 0.5), 1);
              client.println(F("</font>"));
              client.println(F("<font color=\"blue\">F</font>"));
              client.println(F("<H3><font color=\"blue\">Humidity</font>"));
              client.println((int)floor(dht.getHumidity() + 0.5), 1);
              client.println(F("<font color=\"blue\">%</font>"));
              client.println(F("<div style=\"background-color:grey;"));
              client.print(F(" color:black; margin:20px; padding:20px;\">"));
              client.println(F("<h3>Jim Brower</h3>"));
              client.println(F("<p>"));
              client.println("&#169");
              client.println(F(" 2014"));
              client.println(F("</p>"));
              client.println(F("</div>"));
              client.println(F("</BODY>"));
              client.println(F("</HTML>"));
              delay(1);
              client.stop();
              if(strstr(myString, "?ledOn")) // control arduino pin and LCD backlight //checks for 'on'
                lightOn = true;
                EEPROM.write(0,0xFF);
                digitalWrite(LED_PIN, HIGH);
                lcd.backlight();
                DEBUG_PRINTLN(F("Led On"));
              if(strstr(myString, "?ledOff")) // compliment to above
                lightOn = false;
                EEPROM.write(0,0x00);
                digitalWrite(LED_PIN, LOW);
                lcd.noBacklight();
                DEBUG_PRINTLN(F("Led Off"));
              else if (strstr(myString, "?syncClock"))
                DEBUG_PRINTLN(F("Sync Set"));
              else if (strstr(myString, "?phoneyOn"))
                phoneyTV(true);
                DEBUG_PRINTLN(F("PhoneyTV On"));
              else if (strstr(myString, "?phoneyOff"))
                phoneyTV(false);
                DEBUG_PRINTLN(F("PhoneyTV Off"));
              myString[0] = '\0'; //clearing string for next read
              locator = 0;
    void phoneyTV(boolean status)
      ShowSockStatus();
      if (client.connect(myserver, 3480)) //starts client connection, checks for connection
        DEBUG_PRINTLN(F("connected"));
        client.print(F("GET /data_request?"));
        client.print(F("id=action&output_format=xml"));
        client.print(F("&DeviceNum=88"));
        client.print(F("&serviceId=urn:upnp-org:"));
        client.print(F("serviceId:SwitchPower1"));
        client.print(F("&action=SetTarget"));
        client.print(F("&newTargetValue="));
        client.print(status ? F("1") : F("0"));
        client.println(F(" HTTP/1.1"));
        client.println(F("Connection: close"));  //close 1.1 persistent connection
        client.println(); //end of get request
        delay(1);
        client.stop();
    void ShowSockStatus()
      for (int i = 0; i < MAX_SOCK_NUM; i++) {
        DEBUG_PRINT(F("Socket#"));
        DEBUG_PRINT(i);
        uint8_t s = W5100.readSnSR(i);
        socketStat[i] = s;
        DEBUG_PRINT(F(":0x"));
        #ifdef DEBUG_ON
        Serial.print(s,16);
        DEBUG_PRINT(F(" "));
        DEBUG_PRINT(W5100.readSnPORT(i));
        DEBUG_PRINT(F(" D:"));
        uint8_t dip[4];
        W5100.readSnDIPR(i, dip);
        for (int j=0; j<4; j++) {
          Serial.print(dip[j],10);
          if (j<3) Serial.print(".");
        DEBUG_PRINT(F("("));
        DEBUG_PRINT(W5100.readSnDPORT(i));
        DEBUG_PRINT(F(")"));
    • R Offline
      R Offline
      RJ_Make
      Nice, I like it.
      RJ_Make
      B 1 Reply Last reply
      • R RJ_Make
        Nice, I like it.
        B Offline
        B Offline
        BulldogLowell
        @ServiceXp
        So I've updated this for a four line display and gave it the ability to send a message to the device from its own website:
        the Display shows lots of data points from Vera:
        Video Here
        Anyone interested I'm making one... I'll post the code... or show some more video.
        • D Offline
          dayve218
          @ServiceXp im keen, post away
          R B 3 Replies Last reply
          • D dayve218
            R Offline
            R Offline
            RJ_Make
            @dayve218 I think you mean @BulldogLowell ... ;-)
            RJ_Make
            • D dayve218
              B Offline
              B Offline
              BulldogLowell
              @dayve218
              well, having some free time I've expanded it quite a bit, and I am not 100% sure it will run on an UNO... It works on a mega. I added a bunch of stuff:
              • tells you how many unread emails you have using a BASH script on a server to send updates every so often (I'll post that too).
              • control the brightness of the LCD with a dimmer.
              • uses Vera dimmer and switch to control relay and brightness (uses standard xml files to upload to Vera)
              • more weather
              I don't have a display demo right now, been testing in my Serial Monitor
              I can help you with any of it:
               Vera Auxilliary Controller a.k.a. Arduino/Vera Ethernet Device
               December, 2014
               Version .91
               This sketch features the following:
               * With the device's own website it allows you to send the device a message along with a visual or sound indicator
               * Control LCD backlight
               * Control led (relay)
               * Control your alarm state or lights or execute scenes...
               * Control attached Relay
               * Processes and displays "Vital" data from Vera like the Weather, Alarm State
               * Reliably runs on an UNO but very expandable if you want to use a Mega instead
               * Displays Indoor Temp and Humidity using DHT sensor
               INSTRUCTIONS:
               * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
               * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
               * Add virtual switches to your Vera by following instructions here:http://faq.mios.com/content/2/40/en/how-to-create-virtual-device.html
               * and create a scene and add luup (lua) code like this:
                 local state = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 3)
                 luup.inet.wget("192.168.1.50//?ledState=“..state..”&”)
               copyright (c) by Jim Brower (BulldogLowell@gmail.com)
              #include <Wire.h>
              #include <EEPROM.h>
              //#include <SD.h>  // you will need a MEGA for this, if you want to really expand the web UI
              #include <Time.h>
              #include "DHT.h"
              //#define DEBUG_ON   // comment out getNTPtime(); in loop to get this to fit on an UNO for debug, otherwise debug on a MEGA
              //#define USE_DHCP   // uncomment here for DHCP but uses more than 3kBytes, so warm up your MEGA it is too big for your UNO
              #define DIMMER_PIN 6                // available PWM capable pin
              #define DHT_SENSOR_PIN 7            // Thermometer-Hygrometer
              #define RELAY_PIN 13//8                 // Relay control output
              #define DISPLAY_UPDATE_TIME 3000UL  // 3.5 seconds seems OK
              #define NUMBER_OF_MESSAGE_TYPES 17  // Kinds of transmissions from Vera/Internet
              #define TONE_PIN 6                  // If you want Audio alerts
              #define NUMBER_OF_ACTION_BUTTONS 5  // your device can control scenes, devices, etc Vera-side
              #ifdef  DEBUG_ON
              #else
              typedef enum{
                LCD_WIND, LCD_TIME, LCD_ALARM_STATUS, LCD_GARAGE, LCD_GUEST_GARAGE, LCD_IP_ADDRESS, LCD_TEMPERATURE, LCD_AC_SETPOINT, LCD_OUTSIDE_TEMP, LCD_WEATHER, LCD_FORECAST, LCD_MESSAGE, LCD_HI_LOW, LCD_EMAIL}
              lcdState;
              lcdState state = LCD_TIME;  // display start on Time
              //File webFile;
              char *messagePtr;
              const char *messageType[NUMBER_OF_MESSAGE_TYPES] = {
                "?ledStatus=", "?alarmState=", "?garageState=", "?guestGarageState=", "?weatherCondition=", "?outsideTemp=", "?outsideHumid=", "?airconSetpoint=", "?weatherForecast=", "?messageData=", "?todayHigh=", "?todayLow=", "?windSpeed=", "?windDirection=", "?relayState=", "?brightLevel=", "?emailCount="};
              boolean messageFlag = false;
              unsigned long timerStart;
              unsigned long timerDuration;
              int signal = 0;
              boolean lightOn;
              boolean relayState;
              boolean garageOpen = false;
              boolean guestGarageOpen = false;
              char customMessage [30];
              char weatherCondition[30] = {
                "  Not Yet Reported"};
              char weatherForecast[30] = {
              int outdoorTemp = -99;
              int outdoorHumid = -99;
              int todayHigh = -99;
              int todayLow = -99;
              int airconSetpoint = 78;
              int alarmArmed = -1;
              int windSpeed = 99;
              char windDirection[6] = {"ZZZ"};
              char myCharBuffer[30];
              byte brightLevel = 0;
              byte oldBrightLevel;
              int emailCount = -1;
              byte buttonPin[NUMBER_OF_ACTION_BUTTONS] = {
                4, 5, A0, A1, A2};
              byte lastButtonState[4];
              DHT dht;
              LiquidCrystal_I2C lcd(0x27, 20,4);
              EthernetUDP Udp;
              uint8_t mac[] = {
              IPAddress ip(192,168,1,50);
              char myString[100];
              byte locator = 0;
              const byte veraServer[] = {
                192,168,1,59 };
                "NULL","       Sunday","       Monday", "      Tuesday", "     Wednesday", "      Thursday", "       Friday", "      Saturday"};
                SERIAL_START(9600);
                relayState = EEPROM.read(1);
                pinMode(RELAY_PIN, OUTPUT);
                pinMode(DIMMER_PIN, OUTPUT);
                digitalWrite(RELAY_PIN, relayState? HIGH : LOW);
                for (byte i = 0; i < 4; i++)
                  pinMode(buttonPin[i], INPUT_PULLUP);
              #ifdef USE_DHCP
                 DEBUG_PRINTLN(F("configuring e-net"));
                 DEBUG_PRINTLN(F("Fail Ethernet DHCP"));
                 while(true){
              #else
                Ethernet.begin(mac, ip);
                server.begin();
                lcd.init();
                lcd.clear();
                updateLCD();
                getNTPtime();
                webControl();
                messageTimer();
                updateBriteness();
                for (byte i = 0; i < NUMBER_OF_ACTION_BUTTONS; i++)
                  byte buttonState = digitalRead(buttonPin[i]);
                  if (buttonState == LOW && lastButtonState[i] == HIGH)
                    buttonPress(i);
                  lastButtonState[i] = buttonState;
              void updateLCD()
                static unsigned long lastDisplayChangeTime;
                if (millis() - lastDisplayChangeTime >= DISPLAY_UPDATE_TIME)
                  switch (state)
                  case LCD_TIME:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    DEBUG_PRINT(F("Time: "));
                    DEBUG_PRINT(F(":"));
                    DEBUG_PRINTLN(isAM() ? "a" : "p");
                    lcd.print(dayOfWeek[weekday()]);
                    displayStatus();
                    if (emailCount != -1)
                      state = LCD_EMAIL;
                    else
                      state = LCD_ALARM_STATUS;
                    break;
                  case LCD_EMAIL:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Email Count"));
                    DEBUG_PRINT(F("emails: "));
                    lcd.setCursor(0,2);
                    lcd.print(F("         "));
                    lcd.print(emailCount);
                    DEBUG_PRINTLN(emailCount);
                    displayStatus();
                    break;
                  case LCD_ALARM_STATUS:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Alarm Status"));
                    DEBUG_PRINT(F("Alm: "));
                    lcd.setCursor(0,2);
                    if (alarmArmed == 0)
                      lcd.print(F("     Not  Armed"));
                    else if (alarmArmed == 1)
                      lcd.print(F("        Armed"));
                    else
                      lcd.print(F("  Not Yet Reported"));
                    DEBUG_PRINTLN(alarmArmed ? F("Yes") : F("NO"));
                    displayStatus();
                    state = LCD_GARAGE;
                    break;
                  case LCD_GARAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Main  Garage"));
                    DEBUG_PRINT(F("Garage: "));
                    lcd.setCursor(0,2);
                    if (garageOpen == 0)
                      lcd.print(F("       Closed"));
                    else if (garageOpen == 1)
                      lcd.print(F("        Open"));
                    else
                    DEBUG_PRINTLN(garageOpen ? F("OPEN") : F("CLOSE"));
                    displayStatus();
                    state = LCD_GUEST_GARAGE;
                    break;
                  case LCD_GUEST_GARAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Guest Garage"));
                    DEBUG_PRINT(F("Guest: "));
                    lcd.setCursor(0,2);
                    if (guestGarageOpen == 0)
                    else if (guestGarageOpen == 1)
                    else
                    DEBUG_PRINTLN(guestGarageOpen ? F("OPEN") : F("CLOSE"));
                    displayStatus();
                    state = LCD_TEMPERATURE;
                    break;
                  case LCD_TEMPERATURE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("  Temperture:"));
                    DEBUG_PRINT(F("Inside Temp:"));
                    lcd.print(dht.toFahrenheit(dht.getTemperature()), 0);
                    lcd.print(char(223));
                    lcd.print(F("F"));
                    lcd.setCursor(0,2);
                    lcd.print(F("    Humidity:"));
                    lcd.print(dht.getHumidity(), 0);
                    DEBUG_PRINT(F("Humidity:"));
                    DEBUG_PRINTLN(dht.getHumidity());
                    lcd.print(F("%"));
                    displayStatus();
                    state = LCD_AC_SETPOINT;
                    break;
                  case LCD_AC_SETPOINT:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    A/C Setpoint"));
                    lcd.setCursor(0,2);
                    lcd.print(F("        "));
                    lcd.print(airconSetpoint);
                    lcd.print(F("F"));
                    DEBUG_PRINT(F("A/C setpoint:"));
                    DEBUG_PRINTLN(airconSetpoint);
                    displayStatus();
                    state = LCD_OUTSIDE_TEMP;
                    break;
                  case LCD_OUTSIDE_TEMP:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F(" Outdoor Temp:"));
                    DEBUG_PRINT(F("Ext. Temp:"));
                    lcd.print(outdoorTemp);
                    lcd.print(F("F"));
                    DEBUG_PRINTLN(outdoorTemp);
                    lcd.setCursor(0,2);
                    lcd.print (outdoorHumid);
                    lcd.print(F("%"));
                    DEBUG_PRINTLN(outdoorHumid);
                    displayStatus();
                    state = LCD_WEATHER;
                    break;
                  case LCD_WEATHER:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("  Today's  Weather"));
                    DEBUG_PRINT(F("Weather: "));
                    lcd.setCursor(0,2);
                    lcd.print(weatherCondition);
                    DEBUG_PRINTLN(weatherCondition);
                    displayStatus();
                    state = LCD_HI_LOW;
                    break;
                  case LCD_HI_LOW:
                    fastClearLCD();
                    DEBUG_PRINTLN(F("Weather Hi/Lows"));
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("Today's High: "));
                    lcd.print(todayHigh);
                    lcd.print(F("F"));
                    lcd.setCursor(0,2);
                    lcd.print(F("         Low: "));
                    lcd.print (todayLow);
                    lcd.print(F("F"));
                    displayStatus();
                    if (windSpeed > 2)
                      state = LCD_WIND;
                    else
                      state = LCD_FORECAST;
                      DEBUG_PRINTLN(F("wind too light to report..."));
                    break;
                  case LCD_WIND:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("   Winds  Gusting"));
                    DEBUG_PRINT(F("Winds: "));
                    DEBUG_PRINTLN(windSpeed);
                    lcd.print(F(" "));
                    lcd.setCursor(1,2);
                    if (windSpeed < 10) lcd.print(F(" "));
                    lcd.print(windSpeed);
                    lcd.print(F("mph from the "));
                    lcd.print(windDirection);
                    displayStatus();
                    break;
                  case LCD_FORECAST:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("      Tomorrow"));
                    DEBUG_PRINT(F("Forecast: "));
                    lcd.setCursor(0,2);
                    lcd.print(weatherForecast);
                    DEBUG_PRINTLN(weatherForecast);
                    displayStatus();
                    if (messageFlag)
                      state = LCD_MESSAGE;
                    else
                      state = LCD_IP_ADDRESS;
                    break;
                  case LCD_MESSAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    if (signal == 2 && lightOn == 1)
                      for (int i = 0; i < 20; i++)
                        lcd.noBacklight();
                        delay(50);
                        lcd.backlight();
                        delay(50);
                    else if (signal == 1 && lightOn == 1)
                      beepTone();
                    if (signal != 0)
                      lastDisplayChangeTime - millis();  // give the message back the time lost in the flash/blinking
                    lcd.setCursor(0,1);
                    lcd.print(F("  *** Message ***"));
                    DEBUG_PRINT(F("Message: "));
                    lcd.setCursor(0,2);
                    lcd.print(customMessage);
                    DEBUG_PRINTLN(customMessage);
                    displayStatus();
                    break;
                  case LCD_IP_ADDRESS:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("     IP Address"));
                    DEBUG_PRINT(F("IP Address: "));
                    lcd.setCursor(0,2);
                    lcd.print("    ");
                    for (byte thisByte = 0; thisByte < 4; thisByte++) // print the value of each byte of the IP address:
                      lcd.print(Ethernet.localIP()[thisByte], DEC);
                      if (thisByte < 3) lcd.print(".");
              #ifdef DEBUG_ON
                      Serial.print(Ethernet.localIP()[thisByte], DEC);
                      if (thisByte < 3) DEBUG_PRINT(".");
                      else DEBUG_PRINTLN(F(" "));
                    lcd.print(F(" "));
                    displayStatus();
                    state = LCD_TIME;
                    break;
                  lastDisplayChangeTime = millis();
                  DEBUG_PRINT(F("free ram:"));
                  DEBUG_PRINTLN(freeRam());
                Udp.endPacket();
                setTime(newTime);
                  DEBUG_PRINT(day());
                lcd.setCursor(19,0);
                lcd.print(F(" "));
              void getNTPtime()
                if ((millis() - lastUpdateTime >= interval))
                  lcd.write(0);
                  delay(1000);
                    time_t utcEpoch = secsSince1900 - 2208988800UL;  //seventyYears = 2208988800UL
              void webControl()
                if (client)
                      if (locator < 100)
                        locator++;
                        // Send a full website with controls functions and handles message input...
                        client.println(F(
                          "<html>"
                          "<head>"
                          "<title>Vera Helper</title>"
                          "</head>"
                          "<body>"
                          "<div align=\"center\">"
                          "<H2>Arduino Auxilliary Controller</H2>"
                          "<H3>for Vera</H3>"
                          "<hr>"
                          "<H2><font color=\"green\">Comfort Settings</H2>"
                          "<H4><font color=\"blue\">Temperature</font>"
                        client.println(dht.toFahrenheit(dht.getTemperature()), 1);
                          "<br />"
                          "<H4><font color=\"blue\">Humidity</font>"
                        client.println(dht.getHumidity(), 1);
                          "<H4><font color=\"midnightBlue\">AirConditioning Setpoint</font>"
                        client.println(airconSetpoint);
                          "<br />"
                          "<hr>"
                          "<h2>"
                          "Send Message<br>"
                          "<form>"
                          "<input type=\"text\" size=\"20\" name= \"messageData\" value=\"Enter message here\">"
                          "<select name=\"time\">"
                          "<option value=\"5\">5min</option>"
                          "<option value=\"15\">15min</option>"
                          "<option selected value=\"30\">30min</option>"
                          "<option value=\"60\">60min</option>"
                          "<option value=\"720\">12hrs</option>"
                          "<option value=\"1440\">24hrs</option>"
                          "</select>"
                          "<h4>"
                          "<input type=\"radio\" name=\"signal\" value=\"2\"> Flash<br>"
                          "<input type=\"radio\" name=\"signal\" value=\"1\"> Tone <br>"
                          "<input type=\"radio\" name=\"signal\" value=\"0\" checked> None</h4>"
                          "<input type=\"submit\" onclick=\"alert('Message Sent!')\" value=\"Send\"> <input type=\"reset\" value=\"Reset\"></h2>"
                          "</form>"
                          "<hr>"
                          "<a href=\"/?ledStatus=1?\"\">Turn On LED Backlight</a>    "
                          "<a href=\"/?ledStatus=0?\"\">Turn Off LED Backlight</a>"
                          "<br />"
                          "<a href=\"/?relayState=1?\"\">Turn On Outlet</a>    "
                          "<a href=\"/?relayState=0?\"\">Turn Off Outlet</a><br /> "
                          "<br />"
                          "<a href=\"/?airconSetpoint="));
                        if (airconSetpoint > 70) client.println(airconSetpoint - 1);
                        else client.println(airconSetpoint);
                        client.println(F("?\"\">Lower Air Conditioning Setpoint</a><br /> "
                          "<br />"
                          "<div style=\"background-color:LightSlateGray; color:black; margin:20px; padding:20px;\">"
                          "<h5>&copy; copyright 2014</h5>"
                          "<h5><a href=\"mailto:bulldoglowell@gmail.com?subject=Arduino/Vera Home Controller\">"
                          "Send Email</a><h5>"
                          "</div>"
                          "</body>"
                          "</html>"));
                        delay(1);
                        client.stop();
                        // let's sort out that HTTP request...
                        for (byte i = 0; i < NUMBER_OF_MESSAGE_TYPES; i++)
                          messagePtr = strstr(myString, messageType[i]); // we need a global variable here
                          if (messagePtr)
                            DEBUG_PRINT(F("network msg..."));
                            DEBUG_PRINTLN(messageType[i]);
                            processMessage(i);
                            break;
                        locator = 0;
              #ifdef DEBUG_ON
              int freeRam ()
                extern int __heap_start, *__brkval;
                int v;
                return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
                  DEBUG_PRINT(i);
                  socketStat[i] = s;
              #ifdef DEBUG_ON
                  Serial.print(s,16);
                  uint8_t dip[4];
              #ifdef DEBUG_ON
              void processMessage(byte httpMessage)
                switch (httpMessage)
                case 0: // "?ledStatus="
                  lightOn = parseNumber(httpMessage) ? 1 : 0;
                  //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? lightOn = 0 : lightOn = 1;
                  EEPROM.write(0, lightOn? 0xFF : 0x00);
                  if (lightOn) lcd.backlight();
                  else lcd.noBacklight();
                  DEBUG_PRINT(F("LCD Backlight: "));
                  DEBUG_PRINTLN(lightOn ? F("ON") : F("OFF"));
                  break;
                case 1: // "?alarmState="
                  alarmArmed = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(alarmArmed ? F("Alarm is ON") : F("Alarm is OFF"));
                  break;
                case 2: // "?garageState="
                  garageOpen = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(garageOpen ? F("Garage is Open") : F("garage is Closed"));
                  break;
                case 3: // "?guestGarageState="
                  guestGarageOpen = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(guestGarageOpen ? F("Guest garage is Open") : F("Guest garage is Closed"));
                  break;
                case 4: // "?weatherCondition="  // Parse Weather
                    strncpy(weatherCondition, parseString(httpMessage), sizeof weatherCondition);
                    if (strstr(weatherCondition, "%20"))
                      strncpy(weatherCondition, cleanString(weatherCondition, "%20"), sizeof weatherCondition);
                    if (strlen(weatherCondition) < 19)
                      strncpy(weatherCondition, centerString(weatherCondition), sizeof weatherCondition);
                  break;
                case 5: // "?outsideTemp="  // Parse Outside Temperature
                  outdoorTemp = parseNumber(httpMessage);
                  break;
                case 6: // "?outsideHumid=" // Parse Outside Humidity
                  outdoorHumid = parseNumber(httpMessage);
                  break;
                case 7: // "?airconSetpoint="  // Parse A/C Setpoint
                  airconSetpoint = parseNumber(httpMessage);
                  break;
                case 8: // "?weatherForecast="  // Parse the weather forecast
                    strncpy(weatherForecast, parseString(httpMessage), sizeof weatherForecast);
                    if (strstr(weatherForecast, "+"))
                      strncpy(weatherForecast, cleanString(weatherForecast, "+"), sizeof weatherForecast);
                    if (strlen(weatherForecast) < 19)
                      strncpy(weatherForecast, centerString(weatherForecast), sizeof weatherForecast);
                  break;
                case 9: //"?messageData="  // Parse display message
                    strncpy(customMessage, parseString(httpMessage), sizeof customMessage);
                    if (strstr(customMessage, "+"))
                      strncpy(customMessage, cleanString(customMessage, "+"), sizeof customMessage);
                    if (strlen(customMessage) < 19)
                      strncpy(customMessage, centerString(customMessage), sizeof customMessage);
                    Serial.println(myString);
                    if (strstr(myString, "&time="))
                      DEBUG_PRINTLN(F("Got length marker..."));
                      char *timePointer = (strstr(myString, "&time="));
                      timerDuration = atoi(timePointer + 6);
                      timerStart = millis();
                      DEBUG_PRINT(F("message length:"));
                      DEBUG_PRINTLN(timerDuration);
                    else
                      DEBUG_PRINTLN(F("No length marker..."));
                      timerDuration = 5;
                    if (strstr(myString, "&signal="))
                      DEBUG_PRINTLN(F("Got signal..."));
                      char *signalPointer = (strstr(myString, "&signal="));
                      signal = atoi(signalPointer + 8);
                      DEBUG_PRINT(F("Signal ="));
                      DEBUG_PRINTLN(signal);
                    else
                      DEBUG_PRINTLN(F("No signal..."));
                      timerDuration = 5;
                    messageFlag = true;
                  break;
                case 10: // "?todayHigh="  // Parse Outside High Temperature
                  todayHigh = parseNumber(httpMessage);
                  break;
                case 11: // "?todayLow="  // Parse Outside Low Temperature
                  todayLow = parseNumber(httpMessage);
                  break;
                case 12: // "?windSpeed="  // Parse Outside Low Temperature
                  windSpeed = parseNumber(httpMessage);
                  break;
                case 13: // "?windDirection"  // Parse Outside Low Temperature
                  strncpy(windDirection, parseString(httpMessage), sizeof windDirection);
                  break;
                case 14:  //  "?relayState=" // Get the state of the relay
                  relayState = parseNumber(httpMessage) ? 1 : 0;
                  //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? relayState = 0 : relayState = 1;
                  EEPROM.write(1, relayState ? 0xFF : 0x00);
                  digitalWrite(RELAY_PIN, relayState ? HIGH : LOW);
                  DEBUG_PRINT(F("Relay Status: "));
                  DEBUG_PRINTLN(relayState ? F("ON") : F("OFF"));
                  break;
                case 15:  //  "?brightLevel=" // Get the brightness of the LED
                  brightLevel = parseNumber(httpMessage);
                  brightLevel = map(brightLevel, 0, 100, 0, 255);
                  DEBUG_PRINT(F("Brite:"));
                  DEBUG_PRINTLN(brightLevel);
                  break;
                case 16: // "?emailCount"  // Parse email count
                  emailCount = parseNumber(httpMessage);
                  break;
                default:
                    //Nothing to do here...
              void buttonPress(int buttonID)
                DEBUG_PRINTLN(F("buttonPress"));
                ShowSockStatus();
                if (client.connect(veraServer, 3480)) //starts client connection, checks for connection
                  switch (buttonID)
                    case 0:  // Toggle LED backlight (?ledStatus=)
                        "&DeviceNum=111" // <<<<< Set Vera Device Number for LCD backlight
                        "&action=SetTarget"
                      client.println(lightOn ? F("0") : F("1"));
                      delay(1);
                      client.stop();
                      break;
                    case 1:  // Toggle Relay (relayState)
                        "&DeviceNum=116" // <<<<< Set Vera Device Number for Relay
                        "&action=SetTarget"
                      client.print(relayState ? F("0") : F("1"));
                      delay(1);
                      client.stop();
                      break;
                    case 2:  // Toggle Alarm
                        "&DeviceNum=112" /* <<<<< Set Vera Device Number for Alarm */
                        "&action=SetTarget"
                      delay(1);
                      client.stop();
                      break;
                    case 3:  // run lights out scene  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                        "&action=SetTarget"
                      delay(1);
                      client.stop();
                      break;
                    case 4:  // Lower Air Conditioning //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                        "&DeviceNum=112" /* <<<<< Set Vera Device Number for A/C Control */
                        "&action=SetTarget"
                      if (airconSetpoint > 72) client.print(airconSetpoint - 1);
                      else client.print(airconSetpoint - 1);
                      delay(1);
                      client.stop();
                      break;
                    default:
                      //nothing to do here...
              char *parseString(byte messageNumber)
                int textLocation = (messagePtr - myString + strlen(messageType[messageNumber]));
                myCharBuffer[0] = '\0';
                for (byte i = 0; i < 30; i++) // we have room to display only 20 chars, but lets parse 30.
                  if (myString[textLocation + i] != '&')
                    myCharBuffer[i] = myString[textLocation + i];
                    DEBUG_PRINTLN(myCharBuffer[i]);
                  else
                    DEBUG_PRINTLN(F("got & marker"));
                    myCharBuffer[i] = '\0';
                    break;
                DEBUG_PRINTLN(myCharBuffer);
                return myCharBuffer;
              char *cleanString(char *targetString, char *searchString)
                while(strstr(targetString, searchString))
                  char* stringChunk;
                  stringChunk = strstr(targetString, searchString);
                  targetString[stringChunk - targetString] = '\0';
                  strncpy(myCharBuffer, targetString, sizeof myCharBuffer);
                  strncat(myCharBuffer, " ", sizeof myCharBuffer);
                  strncat(myCharBuffer, stringChunk + strlen(searchString), sizeof myCharBuffer);
                  strncpy(targetString, myCharBuffer, sizeof myCharBuffer);
              int parseNumber(byte msgNum)
                if (strstr(myString, messageType[msgNum]))
                  char *messagePointer;
                  messagePointer = strtok(myString, "=");
                  messagePointer = strtok(NULL, "?");
                  int extractedNumber = atoi(messagePointer);
                  return extractedNumber;
                else
                  DEBUG_PRINTLN(F("Fail parseNumber..."));
                  return -99;
              char *centerString(char *stringToCenter)
                char centerSpacing[30];
                for (byte i = 0; i < ((20 - strlen(myCharBuffer)) / 2); i++)
                  centerSpacing[i] = ' ';
                  centerSpacing[i+1] = '\0';
                strncat(centerSpacing, myCharBuffer, sizeof centerSpacing);
                strncpy(myCharBuffer, centerSpacing, sizeof myCharBuffer);
              void messageTimer()
                if (millis() - timerStart >= timerDuration * 60000UL)
                  signal = 0;
              void fastClearLCD()
                for (int i = 1; i < 3; i++)
                  lcd.setCursor(0,i);
                  for (int j = 0; j < 20; j++)
                    lcd.print(F(" "));
              void timeDate()
                if (hourFormat12() < 10) lcd.print(F(" "));
                lcd.print(hourFormat12());
                lcd.print(minute() < 10 ? F(":0") : F(":"));
                lcd.print(minute());
                lcd.setCursor(11,0);
                if (month() < 10) lcd.print(F(" "));
                lcd.print(month());
                lcd.print(day() < 10 ? F("/0") : F("/"));
                lcd.print(day());
                lcd.print(F("/"));
                lcd.print(year());
              void displayStatus()
                lcd.setCursor(0,3);
                lcd.print(F("A/C:"));
                lcd.print(airconSetpoint);  //lcd.print(dht.toFahrenheit(dht.getTemperature()), 1);
                lcd.print(F("F "));
                lcd.setCursor(11,3);
                if (alarmArmed != 1)
                  lcd.print(F("Not Armed"));
                else
              void beepTone()
                tone(TONE_PIN, 440, 200);
                noTone(TONE_PIN);
              void updateBriteness()
                if (brightLevel != oldBrightLevel)
                  analogWrite(DIMMER_PIN, brightLevel);
                oldBrightLevel = brightLevel;
              • D dayve218
                B Offline
                B Offline
                BulldogLowell
                @dayve218
                BASH script to transmit unread emails to the arduino:
                #!/bin/bash
                #SCRIPT_NAME="Arduino Gmail Checker"
                #SCRIPT_VERSION="0.1"
                #figlet $SCRIPT_NAME $SCRIPT_VERSION
                # Modified for use with Vera Tool #
                #    Jim Brower  January 2015     #
                # Description: Check Gmail for unread email and switch RGB LED on Arduino in accordance #
                # Dependencies: sed, curl,                                                              #
                # Author: Virtualmix        #
                # http://blog.trollmaker.com/article10/arduino-led-notification-for-gmail-on-linux      #
                # License: CC BY        #
                # Enter Gmail username and password below (Warning: Unsafe storage):
                USERID="username"
                PASSWORD="password"
                # Enter number of seconds between email verification:
                WAIT=60
                #set -xv
                # Loop to check for new mail every X minutes
                while [ "1" -eq "1" ]; do
                    # Command line to fetch the number of unread emails:
                    MAILCOUNTER=`curl -u $USERID:$PASSWORD --silent "https://mail.google.com/mail/feed/atom" \ | xmllint --format - \ | sed -n 's#<fullcount>\(.*\)</fullcount>#\1#p'`
                    if [[ "$MAILCOUNTER" = "" ]]; then
                        echo "ERROR: The program coulndn't fetch the account for user \"$USERID\"."
                        echo "- Are you connected to the Internet?"
                        echo -e "- Is the userid and password correct for \"$USERID\"?\n"
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=-1\&
                    elif [[ "$MAILCOUNTER" -eq "0" ]]; then
                        echo "* There is 0 new email for user $USERID."
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=0&
                        # you can do other curl here....
                    elif [[ "$MAILCOUNTER" -gt "0" ]]; then
                        echo "* There is $MAILCOUNTER new email for user $USERID."
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount="$MAILCOUNTER"&
                    fi
                    echo "* Waiting $WAIT seconds before checking for emails again."
                    echo "* (^C to quit the program)"
                    sleep $WAIT
                #set +xv
                done
                C 1 Reply Last reply
                • D Offline
                  dayve218
                  @BulldogLowell thanks!!! ill have a play later on!!
                  • B BulldogLowell
                    @dayve218
                    #!/bin/bash
                    # License: CC BY        #
                    USERID="username"
                    PASSWORD="password"
                    WAIT=60
                    #set -xv
                        fi
                        sleep $WAIT
                    #set +xv
                    done
                    C Offline
                    C Offline
                    cleight
                    @BulldogLowell Would it be possible to use your example without the webserver portion on a Nano and still pull information from Vera?
                    • C cleight
                      B Offline
                      B Offline
                      BulldogLowell
                      @cleight
                      do you mean without ethernet using the MySensors configuration?
                      look at this example, and be sure to check out @korttoma example down the page...
                      • K Offline
                        K Offline
                        korttoma
                        I just had an idea @BulldogLowell .
                        Do you think it would be possible for your Vera Helper to write variables directly to Plot.ly using http.request?
                        How cool would that be?
                        • Tomas
                        • K korttoma
                          B Offline
                          B Offline
                          BulldogLowell
                          @korttoma
                          Sure... you could retrieve data from vera and transmit to plot.ly by making an http request to vera and passing it on to plot.ly.
                          I guess it is possible also to make a MySensors ethenet node and other MySensors sensors could transmit values to the Ethernet Enabled Sensor too.
                          • mntlvrM Offline
                            mntlvrM Offline
                            mntlvr
                            Hello @BulldogLowell
                            I am brand new to this site but have built a few of my own project that monitored batteries and controlled the charging rate as well as the voltage all through a web page but I am Interested in this project, Have you a complete project details with BOM and full working code, as of yet? I am looking to control the fill of a 275 gallon water tank by sonic means. I wish to have the Ultra-Sonic device measure the water level and when certain depth conditions are met the unit will open a valve and allow water in , then when the proper level is met it will close the valve and transmit all this info back to my Vera and or a web page. Please keep up the great idea.
