  3. nRF5 action!
nRF5 action!
  • JokgiJ Jokgi
    @NeverDie Hello, If you are referring to that Prototype Board with the Nordic logo on it then it was being controlled by GPIO and by the Bluetooth Low Energy stack (Softdevice) You can read more about it here.. https://devzone.nordicsemi.com/blogs/831/palna-support-in-s132/.
    As I mentioned before. there is no good way to control the PA in a proprietary mode, only when using BLE. Regardless, I have asked if it is ok to share the schematic that relates to that PA board and I will let you all know. And about the question about antenna switching. This was never implemented in the Softdevice. Any antenna switching would need to be done in the application.
    See if this chart helps.
    NeverDieN
    NeverDieN
    @Jokgi
    Thanks! Yes, those three tables are exactly what I was looking for.
    JokgiJ 1 Reply Last reply
    • NeverDieN
      NeverDieN
      #1182
      https://www.openhardware.io/view/489/BT830X-Power-Amplified-nRF52832-Remote-Control
      • NeverDieN
        NeverDieN
        #1183
        I just noticed a very clever thing that Fanstel did: their nRF52 modules all have the same land pattern and pinout. That means you can upgrade from a regular nRF52832 to a power amplified version, or even an NRF52840 (when they become available), by just dropping the upgrade module into the same position on the PCB. i.e. you can run all the different modules from the same PCB design. Pretty cool. I like it. :)
        • NeverDieN NeverDie
          @NeverDie but how will you spend all the time you save by not having to create new boards all the time? ;-)
          NeverDieN 1 Reply Last reply
            NeverDieN
            NeverDieN
            @mfalkvidd said in nRF5 Bluetooth action!:
            Yeah, not just that, but also not having to waste all that time waiting for each new board to come back from the fab. :)
              @Jokgi
              Do you happen to have the datasheet? The closest I've been able to find is: http://www.mouser.com/ds/2/472/rfaxis_RFX2411N Eval Board Summary and Technical N-952564.pdf
              which isn't quite on-point, but I may have to make do with.
              I had thought it would somehow automagically select the better antenna for receiving, but it looks like it wants me to make that selection myself. So, this may work better with longer preambles I suppose, to give enough time to measure the RSSI on each and then decide.
              NeverDieN
              NeverDieN
              #1186
              I suppose an easy solution would be to have a remote node send repeated packets, and I just program the RFAxis to toggle between its two antennas after allowing sufficient dwell time per antenna. That way it's more likely to receive at least one of the packets.
              All in all, though, I think maybe having two separate radio receivers (since they're cheap anyway) for a gateway is probably better than having one radio receiver, with the burden on the firmware to select which antenna to receive on.
              Any thoughts on this?
                @Jokgi
                JokgiJ
                JokgiJ
                Jokgi
                @NeverDie 0_1508367805179_RD-nRF52-RFX2411N-REV2.zip Hello All -- For your viewing enjoyment. The Schematic and layout files for that nRF52840 and RFX2411n board you have. (If it is version 2 which did have the big Nordic logo on it. )
                I think you may know this already but this bears repeating. This is not a Nordic board. Nordic Semiconductor's tech support will probably not know anything about this board. Also there is a difference between the RFX2411 and the nRF2411N. (N for Nordic) It is not the same device.
                • NeverDieN
                  NeverDieN
                  On a different topic, regarding the Ebyte modules, I'm noticing that they are much more likely to miss a packet if being run at 2.1v than if it's being run at, say, 3.3v. I've tried this now on two different modules, and the results are repeatable. It's a preliminary result, because so far I've only tested it with respect to the "listen mode."
                    JokgiJ
                    JokgiJ
                    Jokgi
                    wrote on last edited by Jokgi
                    #1189
                    @NeverDie Is this the board with a PA on it or stand alone nRF5x part? If with a PA what is the rated voltage of the device?
                    Depending on the Nordic part the nRF5x can run from 1.7 (or 1.8) to 3.6vdc. Note that the nRF51 cannot run with the DC / DC under 2vdc. The nRF52 does not have that restriction and the DC/DC can be used throughout the full voltage range..
                    • JokgiJ Jokgi
                      NeverDieN
                      NeverDieN
                      @Jokgi said in nRF5 Bluetooth action!:
                      I observed it on Ebyte's E73-2G4M04S on this board: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
                      while running in DCDC mode. The E73-2G4M04 has no PA.
                      For now, I'm just reporting the finding, in case anyone else has noticed it. Also, it's a very early result. If there's no known reason to suspect the nRF52832 as a possible cause (i.e. no erratas or the like), then I'm glad to hear it.
                      • NeverDieN
                        NeverDieN
                        #1191
                        OK, I fixed the problem by increasing the size of the listen window by another 30 microseconds (which is the smallest granularity that the RTC offers). What this probably means is that some aspect of the wake-up process (for instance, perhaps the amount of time it takes for the high frequency oscillator to come up to speed) is taking a wee bit longer when the module is powered at the lower voltage than when it is powered at 3.3v.
                        • JokgiJ Jokgi
                          NeverDieN
                          NeverDieN
                          #1192
                          The only definition I've found for PDET is "Analog Voltage Proportional to the PA Power Output ." I'm not sure what that means. So, I set P0.02 to HIGH, which in this instance is 3.3v. However, I'm only getting relatively weak Tx power emitted. Is there anything else I should be doing? For instance, should I be supplying external voltage to the PDET pin directly?
                          Here's the code I'm currently using to setup for transmission:
                            myNrf5_pinMode(2,OUTPUT_H0H1); //PDET
                            myNrf5_pinMode(20,OUTPUT_H0H1); //SWANT
                            myNrf5_pinMode(24,OUTPUT_H0H1); //TXEN
                            myNrf5_pinMode(23,OUTPUT_H0H1); //RXEN
                            myNrf5_pinMode(22,OUTPUT_H0H1); //MODE
                            digitalWrite(20,HIGH);  //select one of the antenna's.
                            digitalWrite(23,LOW);  //disable RXEN
                            digitalWrite(24,HIGH);  //enable TXEN
                            digitalWrite(22,LOW);  //disable MODE
                            digitalWrite(2,HIGH);  //set the analog voltage for PDET as high as possible
                            NeverDieN
                            NeverDieN
                            I tried that just now, and it made no difference.
                            I also tried powering the PA_VDD pin externally at 3.3v, and that didn't help either. Does that pin expect higher voltages?
                            • JokgiJ Jokgi
                              NeverDieN
                              NeverDieN
                              #1194
                              Just now noticed that the schematic explains PDET. It's "Optional Antenna Power Monitoring." So, I take that to mean that it's output from the board, not input to it.
                              Also, the schematic indicates that the board has the DCDC inductors built into it, so that's good.
                              • NeverDieN
                                NeverDieN
                                #1195
                                Aha! Apparently the RFaxis defaults not to the trace antenna on the board, but rather to the external, connected antenna. So, I hooked that up, and now it's working like a champ. I can now safely say that it definitely has a much better range than a non-PA nRF52832 module. And, of course, I'm running it at 2mbps. :)
                                The other nice thing is that even if I transmit continuously (i.e. 100% duty Tx cycle), the chips don't get hot. I'm impressed. I tried doing that with a LoRa module once, and it got too hot to even touch.
                                It will be fun to check the range when there's a PA+LNA nRF52832 on both ends of the link.
                                • NeverDieN
                                  NeverDieN
                                  And here it is:
                                  • NeverDieN
                                    NeverDieN
                                    Of course, I couldn't stop until I tried hooking it up to the 4w boost amplifier:
                                    Wow! That really kicks tail. I don't think there's a nook or cranny anywhere that I don't get a great signal now, and all from a single gateway. :)
                                    • NeverDieN
                                      NeverDieN
                                      I just now ordered a number of Fanstel modules to go with the breakout boards I recently posted. It's worth noting that Fanstel's lowest cost nRF52832 module is only $3.75, which is lower than the Ebyte module: http://www.fanstel.com/buy/bt832-ble42-hardware-ready-for-bluetooth-5-module-2fhya
                                      I ordered one, and I'll see how it compares in actual use.
                                      scalzS Nca78N 2 Replies Last reply
                                        scalzS
                                        scalzS
                                        wrote on last edited by scalz
                                        #1199
                                        interesting for US customers only I think. Because last time I looked, shipping were too expensive (plus add extra shipping fee like customs etc.).
                                          Nca78N
                                          Nca78N
                                          It's woth noting that despite it's "832" name it's in fact an nrf52810 :P
                                          @scalz said in nRF5 Bluetooth action!:
                                          43$ shipping if you're not in the US. And with DHL meaning (at least for me) 10 extra dollars of DHL fee for custom processing + highest tax possible.
