  3. Repeater Node Question
6 Posts 3 Posters 5.2k Views 4 Watching
  • S Offline
    siod
    I would like to add a repeater Node to my Network and I would like to know a few things:
    MY_PARENT_ID for the repeater node is the gateways ID, right? So which MY_PARENT_ID will the repeated Nodes have? The ID of the Repeater Node?
    Does someone have an example sketch of a repeater node for me?
    Thanks in advance!
    still learning...
    • S siod
      Thanks in advance!
      @siod yes, your assumptions are correct.
      There is no example sketch for a repeater node because it only needs to contain a single define. You can add this define to any sketch. If the node uses sleep you will need to change sleep to wait, so the node stays awake. See https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes for details.
      S 1 Reply Last reply
        siod
        @mfalkvidd great, thanks for your quick and short answer! :thumbsup:
        still learning...
        • S Offline
          siod
          wrote on last edited by siod
          one more question: that´s what I have so far, is this all? I think I´ve read somewehere that there must be a special command included and I also read this:
          // Repeater Node1, Repeater Nodes starten bei ID 50
          #define MY_RADIO_NRF24 //MySensor Library auf NRF24 Funkmodul einstellen, muss vor MySensor.h Initialisierung geschehen
          // Define Node ID
          #define MY_NODE_ID 50
          #define MY_PARENT_NODE_ID 0
          #define MY_REPEATER_FEATURE
          //Messages
          //Presentation; present sensors to gateway!
          void presentation(){
            sendSketchInfo("Repeater Node 1", "1.0");
            wait(500);
          //Setup
          //Starte den Loop
          *Handling incoming radio messages
          Nodes that expects incoming data, such as an actuator or repeating nodes, must implement the receive()-function to handle the incoming messages. Do not sleep a node where you expect incoming data or you will lose messages.
          message - The incoming message data*
          where do I have to add this?
          still learning...
          Boots33B 1 Reply Last reply
          • S siod
            // Define Node ID
            //Messages
              wait(500);
            //Setup
            //Starte den Loop
            Boots33B Offline
            Boots33B Offline
            Boots33
            wrote on last edited by Boots33
            @siod What you have above is all you need for a repeater node. if you also have sensors/actuators on this node that are expecting to receive data then you will need to add the receive function. have a look at the RelayActuator example to see how it looks.
            the lines below are not mandatory for a repeater either but of course you can use them if needed
            • S Offline
              siod
              ok, thanks for clarifying this!
              still learning...
