  3. NodeManager
  4. NodeManager Motion Sensor: how to use the SensorSwitch class?
17 Posts 5 Posters 6.6k Views 6 Watching
  • I
    I
    iahim67
    When using the Node Manager for a Motion Sensor, I read the default interrupt mode is "CHANGE" (see that in NodeManager.h).
    I would like it to replace with "RISING" and I can see it could be in the SensorSwitch class, I just don't know how to code this.
    I took the NodeManager "Motion Sensor" example and tried to add "SensorSwitch.setMode(1);" in the before() routine but I'll get a compilation error of course as I didn't code that the right way.
    Can someone please teach me how to make it right?
    This is my code so far:
      NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
      NodeManager includes the following main components:
      - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
      - Power manager: allows powering on your sensors only while the node is awake
      - Battery manager: provides common functionalities to read and report the battery level
      - Remote configuration: allows configuring remotely the node without the need to have physical access to it
      - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
      Documentation available on: https://github.com/mysensors/NodeManager
    // load user settings
    #include "config.h"
    // load MySensors library
    // load NodeManager library
    #include "NodeManager.h"
    // create a NodeManager instance
    NodeManager nodeManager;
    // before
    void before() {
      // setup the serial port baud rate
      Serial.begin(MY_BAUD_RATE);
         Register below your sensors
      nodeManager.setBatteryMin(1.8);
      nodeManager.setBatteryMax(5.2);
      nodeManager.setSleep(SLEEP, 1, MINUTES);
      nodeManager.registerSensor(SENSOR_MOTION, 3);
         Register above your sensors
      nodeManager.before();
    // presentation
    void presentation() {
      // call NodeManager presentation routine
      nodeManager.presentation();
    // setup
      // call NodeManager setup routine
      nodeManager.setup();
    // loop
      // call NodeManager loop routine
      nodeManager.loop();
    // receive
      // call NodeManager receive routine
      nodeManager.receive(message);
      You don't want to report when pir sensors resets to "no motion"?
      • I
        I
        iahim67
        I'm not sure about that, what I really want is to learn how to use NodeManager.
        Like how can I make such changes as described.
        I want to experiment a bit and don't know how :simple_smile:
          Node manager is made to automate the most common tasks and the pir sensor normally needs to report both status changes, so if you need to experiment you'd probably need to write some code yourself ☺️
          • I
            I
            iahim67
            You're absolutely right :simple_smile:
            I am experimenting with mysensors as much as I can. My motion sensor works fine without NodeManager ... but I'm interested in NodeManager too.
            Back to my question however, how can solve my issue?
              Only author can answer that 😀
              • I
                I
                iahim67
                That fine ... I just don't know who's the author, I guess I have to solve this issue first :smile: , or I get lucky and he'll read my post!
                  @user2684 is the guy
                  • U
                    U
                    user2684
                    Sorry for the delay guys, for some reasons I haven't got the notification of this thread, thanks @gohan for pulling me in! When using SENSOR_MOTION, the default mode is already RISING. To help you reading through the code, the registerSensor() in NodeManager.cpp would create an instance of the SensorMotion class. SensorMotion is derived from SensorSwitch (which has CHANGE has default mode) but in its constructor (SensorMotion::SensorMotion) you will find a setMode(RISING) which is then the default value.
                    Whatever parameter you want to change, this requires three steps:
                    • registering the sensor
                    • retrieving the instance of the class
                    • invoking its functions
                    SensorSwitch in your example above is a class, you need the instantiated object to invoke its member functions. So something like the following:
                    // register the sensor and keep track of its id
                    int sensorPIR = nodeManager.registerSensor(SENSOR_MOTION,3);
                    // retrieve the instance of the object. Since getSensor() will return a generic Sensor class, you need to cast it accordingly
                    SensorMotion* sensorMotion = (SensorMotion*)nodeManager.getSensor(sensorPIR_Id);
                    // invoke whatever function you need. Since sensorMotion is a pointer, you need to use the -> notation
                    sensorMotion->setMode(CHANGE);
                    sensorMotion->setInitial(LOW);
                    Does it make sense now?
                    • I
                      I
                      iahim67
                      Thank you very much sir, it start making sense to me, I still need to "digest" this :smile: as I am a HW engineer ... but trying to improve my SW skills.
                      I am comfortable with the basics of C and Arduino but not really with object oriented programming.
                      What literature would you suggest me to start with to understand this kind of coding? Java perhaps?
                      gohanG 1 Reply Last reply
                      • I iahim67
                        @iahim67 c++? 😁
                        • I
                          I
                          iahim67
                          I thought you may say that :smile: ... is there a good C++ book for beginners that you would recommend?
                          On paper I mean, that I can buy?
                          TerrenceT 1 Reply Last reply
                            I could sell you mine, it is still brand new but it is in Italian 😁
                            • U
                              U
                              user2684
                              Agree starting from c++ would make more sense :-) Just a silly personal advise: pay attention not to get lost into the tons of capabilities c++ can provide, especially if you want to be just focused on arduino to start with since you can easily get lost. Sometimes I personally prefer just an electronic one-pager with a good amount of examples :-)
                              • I iahim67
                                TerrenceT
                                TerrenceT
                                Terrence
                                @iahim67 Simon Monk's Programming Arduino: Getting Started... book is pretty good.
                                Look at the table of contents.
                                https://www.amazon.com/Programming-Arduino-Getting-Started-Sketches/dp/1259641635/
                                • I
                                  I
                                  iahim67
                                  Thanks for your help, I'll start with Simon Monk's Programming Arduino :smile: !
                                  • JoeyGJ
                                    JoeyGJ
                                    JoeyG
                                    This post is deleted!
