  3. Repeater Node not working, pls help debug...
2 Posts 2 Posters 1.3k Views 2 Watching
  • siodS
    siodS
    siod
    wrote on last edited by siod
    unfortunately I can´t get my first repeater node to work. Actually it worked a few times, now I only get these messages and it is not communicating correctly with my GW:
    Log Parser Link
    This is my repeater node code:
    // Repeater Node1, Repeater Nodes starten bei ID 50
    //#define MY_DEBUG
    #define MY_RADIO_NRF24 //MySensor Library auf NRF24 Funkmodul einstellen, muss vor MySensor.h Initialisierung geschehen
    // Define Node ID
    #define MY_NODE_ID 50
    #define MY_PARENT_NODE_ID 0
    #define MY_REPEATER_FEATURE
    #include "Timer.h"
    //Variables
    Timer t;
    //Messages
    //Presentation; present sensors to gateway!
    void presentation(){
      sendSketchInfo("Repeater Node 1", "1.0");
      wait(500);
    //Setup
      Serial.begin(9600);
      sendImAlive();
      t.every(60000, sendImAlive);
    //Starte den Loop
      Serial.println("Sending Update...");
      t.update();
      Serial.println("...Done!");
    void sendImAlive() {
        sendHeartbeat();
    I hope you can help me! Thanks in advance!!!
    still learning...
      NACK usually it is a range issue if the radio module is working correctly. Try putting repeater node closer to the gateway
