  3. NodeManager
  4. can not get the BH1750 to work with NodeManager
1 Posts 1 Posters 1.4k Views 1 Watching
  • B
    B
    betonmoewe
    wrote on last edited by betonmoewe
    I have tried to convert (or recreate) my original mySensors 2.1.1 Sketch to a new NoteManager scetch because I love the idea behind the NodeManager (great work). I have a Sensor with the BH1750 and one DHT22 connected. With my old sketch, both sensors are working. With the new NodeManager based sketch, only the DHT22 produces a reading, the BH1750 is silent. I have tried the 1.5 and the 1.6 (beta) version (1.6 with the DHT library from the description) still nothing.
    Here are the relevant code:
    void before() {
    // setup the serial port baud rate
    Serial.begin(MY_BAUD_RATE);
    pinMode(BMPLUXPWR_PIN, OUTPUT); # to set PowerPin for BH... permanent high (works (tested via multimeter))
    digitalWrite(BMPLUXPWR_PIN, HIGH);
    delay(2000);
    • Register below your sensors
      nodeManager.setSleepMinutes(10);
      nodeManager.setBatteryMin(1.8);
      nodeManager.setBatteryMin(3.2);
      nodeManager.registerSensor(SENSOR_DHT22,3);
      nodeManager.registerSensor(SENSOR_BH1750);
      nodeManager.setPowerPins(6,5,250); # Pin 5 is for the DHT Sensor
    • Register above your sensors
      nodeManager.before();
    all other code is unchanged.
    I can not enable debug because of too low memory :(
    ok ok ... after disabling some default sensors (analog/digital) I have some debug output:
    REG I=1 P=3 P=6 T=0
    REG I=2 P=3 P=7 T=1
    REG I=3 P=18 P=16 T=37
    PWR G=6 V=5
    NodeManager v1.6-dev
    LIB R=N T=N A=A S=- B=-
    INT P=3 M=255
    INT P=2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.34 P=100
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.34
    PRES I=1 T=6
    PRES I=2 T=7
    PRES I=3 T=16
    READY
    MY I=109 M=1
    ON P=5
    DHT I=1 T=28.90
    SEND D=0 I=1 C=0 T=0 S= I=0 F=28.90
    DHT I=2 H=98.40
    SEND D=0 I=2 C=0 T=1 S= I=0 F=98.40
    BH1 I=3 L=0
    SEND D=0 I=3 C=0 T=37 S= I=0 F=0.00
    OFF P=5
    SLEEP 600s
    AWAKE
    ON P=5
    DHT I=1 T=nan
    DHT I=2 H=98.40
    SEND D=0 I=2 C=1 T=1 S= I=0 F=98.40
    BH1 I=3 L=0
    SEND D=0 I=3 C=1 T=37 S= I=0 F=0.00
    OFF P=5
    SLEEP 600s
    AWAKE
    ON P=5
    DHT I=1 T=28.70
    SEND D=0 I=1 C=1 T=0 S= I=0 F=28.70
    DHT I=2 H=nan
    BH1 I=3 L=0
    OFF P=5
    SLEEP 600s
    The Humidity reading of the BHT sensor is a little bit wired, but this is the same with my old sketch (defect?)
    Maybe someone have the right idea????
    Best regards and thanks
    Frank (Betonmoewe)
